#1 | Link |
VX10 or VrP-1000
Hello all,
I am a novice when it comes to subwoofers so I need a little advice. My piece of poop Sony sub (finally) died the other night. I dont wanna spend a lot of money on the sub (around $200) so i've been looking at the Velodyne VX10 and the Velodyne VRP-1000. It seems like the VRP is about $70 more than the VX10. Is there a big difference between the two models??? I am using an Onkyo 803 receiver and have Polk RTI 8s in the front with RTI 6s in the back. Oh..and my room is approximately 12 X 18. Thanks! |
#2 | Link |
Same sub different finish. Don't be concerned about the slight differences in the advertised specifications. If you don't mind the vinyl veneer the VX10, which is often sold as a loss leader, (check out 6th AVE Electronics on line for pricing) is a better deal. I have used this sub and it offers a very good bang for the buck in smaller rooms.
Ian
__________________
BOOMER McLOUD XTREME CAR AUDIO |
#5 | Link | |
Having owned a VRP-1000 for about 3 weeks before returning it, I would say that you are better off looking elsewhere. In keeping under $300, I would suggest checking out the Acoustech H-100 or Onix X-Sub instead. Each would give you better extension and sound quality in this price range.
I'm sure either of the Velodynes that you have listed would sound a world better than the Sony that you're replacing, but there are definitely better options for the money. Personally, I traded the VRP-1000 on an Infinity PS-12, which was a MUCH better sub, and I then traded that sub in when I picked up a Mirage S12. |
#6 | Link |
Just to put things in perspective, with proper set up the VRP subs are very capable performers. On the Home Theater Forum they compared the VRP 1200 to the Infinity PS12. Although the infinity slightly edged out the less expensive Velo in over all output, the Velo received a better bang for the buck in the review. I have compared the 12 and the 10 and in smaller rooms (under 2000 cu ft) they are very close.
Ian
__________________
#7 | Link |
I like speakers!
A link to that review can be found here http://www.hometheatershack.com/foru...ontenders.html
__________________
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW! -Rob My Natalie P project |
#9 | Link | |
To refer back to that particular article, the Velo was a better value when compared to the Infinity's list price of $449.99; however, it is not difficult to find the PS-12 on sale at prices less than the VRP-1200. Right now, you can get the Infinity shipped from Vanns for just under $300. Considering that the PS-12>VRP-1200>VRP-1000, it should also be considered at this price point. |
#10 | Link | |
I'm not a reviewer.. I just used it as a everyday consumer. The VPR-1000 cost me around $265 with tax.. Then I bought a H100 for around the same price with a 12 inch woofer. It killed the vpr 1000 by a mile. Of course this is just my opinion.. But I wouldn't wish the vpr1000 on my worst enemy.. Maybe if the vpr1000 10 inch cost $100 it would be a different story.. |
#11 | Link | |
The problem with the VRP subs is that the input sensitivity is fairly low and this can effect their performance capability.
offers a lot of value for those with smaller HT rooms and will compete with any sub in the $200.00 +/- price club. Ian
__________________
BOOMER McLOUD XTREME CAR AUDIO Last edited by mailiang; 06-14-06 at 11:27 PM.. Reason: typo |
#12 | Link |
Thanks for all your help guys. I ordered the Accoustech H-100 yesterday for $214 shipped. It ended up costing only $45 more than the velodyne VX10....it sounds like either would've been a big improvement over my sony but everyone seems to really rave about the Accoustech. I hope it arrives soon...I really miss my bass!!! Again, thanks for your help!
#13 | Link | |
I have a friend that is in the process of putting together a system on a tight budget, and I would like to pass this information along. rel |
#16 | Link |
Hillbilly The Wise
I just returned the Infinity PS 12 and re-bought the VRP 1200. The Infinity was nice but after a week of having it the thing would start crackling during any powerful LFE scene in a movie. And it wasn't distortion or boominess, the cracking sound was coming from the physical part of the sub. It sounded like it was going to break. To me that was too noticeable during movies to keep so I gave the VRP 1200 another shot. With mailiang's great set up advice, it is working great! With having owned both the Infinity PS 12 and the Velo VRP 1200, I can tell you for certain that the VRP 1200 can hang with the PS 12 any day of the week when it is tweaked the right way. And, JMO, but I think the Velo is built a lot better than the Infinity was. I did like the Infinity, however, and my home theater speakers are Infinity Primus but when it comes to subs I will take the Velodyne. BTW, Happy Father's Day all AVS Fathers!
Good luck... <>< |
#17 | Link | |
#19 | Link | |
New Member
Help
#21 | Link | |
New Member
Would you be kind enough to send me the detailed setup tips for the VRP-1200 as well. I just picked up a unit today and would be interested in any advice. Thanks. |
#22 | Link | |
I sent you a PM. If you follow my instructions you will find that these subs have a lot of potential. Proper placement and set up can make a world of difference. Enjoy! Ian
__________________
#24 | Link | |
I spoke to Curt C. from Velodyne the other day and he thanked me for advising members on my Velo VRP set up routine. He gets a lot of questions and PM's from the Velo support thread and I'm helping him reduce his work load! If you PM me I will send you my recommendations. $170.00 for a VRP1200! Not a bad deal? Thats a #*#*#* of a deal!Ian ![]()
__________________
#27 | Link |
Ive been trying for 1/2hr to get this friggin PM thing working and it just wont let me turn it on in my options. After I check it and save changes it keeps saying to log in or I dont have access.
If you can, just email me the setup info to mikeandlisaf@canada.com thanks. |
| Bookmarks |
| Thread Tools | |
