#1 | Link |
Chosing a remote (Harmony vs Universal)
I'm moving a budding remote control discussion from my theater thread to this area. That thread lists my equipment, but I will also be adding a media PC (probably Windows MCE) and PVR.
I've recently completed my home theater and am ready to purchase a universal remote. Here's what I want:
So after reading reviews and forum posts I was ready to go to a local store and pay $199 CDN for a Harmony 880. Then I read this reply in my thread: Quote:
#2 | Link |
I'm not sure what MX you'd be pushed to... but the MX-700 sure looks neat.
I do have a harmony 880 and love it. There are a couple downsides but over all it is minor. I had no problems setting up "Watch TV" and "Watch DVD" buttons and I have a reasonably complex setup. I have nothing, however; to control my lights. Looking at some of the Lutron offerings I wouldn't imagine there would be an issue with the harmony doing this either. Downsides to consider with the Harmony: 1) LCD Screen is difficult to organize. Items are grouped by devices. I've been petitioning Harmony to change this... I don't get the indication this is a technical issue 2) Hard to navigate by touch. I'm getting used to it but the buttons are close together and smooth. Other than those minor things I love it. If they fix my #1 I would really never feel the need to see if there is another remote. Also, the 880 can be obtained well below its MSRP. |
#3 | Link | |
Thanks ![]() |
#4 | Link |
The Guy
The MX-700 is a great remote, but for the most part has been replaced by the MX-850 which has better feel to the cursor controls in the center of the remote and has much better backlighting. It also offers the opportunity to upgrade to RF control if need be.
I have programmed hundreds of MX remotes and these remotes are a great choice for many applications. I have nothing against the Harmony's. They work well, they're a great idea, but I've recently gotten new clients whose previous installers had chosen Harmony remotes that were insufficient (although they look neat) for the type of control the clients were after. We replaced these with MX-850 and MX-900 models. Happy clients.
__________________
"Who is this Superman?" |
#5 | Link | |
So you have 8 total options that can go on a screen. You can have multiple pages of screens for that activity. If I want 10 options for my PVR listed and I want 2 options for my TV listed and 1 option for my reciver listed it is very hard to order those. My PVR options would all have to be listed together so there really isn't a way for me to chose to have 5 PVR options, 2 TV options, and 1 Receiver option on the first page and have the remaining 5 PVR options on the second page. Now you *might* be able to work around this if you list the same device multiple times in the setup or custom program your own device that consists of functions from the PVR, TV, and receiver. I'm pleased with how I have it set up now but I'm too lazy to program it like I mentioned in the previous paragraph. In the end it is something that Logitech could easily give users the ability to do but have chosen not to for some reason... Last edited by decktard; 07-14-06 at 02:33 PM.. |
#6 | Link | |
#7 | Link | |
#9 | Link |
New Member
I program a lot of MX850's and I really like them, but you don't get much space on the LCD to put things such as "Watch DVD", etc..... You have to do something like CABLE, DVD, OFF, etc.... short names. Move up in their line and the LCD's have a little more space, or go to a touchscreen model (either with Universal or marantz/phillips pronto) and then you can make the screen say/look however you want.
#10 | Link | |
Another remote line to look at is RTI..this is a dealer only line but they work and are very customizable. the T2+ is a great remote add on a RP-1 or RP-6 and you have the ability to use RF that actually works.
rticorp the T3 is awsome and they also have a U1 that is waterproof for the shower or pool or hot tub We used to sell the URC line but after seeing so much of it on ebay and people calling us for help with remotes they didnt buy from us got old...not to mention the Crap ass MRF-200, MRF-250 and MRF300 I wish we were Real system stuff they keep pushing. We had so many issues with bad product we had to quit selling it also look at the Nevo SL at mynevo |
#11 | Link | |
New Member
I was just about to buy an MX-850 with the MRF-250. Should I think about the Harmony 890 instead? |
#12 | Link |
I think what monkey was refering too was the Poor RF perfomance on the MX3000 with a MRF 250 or 300 unit, we have had similar issues when combining the 2
The MX850 and MRF should be fine www.surfremotecontrol.com and talk with Mike http://www.surfremotecontrol.com/store/mx-850rfs.html |
#13 | Link |
I've used the Univerals quite a bit and love the complete control you have over the inteface, macros, etc.
That being said, I purchased a Harmony 880 when they first came out, took an hour to set it up, and it's been 90% functional since then. I went through a couple defective remotes with their RMA department, but finally have a good working one. Now I'm trying to customize my remote to get that remaining 10% done, and am completely frustrated. You can't setup a macro within an activity. I've tried using duplicate devices to simulate a macro, but if the software sees a duplicate command, it removes the button. Like another poster said, you also cannot arrange the LCD buttons within the activity - it arranges them as it sees fit. They also have a bug in their software, so you CANNOT customize your MediaCenter commands until they fix it. Since their software is web-based only, you have 0 options other than waiting it out. I think that, assuming their software is working correctly and bug-free (which it's not right now), their remotes are great for the casual user who wants a lot of simplification without a lot of work. They're also OK for a more advanced user who doesn't mind living without certain functionality because of the limitations of the remote. If you're like me and want things to look and work exactly how you envision them, however, look elsewhere. Good luck! |
#14 | Link | |
Thanks |
#15 | Link | |
#16 | Link |
You basically can't assign any custom buttons or commands. They said they released an updated on 7/10 that caused this issue, and they are not scheduled to fix it until early August. Absolutely unacceptable, in my opinion, since they give you no other method to program your remote.
For example, I want to add x10 lighting controls to all of my Activities. I want them to display on the first page of the LCD once I get into the Activity. Since they don't allow you to arrange the commands at all (which I think is stupid), I basically am going to delete unused commands from the LCD so I can fit my lighting controls. Can't do it on any Activity which uses my MediaCenter (Watch TV, Watch DVD, Listen To Music, or Watch Videos) because of the bug. I also want to reassign the function of the + key. Can't do it becuase of the bug. Here's a post on Logitech's forum about it: Logitech You can ADD the MediaCenter PC and create an activity, the bug shows when you try to customize anything to do with it. I can't believe more people aren't complaining about it (MediaCenters mustn't be popular enough), and I think it shows a huge flaw in their method of programming (web-only). |
#17 | Link | |
#19 | Link |
New Member
Does anyone have an opinion about the simplicity of programming a Universal remote versus the Harmony remotes?
I had a local Universal dealer tell me that the Harmony remotes were more designed for consumer programming and that I would have to pay them $250 to program an MX-800 because I probably wouldn't be able to do it. |
#20 | Link | |
that software is availble there as well Here is a better link to the software http://www.universalremote.com/products/downloads.php also goto www.remotecentral.com then one there goto the universal remote section, there you will beable to find out more on the remote |
#21 | Link |
In addition to downloading the software, also download the Programming Manual (not the owner's manual) for the MX-800. You can program the enitre remote without having it, so it's a great, no-cost way to see if it's something you want to tackle.
__________________
Enjoy! Mike Surf Remote Control Contributing reviewer and calibrator, ProjectorReviews.com |
#22 | Link |
The dealer ,if he is in anyway qualified, should be able to do a better job. If you enjoy programming your remote or the money is a big deal, you should give it a shot yourself.
That's my beef with Harmony remotes is that they are too simple for people who frequent this forum. They only get 90% of the way there. In fact I thin kthey take longer to program than other models if they can be programmed at all b/c of the web interface. However, if you are one of the lucky ones or not very picky it might just be all you need. |
#24 | Link | |
My Panasonic 900u isn't in the device list, but a quick Google search revealed this: http://www.remotecentral.com/cgi-bin...700&db=devices Just one question, does the MX know what's already on? Like if I've been "Watching a DVD" activity and switch to "Media PC" activity then processor/amp and projector are already on, don't try to turn them on. That is a major selling point of the Harmony. |
#25 | Link |
Or maybe the activities will just never turn anything on and the procedure will just be to use the system on and off buttons. After all, devices like media PCs and DVRs are never turned off.
Well Universal, making your software available like that may have made you a sale... OK next question, anyone want to sell me an MX-850? Time to start searching and see if I can find one for a low enough price vs. the $99 CDN "90% good enough" Harmony 520. |
#26 | Link | |
Member since 2001-05
#27 | Link | ||
__________________
#28 | Link | ||
#29 | Link |
So I purchased a Harmony 520 on the way home from work yesterday to give it a try.
You tried to warn me, but in my defence I have to say it's hard to appreciate just how frustrating the Harmony software is until you've actually used it in a real situation. Maybe I should stick with the MX-500 that came with my A/V processor and just print labels "Watch DVD" and "Media PC" to stick over "M1" and "M2". |
#30 | Link | |
I think I'll be able to live with the 520. I hate the software, but I've got it doing pretty much everything I want. I'm not satisfied with the physical build quality, the software, the LCD order customization, or the outstanding Media PC button customization bug. But, it looks nice, was relatively cheap, does what I need the most, and, most importantly, passed the wife tests.
| Bookmarks |
| Thread Tools | |
