#1 | Link |
Welcome to the thread!
The Oppo Digital DV-970HD is one of the most highly anticipated DVD players since the incredible Oppo Digital DV-971H. The DV-970HD is a highly-featured sister product to the DV-971H. New features include: HDMI, Memory card reader, SACD, upconversion via component (non-copy protected discs). Deinterlacing is performed by Media Tek - no macroblock enahance problems. Please note the reported results do change with firmware updates. Because of the continuous improvement, this first post is always a work "in progress". Contents: ------------
DV970HD is to be available 5/31/2006! FEATURES:
Latest: MVer: 05.00.01.07 Batch: 3A-0916 Release Date: Sept 22, 2006 Release Notes: The following new features and improvements are included in this version: 1. Improved HDMI Audio Compatibility and High Resolution Audio Output through HDMI This version improves HDMI audio compatibility with TV, A/V receivers and audio processors. It also enables high resolution multi-channel audio output through the HDMI interface. The following setup menu settings are recommended: When the HDMI output is connected to a TV directly, please use the factory default settings. The related settings are: Speaker Setup Page: Down-mix: Stereo Front Speaker: Large Subwoofer: Off Audio Setup Page: HDMI Audio: LPCM With the above factory default settings the DVD player will down-mix center and surround audio channels to stereo and send in LPCM format to the TV. High resolution audio will be down-sampled to meet the TV's playback capability. The 2-channel LPCM format is most compatible with all types of TVs. When the HDMI output is connected to an A/V receiver or audio processor with HDMI v1.1 or above specifications, please use the following settings: Speaker Setup Page: Down-mix: 5.1 CH Front Speaker: Large Center Speaker: Large Rear Speaker: Large Subwoofer: On Audio Setup Page: Digital Output: Raw HDMI Audio: Auto With the above settings, the DVD player will send CD, Dolby Digital and DTS audio signals as raw bit streams to the receiver for decoding. For high resolution stereo or multi-channel audio contents such as DVD-Audio and Super Audio CD, the DVD player will send multi-channel PCM audio signals with the highest available sample frequency and bit numbers to the receiver. Depending on the original audio content, the format could be 44.1kHz - 192kHz, 2 - 6 channels. Setting all speakers to "Large" allows bass management to be handled by the receiver or audio processor. Note: If you use HDMI to connect audio to an HDMI A/V receiver or audio processor, it is recommended that you choose 720p or 1080i HDMI output resolution when playing high resolution audio content (DVD-Audio and SACD). According to the HDMI specification, the bandwidth available for digital audio is proportional to the total bandwidth used by digital video. At 480i/480p/576i/576p resolution, the HDMI specification can only support 2 channels of audio with high sample rate (up to 192kHz), or 8 channels of audio with standard sample rate (up to 48kHz). Depending on the capability of your A/V receiver or audio processor, if you play high resolution audio content at 480i/480p/576i/576p resolution, you may encounter problems of incomplete audio channels or no audio/video output at all. Choosing a high HDMI output resolution such as 720p or 1080i allows enough bandwidth for all high sample rate audio channels. 2. Easier Track Skip for SACD and Digital Music Playback When playing Super Audio CD or digital music files, the "Skip Prev" (|<<) and "Skip Next" (>>|) buttons on the remote control can be used to skip to the the previous or next track. This function enables the user to skip tracks without using the navigation menu on the video screen. When playback is stopped, these buttons can still be used to turn pages for the the on screen navigation menu, just like with the previous firmware version. 3. New Default Contrast Setting for Component Video Output (Same as 1A-0613 Beta Firmware) The factory default contrast setting for component video output is slighted adjusted (tuned down to approximately -3 level of the previous firmware 1A-0526). This adjustment brings the default contrast for component video output to standard level and make it consistent with the HDMI output. The default contrast for the HDMI output is not affected. Please note that the brightness and contrast settings of your TV display also affect the final visual result. It is recommended that you calibrate the DVD player and the TV display together using a reference DVD such as The AVIA Guide to Home Theater or Digital Video Essentials. 4. Improved DVD-Audio Disc Compatibility This version resolved compatibility issue when playing certain DVD-Audio discs, such as Remain in Light by TalkingHeads (UK version) and Greendale by Neil Young & Crazy Horse. 5. Improved DivX and Xvid IDX+SUB Subtitle Support This version improved compatibility for IDX+SUB type of subtitle used by some DivX and Xvid files. It now properly displays subtitle for 2-CD split DivX and Xvid files using the IDX+SUB subtitles. 6. Enhanced Power-on Response Time The response time it takes from power-on to video playing or tray ejection is reduced by 3-4 seconds. This firmware version also improved overall stability. Download Firmware here: Oppo 970HD 0916 Original: Mver 05.00.01.07 Batch: 1A-0525 MANUAL/TIPS/FAQ: Oppo Digital's DV970HD Manuals DV-970HD User Manual DV-970HD Advanced User Manual Inaccessable Settings Certain settings are not accessible while a disc is playing or loaded. In this case, eject the disc to access the settings. Settings affected: General Page: SACD Priority DVD-Audio Mode DivX(R) VOD Audio Setup Page: HDMI Audio Preference Page (The far right box) DV-970HD SETTINGS: Default settings are utilzed, for the most part. Some suggestions:
DIRECT PLAY: To skip over the majority of warnings, promos, etc: As soon as the DVD will allow:
CHECK FIRMWARE VERSION
MAKE REGION FREE:
DEFECT/WISH LIST: 05/30/2006, in approximate order of severity: CURRENT DEFECTS:
WISHLIST: Comments welcome. Oppo Digital is committed to making ongoing product improvement. REVIEW/TEST RESULTS: Keep in mind that the display can introduce its own artifacts. It will be noted if it is thought the display is contributing to any anomaly. Basically, this is a rundown of the DVE video test patterns with certain tests from Avia included. The first description notes the test and expected results. Beneath that are the actual tested results, in italics. EQUIPMENT: Display: Panasonic TC-22LH1, Hitachi 32HDT55 Cable: Oppo supplied HDMI (Monster HDMI-> DVI) for Hitachi Discs: DVE, Avia Other: 6500K florescent light REVIEW (HDMI & Component): Forthcoming DVD COMPATIBILITY (if listed, it's "OK"):
VIDEO PERFORMANCE (HDMI & non-copy protected component): 1080i : HDMI w/Panasonic TC-22LH1 720p : Hitachi 32HDT55 480p : Panasonic TC-22LH1 480i : Panasonic TC-22LH1 SUMMARY: Blacker than Black : 1080i : Passes BTB 720p : Passes BTB 480p : Passes BTB 480i : Passes BTB Whiter than White : 1080i : Passes WTW 720p : Passes WTW 480p : Passes WTW 480i : Passes WTW Macroblock enhance : NONE at any connection or resolution Chroma Upsampling Error : 1080i : no 720p : no 480p : no 480i : no Subtitle Sync : Outstanding at all resolutions Bad Edit : 1080i : OK 720p : OK 480p : OK 480i : OK Layer Change : 1080i : *Blink* of an eye 720p : *Blink* of an eye 480p : *Blink* of an eye 480i : *Blink* of an eye Motion Adaptive Deinterlacer : 1080i : Yes 720p : Yes 480p : Yes 480i : N/A Frame/Field pause : 1080i : Field 720p : Field 480p : Field 480i : N/A 4:3 display on 16:9 (aka "pillarbox"): 1080i: Yes (with a slight penalty of reduction in resolution) 720p: Yes (with a slight penalty of reduction in resolution) 480p: Yes 480i: Yes DVE TEST PATTERN RESULTS (HDMI @ 1080i/480i): 12 - Video Test Signals, Display Setup Patterns 12.2 - DVD PLUGE w/Gray Scale - Check for BTB, uniform color w/6500k ref, uniform geometry 1080i : BTB OK, gray OK, geometry OK 480i : BTB OK, gray OK, geometry OK 12.3 - DVD PLUGE w/White - check for BTB, change in BTB bars, uniform geometry 1080i : BTB OK, gray OK, geometry OK 480i : BTB OK, gray OK, geometry OK 12.4 - Needle Pulse - mostly for CRT. Ensure vertical line does not bend (lower white level if line bends) 1080i : No problem noted 480i : No problem noted 12.5 - DVD PLUGE w/Gray & Bars - "catch all": check for BTB, black/white crush,color w/gray reference 1080i : BTB OK, no black/white crush, color OK 480i : BTB OKNo BTB, no black/white crush, color OK 12.6 - Color Bars w/Gray Reference - color check w/filter: red based colors the same, green based colors the same, blue based colors the same 1080i : Color Bars OK. No "green depression". 480i : Color Bars, OK. 12.7 - Split Bars w/Gray & DVD PLUGE - "catch all": check for BTB, black/white crush, split bars 1080i : BTB OK, no black white crush, color bars OK 480i : BTB OK, no black white crush, color bars OK 12.8 - Combination - "catch all": check for BTB, color, Y/C delay, luminance sweeps 1080i : BTB OK, color OK, no Y/C delay, luminance OK 480i : BTB OK, color OK, no Y/C delay, lumnnance OK 12.9 - 20% Window w/DVD PLUGE : the pluge should not change with the varying window brightness no bars should appear or disappear 1080i : BTB OK 480i : BTB OK 12.10 - 100% Window w/DVD PLUGE : as with 12.9 1080i : BTB OK, no fading or brightening 480i : BTB OK, no fading or brightening 12.11 - 40% Window w/DVD PLUGE : as with 12.9 1080i : as with 12.10 480i : as with 12.10 12.12 - 80% Window w/DVD PLUGE : as with 12.9 1080i : as with 12.10 480i : as with 12.10 12.13 - 20% Window w/DVD PLUGE : as with 12.9 1080i : as with 12.10 480i : as with 12.10 12.14 - Reverse Gray Ramps (with steps) - even color with ref 6500K - no black or white crush within the framing "dots" 1080i : even color with 6500K, no black/white crush 480i : even color with 6500K, no black/white crush 12.15 - Reverse Shallow Ramps - criss-crossed gray ramps. The ramps should be smooth with almost imperceptible steps. The gradation should be smooth and visible with both the top and bottom ramps. If not, crushing is taking place. 1080i : Ramps OK 480i : Ramps OK 12.16 - Ambient Light Reference - adjust 6500K backlight to match brightness, if used Not/Applicable 12.17 - 1.33 Overscan Pattern - check for overscan and edge enhancement (very much display dependent). The center cross should not be outlined by a white line on any edge. 1080i: Top 1% Bottom 0% Left 2% Right 2% No edge enhancement noted 480i: Top 3% Bottom 2% Left 2% Right 2% Some edge enhancement noted 12.18 - 1.33 Aspect Ratio & Geometry Pattern - left: all horizontal/vertical lines visible: no flashing,no banding. right: all diagonal lines visible, smooth, no flashing, no banding 1080i : Mostly OK, some banding of high freq, horizontal/vertical lines noted (may be display). Otherwise OK. 480i : Mostly OK, slight banding of high freq, horizontal/vertical lines noted (may be display). Otherwise OK. 12.19 - 1.78 Aspect Ratio & Geometry Pattern - as above with 1.78 markers 1080i : as with 12.18 480i : as with 12.18 12.20 - 1.78 Convergence & Geometry - should be centered 1080i : see 12.17 some cropping (may be display) 480i : see 12.17 some cropping (may be display) 12.21 - Video Black 13 - Video Test Signals Picture Resolution 13.2 - SMPTE RP 133 - multiple: 1. Alphabet on all sides should be complete and readable. 2. Gray blocks should be uniform in color w/reference 6500K source. Next to the 0% box there is a 0% outer and 5% inner box. The 5% inner box should be visible. Next to the 100% box there is a 100% outer and 95% inner box. The 95% inner box should be visible. If either inner box is not visible, crushing is occurring. 1080i : 1. Top row of capital letters cut off (may be display). Left "A" cropped. Right "M" cropped. 2. Inner boxes OK. 480i : 1. Top row of capital letters cut off (may be display). Left "A" cropped. Right "M" cropped 2. Inner boxes OK. 13.3 - Multiburst Vertical - all lines visible, even brightness, no banding, no flashing, no jittering. 1080i : Some banding noted with "full" (may be display), otherwise OK. 480i : very slight banding noted at "full", otherwise OK 13.4 - Multiburst, Horizontal, 0.5 to 5.75 Mhz - all lines visible, even brightness of segments, no banding no flashing, no jittering. 1080i : Even brightness, some banding noted at higher frequencies (may be display) 480i : Even brightness, very slight banding noted at higher frequencies (may be display) 13.5 - Multiburst, Horizontal, 5.75 to 6.75 Mhz - all line visible, even brightness, no banding no flashing, no jittering. If the brightness decreases, freq response is fading. If brightness increases left to right, freq response boost or edge enhancement 1080i : Even brightness, some banding noted at higher frequencies (may be display) 480i : Slight decrease in brightness, very slight banding noted at higher frequencies (may be display) 13.6 - Luminance Sweep, 0.5 to 5.75 Mhz - all lines visible, even brightness, no banding, no flashing, no jittering. 1080i : Even brightness, some banding noted at higher frequencies (may be display) 480i : Even brightness, slight banding noted at higher frequencies (may be display) 13.7 - Pb & Pr Sweep 0.25 Mhz to 2.785 Mhz - all lines visible, even brightness, no banding, no flashing, no jittering, no fading to gray 1080i : Even brightness, some banding noted at higher frequencies,some fading to gray (may be display) 480i : Even brightness, some banding noted at higher frequencies,some fading to gray (may be display) 13.8 - Video Black 14 - Video Test Signals, System Evaluation 14.2 - 20% Flat Field - even gray at 6500K 1080i : Even color gray w/6500K reference 480i : Even color gray w/6500K reference 14.3 - 40% Flat Field - as above 1080i : as with 14.2 14.4 - 60% Flat Field - as above 1080i : as with 14.2 480i : as with 14.2 14.5 - 80% Flat Field - as above 1080i : as with 14.2 480i : as with 14.2 14.6 - 100% Flat Field - as above 1080i : as with 14.2 480i : as with 14.2 14.7 - 100% Window w/PLUGE - BTB check, still OK? 1080i : BTB OK 480i : BTB OK 14.8 - Red 100% Amplitude - red, no orange tine, no other color, no noise, dead pixel check 1080i : Color good 480i : Color good 14.9 - Green 100% Amplitude - green, no other color, no noise, dead pixel check 1080i : Color good 480i : Color good 14.10 - Blue 100% Amplitude - blue, no other color, no noise, dead pixel check 1080i : Color good 480i : Color good 14.11 - Red 75% Amplitude - should be no change in color from 100% 1080i : Color good 480i : Color good 14.12 - Green 75% Amplitude - should be no change in color from 100% 1080i : Color good 480i : Color good 14.13 - Blue 75% Amplitude - should be no change in color from 100% 1080i : Color good 480i : Color good 14.14 - Cyan 75% Amplitude - check for noise 1080i : Color good 480i : Color good 14.15 - Magenta 75% Amplitude - check for noise 1080i : Color good 480i : Color good 14.16 - Yellow, 75% Amplitude - check for noise 1080i : Color good 480i : Color good 14.17 - Horizontal Color Bars 100% Saturation - check w/filters 1080i : Color good 480i : Color good 14.18 - Vertical Color Bars 100% Saturation - check w/filters 1080i : Color good 480i : Color good 14.19 - Video Black 15 - Video Test Signals, 1.33 Pattern 15.2 - Convergence, 1.33:1 Linear - pillarbox check, should be white line around entire pattern Not Applicable 15.3 - Convergence, 1.33:1 1.78 letterbox markers - same with 1.78 markers Not Applicable 15.4 - Snell & Wilcox Zone Plate Test Pattern, 2/3 rate - ideally the concentric rings should move smoothly,no breakup, no flashing, no distortion as it moves and changes direction. This tests the motion adaptive deinterlacing. In practice it is normal with a good motion adaptive deinterlacer for the concentric rings to distort for a moment, then resume good shape when redirection occurs. The diagonal lines on the left should be smooth with no jittering. If output is 480i then the motion adaptive circuitry used will be that of the TV -- if present. 480i will be more of a test of the display. 1080i : Looks OK, concentric rings motion adapted, diagonal lines fairly smooth 480i : Looks Fair, concentric rings not motion adapted (display), diagonal lines fairly smooth 15.5 - Snell & Wilcox Zone Plate Test Pattern, frame rate - as above 1080i : Concentric rings not motion adapted, diagonal lines fairly smooth 480i : Concentric rings not motion adapted (display), diagonal lines farily smooth 15.6 - Snell & Wilcox Zone Plate Test Pattern, field rate - as above 1080i : Concentric rings not motion adapted, diagonal lines fairly smooth 480i : Concentric rings not motion adapted (display), diagonal lines fairly smooth 15.7 - MPEG Decoder Test - *major* catch all test pattern: 1. diagonal lines on left smooth, no jittering 2. No banding with 4:2:0 on bottom left, it should be flashing alternate colors 3. Red and blue triangles in the center left should have smooth diagonal edges 4. Concentric blue/yellow and red/cyan circles in center upper left and right should be smooth and even brightness (aka ICP test) 5. Luminance sweeps at bottom should be even with no bleeding. 6. Rotating box in upper right should be smooth with no jaggies or combing 1080i : 1. Diagonal lines fairly smooth 2. Banding, no flashing alternate colors 3. Red and Blue Triangles have smooth diagonal edges 4. Concentric blue/yellow and red/cyan circles are smooth - passes test 5. Little bit of bleeding noted (may be display) 6. Rotating box is smooth 480i : 1. Diagonal lines fairly smooth 2. Banding present 3. Red and Blue Triangles have fairly smooth diagonal edges 4. Concentric blue/yellow and red/cyan circles are somewhat smooth - some ICP present 5. Little bit of bleeding noted (may be display) 6. Rotating box is smooth 15.8 - Black Stretch Test - check for BTB 1080i : BTB does fade a bit with this test (probably display) 480i : BTB is passed to fade/enhance 15.9 - Bounce - no geometry changes with flashing. Mainly for CRT displays. 1080i : No problems noted 480i : No problems noted 15.10 - Video Black 16 - Video Test Signals, 1.78 Pattern 16.2 - Snell & Wilcox Zone Plate Test Pattern, 2/3 rate - as with 15.4 1080i : Looks OK, concentric rings motion adapted -- maybe a bit slow to lock, diagonal lines fairly smooth 480i : Looks Fair, concentric rings not motion adapted (display), diagonal lines fairly smooth 16.3 - Snell & Wilcox Zone Plate Test Pattern, frame rate - as with 15.4 1080i : Concentric rings not motion adapted, diagonal lines fairly smooth 480i : Concentric rings not motion adapted, diagonal lines fairly smooth 16.4 - Snell & Wilcox Zone Plate Test Pattern, field rate - as with 15.4 1080i : Concentric rings not motion adapted, diagonal lines fairly smooth 480i : Concentric rings not motion adapted, diagonal lines fairly smooth 16.5 - A/V Timing Clock - color ramps w/flashing white bar on top. The colors should be smooth and the flashing white bar should coincide with the tone. 1080i : Colors mostly smooth, timing OK. Perfect Av Sync 480i : Colors mostly smooth, timing OK. Perfect AV Sync AVIA (selected) TEST PATTERN RESULTS (HDMI @ 1080i): Color Decoder - primary colors should be at 0% with reference to background gray 1080i : Colors OK when adjusted, no green depression noted. 480i : Colors OK when adjusted, no green depression noted. Y/C Delay - primary colors should match up with gray box below at 0.00. Keep in mind that this test is only a rough estimate. 1080i: Blue : -0.00 Red : -0.00 Green : -0:00 480i : Blue : 0.00 Red : 0.00 Green : 0.00 Moving Zone Plate - Concentric and diagonal lines should retain shape and detail upon movement 1080i : Fair, lots of breakup, diagonal lines hold together a bit. Pixel Crop (4:3) - Should be no pixels cropped from sides or top. Highly display dependent. [i]1080i: TOP : 0 BOTTOM : 0 LEFT : 0 RIGHT : 0 [i]480i : (any cropping is probably my display) TOP : 10 BOTTOM : 10 LEFT : 0 RIGHT : 0 Thank you: Oppo Digital Paul Last edited by Paul Bigelow; 09-30-06 at 12:43 AM.. |
#2 | Link |
Damn your placeholder! I want information now. Giddy mow!
OPPO sent this along to me to post: OPPO DV-970HD Universal DVD Player With HDMI Output and High Definition Up-Conversion FEATURES: Universal DVD Player Features: • Superior compatibility with DVD-Video, DVD-Audio, Super Audio CD (SACD), Certified DivX, Xvid, Audio CD, HDCD, Kodak Picture CD and other digital audio and video media/formats • Plays DivX® 5, DivX® 4, DivX® 3, and DivX® VOD video content (in compliance with DivX Certified™ technical requirements) • Plays XviD and .SRT, .SMI, .IDX and .SUB format Video Up-Conversion Features: • High definition up-conversion with film-like picture quality to up-convert 720x480 interlaced video encoded on DVD discs to 480p/720p/1080i • High-quality pure digital video and audio through a single HDMI (High Definition Multimedia Interface) cable • Multiple high definition video formats through HDMI and component outputs*: NTSC: 480i/480p/720p/1080i; PAL: 576i/576p/720p/1080i (* Component output for CSS-encrypted DVD discs (almost all commercially pressed DVD discs) is limited to 480i/480p only.) • Compatible with HDTV, HD-Ready TV, HDTV monitors and projectors Optimized Audio Features: • Optimized analog audio circuitry for great audio quality • Built-in Dolby Digital decoder with individual 5.1ch and down-mixed stereo outputs • Optical and coaxial digital audio outputs for Dolby Digital, DTS and Linear PCM • Unique “Audio Only” mode with video processing turned off for perfect acoustic fidelity • 3D Surround (Virtual Surround): Concert, Live, Dance, Techno, Classic, Soft • Built-in equalizer, channel trim and channel delay functions Compatibility Features: • PAL/NTSC disc and TV compatible with automatic or manual system conversion • Compatible with CD-R/RW, DVD±R/RW and DVD+R DL* (* Playability of self-recorded discs may vary depending on media and formatting software types) • Enhanced dual-layer disc support with fast layer change • Wide range universal power supply (~100V-240V, 50/60Hz AC) Standard Video Features: • Progressive scan component outputs (YPbPr) • Composite video and S-Video outputs for standard TVs • Supports screen aspect ratio 4:3 (standard) and 16:9 (wide-screen) • User adjustable video controls: Sharpness, Contrast, Brightness, Saturation, Hue and Gamma • Multi-angle view Convenience Features: • 4-in-1 flash memory card reader compatible with Memory Stick, Secure Digital, Multi-Media Card, and SmartMedia (MS/SD/MMC/SM) • USB interface for expanded connectivity • Smooth and easy navigation of photo albums, music collections and video files on DVD, CD, flash memory cards and USB disks. • Selectable subtitle and audio tracks Connectors: • HDMI - High Definition Multimedia Interface: 1 • Component Video (YPbPr/YCbCr): 1 group (3 connectors) • Analog Stereo Audio (Mixed 2-Channel Left/Right): 1 group (2 connectors) • Analog 5.1 Channel Audio: 1 group (6 connectors) • S/PDIF (IEC-958) Coaxial Digital Audio: 1 • S/PDIF (IEC-958) Optical Digital Audio: 1 • Composite Video: 1 • S-Video: 1 Accessories Included: • High-quality certified HDMI cable with ferrite core and gold-plated HDMI connectors • Remote control with "glow in the dark" keypad (batteries included) • Stereo audio cable • Composite video cable • User manual and warranty information SPECIFICATIONS: (Designs and specifications are subject to change without notice.) Disc Types*: • DVD-Video, DVD-Audio, Super Audio CD (SACD), Certified DivX, Xvid, Audio CD, HDCD, Kodak Picture CD • DivX (DivX Certified Home Theater Profile Parameters, V2.2. Covers DivX 3.11 – 5.1) • CD-R/RW, DVD±R/RW, DVD+R DL • * Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used. Output: • Analog Audio: Stereo, 5.1ch • Digital Audio: Coaxial, Optical, HDMI • Analog Video: Composite, S-Video (Y/C) • Component Video**: Y/Pb/Pr, NTSC 480i/480p/720p/1080i, PAL 576i/576p/720p/1080i • Digital Video: HDMI with HDCP (NTSC 480i/480p/720p/1080i, PAL 576i/576p/720p/1080i) • ** Component output for CSS-encrypted DVD discs (almost all commercially pressed DVD discs) is limited to 480i/480p only. Video Characteristics: • Composite Video Amplitude: 1.0Vp-p (75Ω) • S-Video Amplitude: Y: 1.0Vp-p (75Ω), C: 0.286Vp-p (75Ω) • Component Video: Y: 1.0Vp-p (75Ω), Pb/Pr: 0.7Vp-p (75Ω) • HDMI: HDMI Specifications 1.1, CEA-861-B Audio Characteristics***: • Frequency: 20Hz – 20kHz (±1dB) • Signal-to-Noise Ratio: >100dB • Total Harmonic Distortion: < 0.01% • *** Nominal specification. General Specification: • Power Supply: ~ 100V – 240V, 50/60Hz AC • Power Consumption: 14W • Dimensions: 420mm x 255mm x 41mm, 16-1/2 x 10 x 1-5/8 inches • Mass: 2.2kg / 4.85 lbs (DVD player unit only) Operating Temperature: • 5°C - 35°C • 41°F - 95°F Operating Humidity: • 15% - 75% No condensation Firmware Updates: • Upgradeable via CD-ROM Last edited by Neuromancer; 05-30-06 at 06:01 PM.. |
#4 | Link |
Oppo DV-970HD at 1080i versus Samsung DVD-HD960 at 1080p--which is better?
There will probably be many more of these questions and many times it will depend upon the processing of the 1080p accepting set versus the processing of the various players and which will work better with each in each situation. Maybe in the future there will be a sticky giving a consensus as to which Upconverting DVD player is best with various sets and resolutions. Until then look for many "Which is best--the DVD player feeding versus the TV set converting?" |
#5 | Link | |
Artwood,
I messed with the DVD-HD960 for a while and could not get a good picture out of it that did not involve some ghosting (even at "1" - the lowest setting - the unit ghosts). It turned my plasma into a DLP! I don't have a 1080p display, so I can't comment on how well designed the 1080p output is. |
#8 | Link |
New OPPO Release Date?
Wild Horses Couldn't Drag Me Away from an OPPO player with DVD-A/SACD and HDMI. Any ideas what the release date is? Are they using the same chipset/scaler as 971H? I'm going to be looking for a new player sometime in July. Any ideas about the selling price? Thanks for the informative posts.
#12 | Link | |
The DV970HD does all of its deinterlacing and scaling through a Mediatek chipset combo: the 1389EE and 1392. The 1389EE (also utilized in the OPDV971H) does all of the hardware decoding and analog audio DAC support. The Mediatek 1392 does the scaling and HDMI transmission, as well as analog video DAC. The DV970HD does not have the Faroudja chipset. |
#15 | Link | |
Interesting, it's got a USB port. Will it support external hard drives? Fat32? NTFS formatted drives? DVD ISO files from hard drive?
Do we know the hack/code to enable component upconversion for protected DVD content? Or do we need a modified firmware in order to enable this?
__________________
But in my own way, I am King. Hail to the King, baby. My Networked Media/Music/DVD Server |
#19 | Link |
New webpage is updating. The official page for the DV970HD will be: http://www.oppodigital.com/dv970hd/dv970hd.html
They are updating the website, so most of it is not accessible at the moment. |
#20 | Link | ||
ISO images will not load, as they are not recognized by the MTK Explorer. Though VOBs may work. Will have to try. Quote:
#21 | Link |
Paul and others,
How does 970 compare to your other DVD players (in any price range) in terms of color rendition, black richness, sharpness, detail, etc. In other words, the "non-scientific" stuff? I'm considering this player or the Sony 3100ES as my last standard DVD player until I jump into HD next year. I have a well calibrated, ISF'd Sony CRT RPTV (KP-57WS520). I've demo'd or owned a good number of players at one time or another (Denon 3910, Sony 3100ES/9100ES, Panasonic XP-30, Sony H75, etc.). I even tried the Oppo 971 but found the image too soft for my display. I would use the 970 primarely for component 480p.......and maybe once in a while upscale it via HDMI to 1080i. |
#22 | Link |
User Manual (included in box)
Advanced User Manul (Online only for now) created by AudioHolics as a procedual manual for setting up the DV970HD, as well as explaining functionality indepth. |
#23 | Link | |
AVS CLUB MEMBER
Will "pillarbox" 4:3 material with a slight penalty in 4:3 resolution? What is the slight penalty and how does it manifest? |
#25 | Link | |
AVS CLUB MEMBER
At first glance I'm glad to see it has 5.1ch analog outputs for DVD-Audio, unlike the new Panny 52S and LG191 which do DVD-Audio only over HDMI and they've nixed the 5.1ch analog outputs. Plus, its good to see that Oppo haven't cheaped out by eliminating either the digital coax or digital optical outputs and have thoughtfully provided both. Its also good to see an Open/Close button on the remote and TV volume control buttons (though its unusual to see them side by side instead of vertically oriented). |
#26 | Link | ||
This is what Josh Z said about Pillarboxing on the OPDV971H Braindump Forum Quote:
#29 | Link | |
AVS Moderator
AVS GOLD CLUB MEMBER
No big deal for me since I would only use 480i or 480p. Is there something I missed.? Previously I was thinking that it would be a dream come true for some folks.larry
__________________
Beauty is in the eye of the beer holder. Help Support AVS Forum Advertisers <click to see them> |
#30 | Link | |
Yeah! Oppo added discrete on/off support for the 970.
http://www.oppodigital.com/dv970hd/dv970hd_faq.html#A5 I created a JP1 upgrade file here (for OneForAll, Radio Shack, etc. JP1-capable remotes): http://www.hifi-remote.com/forums/dl...e&file_id=3284 These codes were created for the Oppo Digital DV-970HD upconverting HDMI DVD player. All original functions of OEM remote are included, including some extra functions not on the original remote. Following functions *not* included on the OEM have been added: discrete on/off pause/step sound field equalizer multi-channel downmix dd dual mono -- Oppo DV-970HD does not support saving playback location automatically upon power shutdown. I was able to simulate this functionality by redefining my Power Toggle and Discrete Off IR functions on my remote to be macros "Memory + Power Toggle" and "Memory + Discrete Off" |
| Bookmarks |
| Thread Tools | |
