AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > DVD Players (Standard Def)
Forum Jump
Old 05-28-06, 05:43 PM   #1   |  Link
anandxxx
New Member
Toshiba SD-4990 Vs. Phillips 5960 Upconverting DivX 6 players!!
Has anyone done a shootout yet? I bought the Toshiba, but returned it after 29 days and 23 hours. Now I have the Phillips 5960. And I hate A-B'ing stuff so much that I didn't do rigorous tests on upconverting or DivX playback (my main concern) with either one. But I can say that the upconverting on the Phillips is ass. My HDTV does better with a 480P signal. But you CAN view pictures (slowly) in 1080i, which is pretty cool. I actually FORGOT to try the feature at all on the Toshiba (I don't really care about upconverting, anyway).
I'm most interested in the DivX/XviD/what-have-you playback. The Toshiba did pretty well. It played more than the Phillips DVP642 (or whatever, the earlier model), but not TOO much more. The new Phillips also plays more than the previous Phillips, but still not everything. It still doesn't play QPEL (although it plays a few frames at a time, then pauses, then plays a few more, AND it can actually play smoothly in fast-forward mode).
Also, the Toshiba is about 20 bones more. And HDMI cables are a total ripoff. That is all.
This is pretty scattered, because I wrote it in a hell of a hurry. Anybody more detail-oriented have anything SUBSTANTIAL to add to the debate, unlike me?
Maybe I'll just get the Phillips DVP3040 (DivX 6, no upconverting)...
anandxxx is offline   Reply With Quote
Old 05-28-06, 07:20 PM   #2   |  Link
bigsnyder
I am most interested in the 480p PQ of these players. I would assume the non-upconverting
models would be similiar such as the DVP-5140 and SD-3990.
C Snyder
bigsnyder is offline   Reply With Quote
Old 05-29-06, 03:04 AM   #3   |  Link
tanooki
I too tried the Toshiba first,then exchanged for the Philips,then returned that,I wasn't completely satisfied with either.The Toshiba would play some files that my old dvp642 would not but failed to play numerous avi's and mpg's that it would. The 5960 played all and more than than the 642 and even allowed zooming in HD JPEG mode(which the Toshiba will not) but does not have a pause/step feature which sadly enough is a deal breaker for me. The Toshiba actually has a step feature but no zoom in HD JPEG. The Toshiba plays qpel and GMC as does the phillips. I found the philips to better in the playback dept. but feels very cheap and the remote sucked. If you do have a 642 though...the remote from the 642 does work with the latter(yeah I actually like the 642 remote...or maybe I'm just used to it).
Also: The 5960 is Divx Ultra certified but the 4990 is not yet both play the same files encoded in divx 6 with menus flawlessly.
tanooki is offline   Reply With Quote
Old 05-30-06, 03:33 PM   #4   |  Link
WaldorfSalad
AVS CLUB MEMBER
Classified Rating: 100% (12)
IMHO, the Philips 5960 is fundamentally flawed due to the following scenario....
- You are using the HDMI output with resolution set to 720p or 1080i resolution.
- You are playing a 4:3 DVD.
- Your TV does not let you select Normal (pillar-boxed) aspect ratio for 4:3 pictures received via HDMI at 720p or 1080i resolution. AFAIK, most HDTVs fall into this catergory. At least the Sony and Samdung RPTVs do.
The result is that for a 4:3 picture via HDMI the picture is always stretched horizontally. Most other HDMI upconverting DVD players, such as Sony and Panasonic, have a setting (Normal or Full) that lets you choose how to deal with 4:3 DVDs in case your TV won't let you.
As for PQ from the Philips 5960...its not too bad but not spectacular. HDMI seems to be a little better than component. I think the Sony and Panasonic upconvert players are a bit better though. Other nitpicks about the Philips 5960: the remote sucks, no open/close button on remote (but pressing the stop button for 2 seconds opens/closes the tray), no digital optical output, pressing play or eject on the unit doesn't power it on, the thing is so light that if you press a button on the front panel the whole player moves. Another shining example of the cheapening of CE that is so prevalent nowaday.
P.S. It plays PAL discs on an NTSC TV just fine and there is a working region-free hack posted on www.videohelp.com
WaldorfSalad is offline   Reply With Quote
Old 10-12-06, 06:31 PM   #5   |  Link
hayabusa55
Anyone figure out a way to letterbox the content?
hayabusa55 is offline   Reply With Quote
Old 01-01-07, 02:16 PM   #6   |  Link
toolazyforalogin
New Member
I am in the same predictament here.....the Toshiba SD-4990 vs the Philips 5960 - I'm on the fence....I currently have a Philips 642 and it plays everything I've thrown at it.....pal/ntsc - divx xvid vcd etc.....the one thing that I CAN'T STAND on the Philips 642 is that you can only FF at 8x - does anyone know how fast you can FF on either the Toshiba SD-4990 or the Philips 5960 - for me....this is the dealbreaker......
In addition the 5960 has USB input so I can throw divx files on a jumpstick w/o the need to burn a RW disc everytime......the problem is that some users on videoh$%lp claim the DD 5.1 doesn't work? Can that be true? idk.....
Thanks for the help. It's much appreciated.
toolazyforalogin is offline   Reply With Quote
Old 01-02-07, 03:24 AM   #7   |  Link
dr0s
The 5960 is a natural upgrade to your 642. There is much discussion in the videohelp forums by people who have owned both (or the 642 and the 5940, which is the same as the 5960 except for the USB). Digital audio out should be fine, as long as you have the latest firmware on the player.
As for FF, the philips will FF DVDs at higher rates, but I am traveling and cannot recall whether this applies as well to video files on the USB or disk. - DR
dr0s is offline   Reply With Quote
Old 01-03-07, 10:38 AM   #8   |  Link
shawn67
FF 32x with Phillips 5960 I get DD 5.1 no problem.
__________________
Annoying Notre Dame "fan"
shawn67 is offline   Reply With Quote
Old 01-03-07, 09:33 PM   #9   |  Link
toolazyforalogin
New Member
Smile
Thanks. 5960 on its way.
Old 01-04-07, 12:02 AM   #10   |  Link
Jim McC
5960
Is it true that the 5960 stretches 4:3 DVD's and you can't avoid it? If so, I'll pass on the 5960.
Jim McC is offline   Reply With Quote
Old 01-04-07, 04:07 AM   #11   |  Link
dr0s
If your DVD is encoded as 4:3 (or letterboxed in a 4:3 window), and you use an upconverted resolution, then indeed it automatically goes into stretch mode. This is very common among inexpensive players, for those that avoid it look for a pillarboxing mode (such as the Oppo 970 has).
That said, there is a way to avoid the stretching on the Philips, namely use 480p instead of 720p or 1080i. This takes one or two pushes of a front panel button. You of course lose any advantages of upscaling for such DVDs, but the quality difference is often minimal on 4:3 material (like old TV shows). - DR
Old 01-07-07, 04:22 PM   #12   |  Link
toolazyforalogin
New Member
I continue to use 1080i but put my tv on 4:3 mode instead of 16:9 and nothing is stretched.
Old 01-08-07, 08:18 PM   #13   |  Link
overfiend
holy crap I thought it was just my TV doing this, now I know it's the 5960...I wish I could set my hdtv to 4:3 but my philips 42PF9631D will only allow 'automatic' and 'widescreen' when source is from HDMI. THIS SUCKS. Most of my widescreen dvds are letterboxed 4:3 so I really hate how they look stretched horizontally.
overfiend is offline   Reply With Quote
Old 01-09-07, 04:07 AM   #14   |  Link
dr0s
I can do this on my set too, but it cuts some of the image off at the sides (not as much as 4:3 clipping of a widescreen image, but a nonnegligible amount), so I prefer on such films to just go back to 480p. - DR
Old 01-11-07, 10:46 PM   #15   |  Link
toolazyforalogin
New Member
Interesting....I'll take another look. Perhaps I missed something.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.19041896 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
