AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Subwoofers, Bass, and Transducers
Forum Jump
Old 07-10-06, 04:06 PM   #1   |  Link
stevenkapoor
Martin Logan Dynamo vs HSU STF2
Any expereinces with ML dynamo? This is available at costco($450). If money is not a concern, which one do you guys recommend. Specs look the same except the design (sealed).
stevenkapoor is offline   Reply With Quote
Old 07-10-06, 04:10 PM   #2   |  Link
stevenkapoor
I read this one on ML website.
Although ports are a convenient and cost-effective way of increasing low-frequency output, they rely on resonant energy in a way that impairs bass quality. A good sealed system will exhibit less transient-blurring group delay while maintaining smooth, consistent response regardless of output level or voice-coil temperature. Listen carefully to the sound of a bass drum, and you'll hear the difference.
Is it true?
Old 07-10-06, 09:33 PM   #3   |  Link
The13thGryphon
This is just my opinion... YMMV... but I do think that on the whole sealed subs (acoustic suspension) are cleaner and tighter, and are therefore better for music reinforcement. They seem to be "faster" -- at least they keep up with my planar magnetic speakers better -- and are more pitch accurate.
However, for most movies, where lots of slam, bam, boom, shaking, rattling, and otherwise just making very loud sounds such as car crashes and explosions, then a ported or slot loaded or passive radiator sub will very often give you higher SPL's and lower frequencies for less money.
Personally, I like the accuracy of the sealed subs -- such as those from ACI, Onyx, Velodyne, Vandersteen, and Martin Logan (to name a few)... but that's my preference, not necessarily everyone's.
__________________
"The difference between a smart person and a wise person is that a smart person knows what to say, and a wise person knows whether or not to say it."
The13thGryphon is offline   Reply With Quote
Old 07-11-06, 12:57 AM   #4   |  Link
stevenkapoor
It's final guys..I just bought the sub also.
So here is my HT
1. Onkyo 602
2. Hsu VT12
3. Martin Logan Dynamo.
I will write the reviews soon.
Thanks for all your help.
Old 07-11-06, 02:11 AM   #5   |  Link
UNICRON-WMD
Is it true?
Funny, because a lot of their speakers are ported
UNICRON-WMD is offline   Reply With Quote
Old 07-11-06, 04:29 PM   #6   |  Link
Anthony A.
which ones are you referring to? i own ml speakers and they are not ported. they use electrostatic panels and their woofers are sealed. ???
Anthony A. is offline   Reply With Quote
Old 07-11-06, 06:31 PM   #7   |  Link
xcjago
Terminal Upgraditis
Martin Logan Vignettes and Frescos are ported.
xcjago is offline   Reply With Quote
Old 07-11-06, 06:46 PM   #8   |  Link
flooger
New Member
Did you see this in a CostCo warehouse, or on the website? Curious if I need to make a special trip to the local CostCo
flooger is offline   Reply With Quote
Old 07-11-06, 08:23 PM   #9   |  Link
stevenkapoor
It's only online. I can return that to any warehouse though.
Old 02-09-07, 02:53 PM   #10   |  Link
avsuser2007
i don't see this online in costco
avsuser2007 is offline   Reply With Quote
Old 02-09-07, 03:21 PM   #11   |  Link
jaegertc
I checked on the costco website recently as well and you are right, they aren't there, but the OP on this was from more than six months ago, so they probably don't carry them anymore?
jaegertc is offline   Reply With Quote
Old 02-09-07, 06:03 PM   #12   |  Link
Forceflow
Uppity
this is basically the same speaker. So 1 speaker type out of how many?
__________________
***Warning*** Do not look into laser with remaining eye!!
Forceflow is offline   Reply With Quote
Old 02-20-07, 06:49 PM   #13   |  Link
rdad
That costcos and MartinLogan relationship was a fleeting experiment.
This is what MartinLogan had to say about it:
http://www.cepro.com/news/editorial/14089.html
And here are some theories (by Hi-Fi dealers) as to what was actually going on. Funny read. Make sure to read down to "2nd Rick's" post. Also gives you an idea on the high dealer mark ups on your favorite speakers.
http://www.remotecentral.com/cgi-bin...ead.cgi?9025,1
rdad is offline   Reply With Quote
Old 02-21-07, 12:08 AM   #14   |  Link
xcjago
Terminal Upgraditis
Actually it's two different speakers. The Mosaics are ported as are the Montage. The Claritys, Vistas, and Vantage are all bass reflex, in other words, ported.
So that makes seven models that are ported.
Old 02-21-07, 10:06 AM   #15   |  Link
John F. Palacio
Video Engineer
Is it true?
What were you thinking when you picked yellow for a font color?
__________________
"Information is only as good as the accuracy of the source"
John F. Palacio is offline   Reply With Quote
Old 02-22-07, 05:23 PM   #16   |  Link
Johnny6722
I would love to know more about the ML Dynamo, if we can get this thread back on track. Costo policies, ported ML speakers, and font colors while absolutely fascinating don't tell any anything about the topic at hand.
Does anyone have any good first hand knowledge to share on the ML Dynamo?
Johnny6722 is offline   Reply With Quote
Old 02-23-07, 12:21 AM   #17   |  Link
swllz
Here is the test result of Dynamo by Tom Nousaine of S&V,
bass limit is 78db at 25Hz, average spl is 95 db from 25-62Hz
Same test for STF-1, bass limit is 75 at 20hz, average spl is 101db from 25-62Hz.
Output from One STF-1 is more than TWO of Dynamo. According to Hsu, output from one STF-2 is more that two of STF-1.
swllz is offline   Reply With Quote
Old 02-23-07, 09:48 AM   #18   |  Link
rockemsockem
Here is a more lengthy thread about the Dynamo:
http://www.avsforum.com/avs-vb/showthread.php?t=756186
__________________
Rockem's Home Theater
rockemsockem is offline   Reply With Quote
Old 02-23-07, 10:19 AM   #19   |  Link
Johnny6722
Do you have a link to this?
Old 02-23-07, 10:55 AM   #20   |  Link
swllz
One of the link is here
http://members.cox.net/fabulousfrankie/Nousaine.htm
You have to dig from previous issues of S&V to get the whole review.
Old 02-23-07, 01:20 PM   #21   |  Link
Johnny6722
Thank you.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.23611307 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
