#1 | Link |
Can you output 1080p over component?
I was under the impression that 1080p required the use of DVI/HDMI. Am I wrong? Are there any TV's that accept a 1080p signal via component?
The reason I ask is because if it doesn't then how can the cheap version of the PS3 output 1080p with now HDMI port? |
#4 | Link | |
Component is a very robust system with one problem, Hollywood can't control it. |
#7 | Link | |
__________________
You are all WEIRDOS! - Sam the Eagle |
#8 | Link | |
Most experts say that the difference between a 1080i component and HDMI isn't really noticable, does this change with 1080p sources? Seems the main problem is whenever movie studios decide to turn on the token system. |
#10 | Link | |
#13 | Link |
Component 1080i is the max that AACS will allow over component.
__________________
But in my own way, I am King. Hail to the King, baby. My Networked Media/Music/DVD Server |
#15 | Link | |
The probelm is not the component signal.
That signal will do 1080p60 without any problems. BUT the licenses governing BD-ROM A/V do NOT allow 1080p outputs on analog connectors. The maximum permissible output resolution is 1080i60. This has nothing to do with the ICT flag btw, so it doesn't matter if ICT=0 or ICT=1. Also keep in mind that the provisions in the BD-ROM A/V license do NOT extent to PS3 games, so the games might output 1080p over component if Sony chose to allow that. |
#16 | Link | |
AVS CLUB MEMBER
--Darin |
#21 | Link |
AVS CLUB MEMBER
It was never realistic to believe Sony would provide the same BR performance level in a machine that not only is listed at half the price of their BR player, but is to double as their flagship gaming device.
Darin has right. Jim |
#22 | Link |
So the answer is "yes" to is it physically possible to do 1080p over component, but protected movie content will still be subjected to 1080i over component (and less with higher restrictions set). Videogame output is still up to whatever the game designers feel obliged to target. Possibly homegrown hd videos burned to disc could still take advantage of 1080p over component, but likely that will be 1080i sourced anyways unless you are using very pro-level videocam equipment.
#23 | Link | |
Cake or Death
__________________
HEY, you viewing dumbasses! NOW! NEW! ALL NEW! (insert name of show here) NEXT! 8/9 PM ET TUESDAY! NEXT WEEK! IN 2 WEEKS! |
#24 | Link | |
Mayor
AVS GOLD CLUB MEMBER
So, if ICT=1 and you've got a 1080p24 source film, the analog pathway could look like this: disc -> 1080p24 -> 960x540p24 -> 1920x1080i60 -> display No studio has announced plans to use ICT (most have very vocally said they would not...at least not at first). Of the majors, Warner is seen as the most likely pulling the trigger someday.
__________________
Alex doesn't live here anymore |
#25 | Link | |
Heading to 5k
#28 | Link | |
I don't know if I like the idea getting my Dolby HD Lossless (or DTS) over analog. I guess the PS3 will hold me over till the "real" players come down in price.
__________________
John |
#29 | Link |
lufters, I am wondering why you need 2 HDMI ports on the PS3. One should do just fine. The HDMI out will go into the New Receiver you need to buy to get Lossless audio then a second HDMI wire from the Receiver to the monitor.
Remember, to get Lossless Audio you need HDMI 1.3 and it is not out yet if I am not mistaken. Next month I think?
__________________
"I believe in censorship. After all, I made a fortune out of it." -Mae West |
#30 | Link | |
They were originally suppose to have 2 HDMI's for Dual Monitor hookup.
__________________
John |
| Bookmarks |
| Thread Tools | |
