#1 | Link |
Zenith DVB612 - anyone know about it?
I just bought a Zenith DVB612 upscaling DVD Player for $80 from Brandsmartusa, and was wondering if anyone has any experience with it. The only information I found online was on Zenith's website:
http://www.zenith.com/index.asp?url=...asp%3Fcat%3D15 It looks good so far, but I haven't had much of a chance to test it out yet. (I'll post an update in a while) Thanks, -Jonathan. Last edited by JLanguage; 06-22-06 at 05:17 PM.. |
#4 | Link |
New Member
Jonathan, do know if this player will do 1080i video via the component outputs. The user manual lists "progressive" as the video output, but on the back of the player, next to the component outputs, is printed "1080i 720p 480p" . I know the zenith 318 DVD player could do 1080i via the coponent outputs, so I'm hoping it can be done with this player. Thanks, Mike.
#8 | Link |
New Member
I have owned a DVB-612 since September. It is a decent low cost upconvert player, not a lot of bells & whistles. It started to pause for a couple of seconds randomly, mainly on DVD-R's. but started on store bought DVDs also. I checked the problem DVD's on another player, no pausing. I called Zenith, they said they would do a swap, since it was under the 90 warranty. About a week later I called Zenith, the player was on the tech's bench waiting to be repaired. I was originally told it was going to be a swap with a replacement player. After a couple of days not getting a straight answer, I was told they were out of replacement units & that my player was not repairable. Then I got a phone call, saying a unit was shipped & will be here today. We'll see what shows up.
#10 | Link | |
New Member
I just bought one from CC for $39.99 (after rebate) and connected it to my Vizio 42" plasma via HDMI. So far it is doing fine, but with my limited time on it, this is what I have found:
It does 1080i, 720p and 480p through HDMI and component. It did play DVD-R and DVD+R disks made using Nerovision 4. It did not play DVD+RW disk made through Nero, but did play DVD+RW made on Cyberhome recorder. It did not play VCDs. Divx files on DVD-R did play fine. Overall it is a good player so far with lots of nice features for the price. |
#11 | Link | |
#12 | Link |
How much improvement would I see in going to this HDMI unit with a 42" Spectre LCD over an old progressive scan player, versus how much between the Zenith and better HDMI units?
If I'd see most of the benefit just in going frm progressive scan component cables to HDMI, it's temping to spend $45 rather than sweat a really nice player for now. |
#13 | Link | |
New Member
#14 | Link |
Plug and Pray
I bought this as well and it does great with HDMI 480p/720p/1080i. It can't do 480i via HDMI. It can do 480i/480p/720p/1080i on component (720p or 1080i requires no copy protection--ripped DVD-R and burnt Divx are fine). It has Svideo and yellow RCA composite. It has optical and coaxial digital. It sends DD/DTS through SPDIF digital connectors and HDMI. Since my plasma can't handle bitstream through HDMI (high pitch, squealing, morse code type sound on bitstream), I had to use PCM mode which sounds great (2 channel stereo). I can send the DTS/DD through its SPDIF digital connectors to my receiver of course (I must switch the HDMI audio of my plasma to analog audio mode to avoid this squealing, incompatible sound through the plasma while using bitstream mode for DD and DTS).
I need to open it up to see what the MPEG decoder and scaling chipset is. It's not likely DCDi as it failed flag wave test pattern on Video Essential DVD. No macroblocking on my plasma. No scaling issues on 720p or 1080i (plasma is 1024X768 so 720p should be best but 1080i looks identical to 720p for me). Remote is generic but functional (needs direct pointing to work (no bouncing off screen). There is no adjustment of video (contrast, brightness, sharpness, etc.) unlike my Samsung 755. It has blue menu background wtih Zenith logo. It's thinner than my Samsung and very sleek looking. You must have the DVD player in stop mode to switch resolution (disc can be in drive). It shows the resolution on the light blue LCD display on front of player. There is no bright lights to distract you in the dark. The front is thin, glossy black bezel with only a circular area of buttons (power and eject buttons are on top of the player). The loader is kinda flimsy and very thin (2-3 mm thick) but durable and can bend. Loads DVD smooth and fast. Loader is very quiet compared to my Samsung 755, Zenith DVB-318 (DCDi). There is no obvious black or white crush on my plasma using Video Essential. It does not come with HDMI cable so you need to buy one (Monoprice is very, very reasonable and great quality with ferrite connectors). It does not come with component cable so need one if you use it. It has 90D labor and 1 year warranty. $60 through website with $20 rebate making net of $40 which is awesome deal. $80 in CC store (I picked it up even though ordered and paid for on line)--they will not match their website but will order it for you through their website in the store--at least at my store in Clarksville, IN.
__________________
Huey ;-] Last edited by Huey; 11-28-06 at 04:07 PM.. |
#17 | Link |
Plug and Pray
This budget Zenith is not DCDi so doubtful will be much different from other upconverting players. It should be better than a non-upconverting, progressive only DVD player, provided your TV is digital like plasma or LCD. CRT TV's don't see as much an improvement as digital TV's. 30" won't see a huge improvement over bigger displays (mine is 42" plasma and 120" FPTV).
__________________
Huey ;-] |
#18 | Link | |
AVS CLUB MEMBER
You've had the 318. How do they compare at 1080i over component? Not having DCDi isn't that big a deal anymore. That's two years old and Genesis/Faroudja hasn't bothered to fix the ##$%@ macroblocking "feature". |
#19 | Link |
New Member
It appears that this Zenith unit is identical to LG DN191H with a few features missing. There is an active AVS thread on that unit with people discussing their experience. According to that thread, this unit may be using Zoran 888 chipset.
http://www.avsforum.com/avs-vb/showt...1&page=1&pp=30 |
#20 | Link |
Plug and Pray
Zenith DVB318 does component 1080i on ANY DVDs while this one only does 1080i component on ripped DVD-R or non-copyrighted DVDs. I'll have to burn 2 copies of DVD-R of the same movie to compare the 2 component 1080i. HDMI on DVB612 1080i is sharper than component 1080i of DVB318 (expected due to digital over analog). I suspect it's very difficult to beat 1080i component of Zenith DVB318. Hopefully there'll be a hack for component 1080i on all DVDs for DVB612. The only time I miss DCDi is when watching video based DVDs and flag waving test patterns
__________________
Huey ;-] |
#21 | Link |
Plug and Pray
I opened the Zenith DVB612 and it uses Zoran 888 all-in-one scaling/decoding chip. I also compared the 1080i component of Zenith DVB318 (FLI2301 or DCDi/Faroudja) vs. 1080i HDMI. Guess what, Zenith DVB318 via 1080i component looks better (sharper, better colors, smoother, less noise using generic 6 foot component cable from Wallyworld) than Zenith DVB612 1080i HDMI (cable by Monoprice, 6 foot, gold plated with ferrite cores at each end). Movie tested was Starwars Episode 2 as I own duplicate of these. Thus, Faroudja still wins on my new 720p DLP projector (Mits HC1000u). HTPC via DVI->HDMI with same movie is the same as the 1080i Zenith DVB318 via component which is very nice imagery.
When using my 37" Panasonic plasma the 1080i HDMI of DVB612 was sharper than DVB318 via 1080i component. This shows that variation of sources will occur between differing displays so you must test both ways to know which you'd prefer.
__________________
Huey ;-] |
#24 | Link |
My experience shows extremely pure quality when the source material is dark. This shows up as bad pixellation and/or lousy dithering. The dark part of the picture looks like negative film. This shows up via HDMI cable and is visible at all resolutions. For some reason, the component video will not sync with my Pioneer 104 -> InFocus 4805 at anything but 480i. The picture looks fine at 480i via component out.
I am not sure if exchanging this for another will fix it. - Vikas |
#25 | Link | |
#26 | Link |
4:3 Materials Through HDMI
Anybody tried to play 4:3 DVDs through HDMI on this DVB612?
I got one from CC 2 weeks ago, while the picture quality is acceptable, I'm unable to play 4:3 DVDs in their original 4:3 ratio through HDMI. I tried to play 4:3 DVDs like Seinfeld and Friends through HDMI on my SONY 40" Widescreen LCD, it always extends the 4:3 into full 16:9 screen... There is no option to change screen ratio on TV when using HDMI input, and I tried to change TV screen format on DVB612, but no matter how I change, the picture is always extended to 16:9 ratio.
__________________
ToLive |
#28 | Link | |
yeah, I just read the LG-DN191H thread, same issue there. Well, a bit disappointment, but I think I got what I paid for, anyway I can still use my HTPC to play those 4:3 ratio DVDs for now, hopefully Zenith would release a new firmware sometime later... Quote:
__________________
ToLive |
#29 | Link |
I have this player, and am having an issue. For some reason, i get a horrible squealing effect through the HDMI audio connection; even the TV's Audio optical out passes it on, so i assume it is from the source. When i use my receiver (and mute the TV) the audio is fine. I think i am going to take back the player tomorrow, but i want to make sure there isn't anything i should check first..
#30 | Link | |
Plug and Pray
Why not hook the player's optical out directly to the receiver which will disable HDMI audio pass through? Sounds like your TV does not like the pass through of the SPDIF signal. Some TV has option of digital or analogue audio for the HDMI. You could chose analog to disable the audio pass through and hook the DVD player directly into the receiver. This will avoid having to mute the TV.
__________________
Huey ;-] Last edited by Huey; 12-19-06 at 08:41 PM.. |
| Bookmarks |
| Thread Tools | |
