AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 07-03-06, 05:37 PM   #1   |  Link
DanXP
twc urc ur5-8400 adding new ir code
i just got a new 8300hd dvr from time warner and i've been trying to figure out how to upgrade the codes so that it operates my ht system... i searched these forums but cannot find an answer...
i went to the universal remote website and found the software to do the "upgrade", but i do not have the accompanying hardware... do i need a cable of some sort that connects to those pins under the battery cover?
i saw on some other thread that a jp1 cable is required... but i think that's for the 'one for all' or 'radio shack' remotes... the 8400 is urc...
i called time warner and they told me to turn to the remotes channel and follow the instructions there... i already did that and it didn't work... knew it wouldn't...
all i need is for the power button to work so i could turn on/off my whole system with one button on one remote instead of two...
i sent in my last remote (for non-dvr) to universal remote and they programmed the code into the remote, but i was without both my remotes for three weeks...
thanks for any advice.
DanXP is offline   Reply With Quote
Old 01-23-07, 09:05 PM   #2   |  Link
moody03svt
New Member
I also would like to know about this! I am interested in controlling my xbox 360 with this remote using the Media Center PC IR code which I dont think comes installed on the remote's original software
moody03svt is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09438396 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
