#1 | Link |
SciFiJoe
Help!! Dead JVC DVHS
I have a JVC HM-DSR100DU (model # off the Dish bar code on the back of the unit) or JVC HM-DSR100U (model # off a sticker in the back of the unit). The power supply crapped out the other day
and I was wondering if anyone here knows where I can buy a replacement PS. I don't want to pay $$$ for a new unit but I would like to fix the one I have. TIA PS: Sorry if this is the wrong forum, not sure where to post this. |
#2 | Link |
www.jvcservice.com is the JVC parts source for consumers. They'll probably have what you need. You have to know part numbers to get anywhere on the site, so download a service manual from one of the many internet sources. Probably be $200 by the time your done so... ? Sorry, don't know about any cheaper solutions.
__________________
-Roger |
#3 | Link |
New Member
Same problem here, but on a HM-DH40000U.
It died before my very eyes... The display was flickering and then nothing. This is the 3rd time it has died now, and I think it's time to make it a book end. Pretty sad, considering the cost of this thing, and the lack of a typical Hi-Def input. Any luck with finding the power supply? If so, did it work? Thanks- Carl |
#5 | Link | |
My 30000 died because I unplugged without 1st ejecting. Tape had to be extracted forcefully (eeek!). When plugged in, rear fan comes on for a second or two, but no front panel lights come on. Checked fuse, and everything. Its sad, since all I need the unit for now is as a decoder (to help enable 169Time recordings to my HDD.
| Bookmarks |
| Thread Tools | |
