#1 | Link |
Audio/Video/PC Tech
Need Help Getting Into RCA 27V550T Service Menu
Searched google and couldnt find a code or anything,
I need to tweak my old Xbox TV for my brother who got it from me when i bought my Sony 30 Inch Wega.. So.. thatsa RCA 27V550T Service Menu.. i need to fix the color and the overscan... |
#2 | Link |
1. TV turned on
2. Press and hold the 'Menu' button at the tv. 3. Press and release the 'Power' button. 4. Press and release the 'Vol up' button. 5. Release the 'Menu' button. 6. The initial security parameter displayed will be 'zero' Change this to '76'. You are now in the Adjustment mode Use the 'Channel up or down' to select parameter 'P'. Use the 'Volume up or down' to change the parameter value. Turn the set off to exit. |
#5 | Link | |
New Member
That way didn't work for me either to enter the RCA 27V550T xbox ready television. I just recently bought a 360 and with the component cables hooked up it overscans to the left about 2" which is quite annoying, it does it a little with the regular av to but I've dealt with it till now. Does anyone know the way to change the horizontal size of the screen and to get into the service menu. I tried doing the steps above but all it does is bring up my regular menu.
#6 | Link |
New Member
Does Anyone Have The Answer
Please someone help and save me the $$$ of taking it to the shop for something so simple. I've been annoyed for 2 years with this problem and now that I actually use it for games its really annoying because sometime things I need to see are off the screen.
#12 | Link |
New Member
I apologize for the necro-post, but this thread is one of the top threads when searching for the answer so I figured I should put the answer here for the two other people in the world that need it.
1. Turn the instrument on. 2. Press and hold the VOL - button. a. Press and release the POWER button. b. Press and release the MENU button. 3. Release the VOL - button. Keep pressing vol -/+ until the number reaches 76. Press chan -/+ to change to the different service options. 01 Error Detection (1st) ? First Error Code 02 Error Detection (2nd) ? Second Error Code 03 Error Detection (last) ? Last Error Code 04 VG2 0 3 Read Back Only 05 Read BCF Status 0 1 Read Back Only 06 Vertical Slope 0 63 07 Vertical Shift 0 63 08 Vertical Amplitude 0 63 09 Horizontal Shift 0 63 10 S Correction 0 63 11 EW Width 0 63 12 EW Parabola Width 0 63 13 EW Upper Corner Parabola 0 63 14 EW Lower Corner Parabola 0 63 15 EW Trapezium 0 63 16 Horizontal Parallelogram 0 63 17 Horizontal Bow 0 63 18 Vertical Zoom 0 - 63 19 AGC 0 63 20 Cathode Drive Level 0 - 15 21 Sub Brightness 1 17 22 Sub Saturation 1 17 23 Sub Hue 1 17 24 Black Level Offset Red 0 63 25 Black Level Offset Green 0 63 26 White Point Red 0 63 27 White Point Green 0 - 63 28 White Point Blue 0 - 63 29 Peak White 0 - 63 30 Y Delay Adjustment 0 15 31 SOC 0 3 32 Offset IF 0 - 63 33 GE (For Kidpass Activation 0 1) |
| Bookmarks |
| Thread Tools | |
