#1 | Link |
AVS GOLD CLUB MEMBER
SDI vs HDMI 480i
I am sure some you have experimented with both SDI & 480i over HDMI feeding your standalone VPs.
Does an SDI mod'd DVD player still offer some real picture quality advantage ? ..... just trying to figure out what route to take next ! - Andy |
#2 | Link |
Yngwie's Biggest Fan
Andy SDI is much better than HDMI, here are the reasons:
-technically more pure, doesn't have HDCP or audio added in the chain -SDI is directly and I mean directly from the mpeg chip -using SDI allows analog output from scalers etc.(a must for CRT projector users) -SDI signals can be sent much further than HDMI and are more robust -BNC connection is more stable and secure than HDMI ![]() -no HDMI 480i players can come close to the SDI mods on the best mpeg decoders ever, the Panasonics from a few years back nothing beats a SDI modified Panny RP91/RP82 and their clones ![]() -Gary
__________________
Gary's HT/Review System |
#3 | Link | ||
There is no image quality difference between SDI and HDMI. |
#4 | Link | |
also the fact the no players with mpeg decoders as good as the Panasonics have HDMI output, so SDI is better than HDMI in every way because of the quality of mpeg decoders in the units we are comparing ![]() -Gary
__________________
#6 | Link |
HDCP should not change the video data in any way once properly decoded. Yes, it is extra baggage to carry alomg but it's not going to affect image quality. Now 480i HDMI technically should not contain HDCP because it's under the maximum unprotected resolution limit. However I do agree many manufactures will not think this out and will just apply HDCP to anothing leaving the HDMI port.
As stated SDI can (and does in many professional installations) carry 4 full bandwidth (48khz) AES channels. HDSDI can actually carry 16! What leaves the MPEG decoder chip in "modifiable" players is either a Bt656 or Bt601 8 bit parallel stream with a clock line. A Bt656 stream can simply be serialized with a single chip. A Bt601 stream must pass through some logic to add the EAV/SAV words which imply H&V sync. Generally an FPGA but I remember the days in the early 1990s when this was a PC board area the size of a business evenlope to do this with TTL chips and some crude programmable logic! SDI is a true unbalanced serial interface needing only a sigle wire and a return wire - coax. Twisted pair is entirely possible but no standard exists for it's use. I have seen a demonstration by Belden carrying SDI over a single CAT5 pair. HDMI is not fully serial inthe same sense. While the individule data channels, Y,pB,pR rae serial streams, there are three of them along with a clock. These four signals are balanced LVDS signals. So HDMI is also a PARALLEL interface in a sense. The problem is data skew. On a long cable it's not possible to make the fuor pairs exactly the same physical legnth. At some point this delay causes data skew. At worst case a data pair may actualyy be delayed into the next clock pulse resulting in visual chaos. SDI is far more robust than HDMI. It can travel much greater distances over inexpensive cable. Last edited by Glimmie; 07-18-06 at 08:11 PM.. |
#7 | Link | |
Targus,
IMHO, Andy and Gary are talking about commercial DVD's, Movies and Television programs. Quote:
Paul |
#8 | Link | |
The addition of audio data in the video stream in either SDI or HDMI has no ill effects on video quality or bandwidth. The space is allocated for it. If you don't use it, then that space is empty. But the space reserved for video data transmission remains the same. Adding audio to SDI or HDMI does not compromise the video data payload in any way. Now the more audio channles on the disk, the less room for video, but that's a different issue altogether. Last edited by Glimmie; 07-18-06 at 08:41 PM.. |
#9 | Link |
![]() So when it is said that a DTS track wasn't put on a DVD because it would take up too much valuable space, compressing the video portion further - would not be an accurate statement? Last edited by Paul H; 07-18-06 at 08:45 PM.. Reason: Question |
#10 | Link | |
Thanks for the tech info.
But what will my eyes see using an SDI player mated with the likes of a Lumagen/DVDO/Crystallio2, as compared to a 480I HDMI player ? I happen to have a Panasonic XP50 with SDi from my Immersive Holo3D-2-Aux days, and am not sure if I should keep it for future use, or sell it off. But Methinks I should keep it in my closet of treasures, considering it might only fetch < $300 at the buy & sell sites. - Andy |
#12 | Link | |
who cares if SDI can carry audio?, that doesn't apply to our situation in anyway shape or form, there have been face offs comparing HDMI to SDI on the same player, take a guess which one won? SDI can travel longer, doesn't have HDCP which leads to analog output problems, uses a much better BNC connector in 99% of cases and is actually better in picture quality, sorry it has been proven Andy you have the best there is, the XP50 is at the top of the heap, no need for anything else, the XP50 also doesn't have a spindle motor defect either, Do Not get rid of it Carl I have yet to have a Philips on my bench, I tend to avoid the 601 players with the 2 extra channels as the SDI products are much more expensive -Gary
__________________
#14 | Link | |
#15 | Link | |
Yes, an optimal HDMI implementation *can* theoretically be identical to SDI. However, in most cases SDI still looks better in real life. Why? Because most DVD players do harm to the video stream before outputting it over HDMI. E.g. I've been told by UK custom installers that an SDI modded Arcam DVD player still looks ever so slightly sharper than the HDMI output of the very same player. The difference is very small with Arcam, though, and only visible on very large displays. However, Arcam are known for a very good HDMI output. Most other DVD players do worse than that. E.g. most HDMI players don't even support 480i output. And YCbCr output is also not available in every HDMI DVD player. |
#16 | Link | |
. With you most of us would have the view that sdi and hdmi can be the same in PQ but it seems most are not when doing real testing. We all asume this is because 'stuff is done to the signal' before it reaches the output. Now the question is have we looked at examples of what is done ? I myself use SDI since it seems to be a sure bet compared to using hdmi out at this stage but i would love to know what kinda of 'things' are done to the signal to create this difference in real world tests.Or could it be that somehow the chips in the chain itself (when using hdmi) that give the difference in results i mean they sofar all use the same chips from SI no? Also i would like to add one more (small) reason to use SDI for dvd, if your scaler has a SDI in it means you will keep 1 extra hdmi free. Like alot of things with scalers small things add up for me its the points Gary pointed out plus this. Daniel. |
#17 | Link | |
(1) Color space conversion. (2) Clipping of BTB/WTW. (3) Deinterlacing. (4) Noise reduction. (5) Filtering (e.g. CUE filtering or vertical filtering). (6) Color "correction". (7) Overscan. Some of these are not necessarily bad in itself - but bad if you use an external video processor which most probably can do all these things better. But as you said, maybe there are more things than that going on behind the scenes, which we don't know of. |
#19 | Link | |
well let's just say for argument sake, for this the additional processing could actually be gd, if the HDMI is done properly and the external video processor is deficient in NR. A prime example will be the upcoming Denon 3930, if the 480i output (it supports) can have HQV NR applied first (this part is unknown yet), then a VP30+ABT102 will benefit greatly from this output.In all honesty I think both depend on how well it is done. A SDI mod can probably also be done poorly that introduces unwanted "jitters" (is there such thing in video?) Since all these mods are after-market, at least for the connector part the builtin "path" can be better. So ideally they all should have no difference, just that in reality the HDMI implementation so far is pretty poor. |
#21 | Link | |||
#22 | Link | ||
#23 | Link | |
#24 | Link | |
(click for homepage)
#25 | Link |
I think I’m following all this……I think. Pretty much over my head, as with 90% of the posts on this board. But I keep reading and trying to learn anyway. Advil helps........
Where would the Oppo 970HD fall into this discussion? Didn’t they target VP owners with this machine? Have they done something different with the data stream that would make the machine comparable to a SDI modified player? |
#26 | Link | |
More Wag, Less Bark
Guess what - there is a measurable difference. The HDMI has noticable ringing on the DVE resolution test pattrern - there is none via SDI. Also, and I admit this may be subjective, viewing a movie via SDI seems more fluid with marginally better blacks and colors. Frankly, I don't care why there is a difference, but I'd tell anyone to consider an SDI mod if they use a video processor that accepts SDI input. PS: folks here don't take likely to 'blanket statements' - much better to share your personal experience. YMMV.
__________________
J.Mike Those who die with the most toys ... are still dead! |
#28 | Link | ||
#29 | Link | |
Talk to the Hand
__________________
http://www.videovantage.com |
#30 | Link | |
ISF Calibrator
AVS CLUB MEMBER
I was thinking the same thing Mark. If you use the "DIRECT" mode out of the 59AVi then it "should', you would think, be pretty much the same as SDI
Although I have found the same thing you mention to be true with mine also.My take on it is if you feel that the small amount of image quality is worth the added expense of going SDI, then just do it. There are so many variables that can creep into each one that I think personal experimentation is definitely in order to see which combo works best and/or makes it worth the money.
__________________
Dave Harper Harper Home Theater Systems ISF Calibrations, Consultations Sales & Installations |
| Bookmarks |
| Thread Tools | |
