AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Blu-ray & HD DVD Areas > HD DVD Software
Forum Jump
Old 07-30-06, 05:33 PM   #1   |  Link
Joseph Clark
The official AVS Guide to HD DVD Authoring.
The Official AVS Guide to HD DVD Authoring
This guide will take you through the creation of your own HD DVDs step by step. This process uses regular DVD recordables (and double layer DVD recordables) to create HD DVD discs that will play on a standard HD DVD player (such as the Toshiba A1 or XA1). At present, high definition MPEG2 files at resolutions of 1920x1080i, 1440x1080i (HDV) and 1280x1080i work without additional conversion within the software. 1088i and 720p are now supported with the addition of HDPatch, a simple but powerful utility by texmex. See below for specific instructions if your files are 720p or 1088i (i.e. DirecTV).
Special Warnings:
1. Recording double/dual layer DVD media has proven less consistent than recording single layer DVDs. You may find it difficult to achieve successful burns with double layer media using certain combinations of burners and media.
2. DircecTV users will need to convert their video from 1088i to 1080i for this process to work. See the notes below on using texmex's HDPatch conversion utility. Download the attached file below.
3. HDTV files in 720p format also will need to be processed with texmex's HDPatch utility, if you are using a version of Ulead Movie Factory 5 before version 5.3.0.0. Versions after this appear to have full support for 720p60 built in. (Thanks Leonowski.) HDV 720p30 files, however, still need to be patched. (Thanks d-v-c.)
4. Reports are that Nero Burning ROM 7 is less problematic in creating discs than earlier versions. Some people report failures with version 6.
5. Reports of stuttering playback using DVD+R, single and double layer, especially with high bitrate material, may be related to the Booktype setting. In Nero, under 'Choose Recorder,' change the Booktype setting on your DVD burner from "DVD-ROM" to "Physical Disc Type." Note that not all burners allow you to change the Booktype.
For additional information and all the original posts, go to the AVS Forum thread started by Aaron.s:
Original AVS Forum HD DVD Creation Thread
Please make all new posts to this thread.
Hardware requirements:
1. A device that allows MPEG2 captures to a computer. This may include: HDV camcorders; D-VHS recorders (with unprotected content); OTA receivers with FireWire output; OTA computer capture cards such as MyHD or Fusion; FireWire devices such as 169Time; and, USB2 devices such as the Nextcom R5000 (for HD receivers from Dish Network, DirecTV and some cable TV companies).
2. Any more recent computer (Intel or AMD based systems) with a DVD burner and sufficient hard drive space.
Software requirements (alternate software is listed below):
1. VideoRedo (version 2.2.1.491).
VideoRedo
2. Ulead Movie Factory 5.
3. Nero Burning ROM (versions 6 and 7 work, although some people report problems creating discs with version 6).
Nero Burning ROM 7
Basic Steps for Creating HD DVDs:
1. Capture a high definition MPEG2 video to your computer.
2. Convert the video file from .ts, .tp or .m2t transport stream format to program stream format (mpg) using VideoRedo.
3. Create an HD DVD folder on your computer using Ulead Movie Factory 5.
4. Burn the HD DVD disc using Nero Burning ROM.
Detailed Steps for Creating HD DVDs:
1. Capture a high definition MPEG2 video clip using an appropriate device. See Hardware Requirements above for a partial list of devices. It is beyond the scope of this guide to include specific instructions for capture. Several other threads exist on the AVS Forum that cover this process.
2. Convert the MPEG2 transport stream file (usually with a .ts, .tp or .m2t file extension) to MPEG2 program stream (with an .mpg extension) with VideoRedo:
Special Note: As of this writing (late October, 2006), version 2.2.1.491 is a beta release. You must follow the instructions below to access the special feature that allows VideoRedo to work seamlessly with Movie Factory 5. Future full releases should have this feature available without having to hold the shift key.
a. Start VideoRedo. Select File>Open Video… . In the browser, select the movie you’ve captured. (Tip: if you have multiple files that need to be added as a whole, lasso select the files and choose "Combine," not "Join," from the dialog that follows; the file segments will be combined into one large MPEG.)
b. In the main menu, select Tools>Options. Hold down the shift key as you click on "Options." This will bring up one additional selection - "Add GOP Timecode to all GOPs... .") Click on this and change the value to "True."
c. Use the play and navigation buttons to find the start of a section of the video you want to delete. Click “Set Start.” Find the end of the section you want to delete and click “Set End.” Click “Cut selection.” (It will turn red.)
d. Repeat this process for all the sections you want to delete. (Tip: use the arrow keys and your mouse’s scroll wheel to move quickly through the video. A full set of keyboard shortcuts can be accessed from the main menu's "Help" item.)
e. Select File>Save Video As… . Select a folder on the hard drive to save the video. By “Save as type:” select “MPEG Program Streams (.mpg .mpeg).”
Special Note: If after using VideoRedo to convert your file, Movie Factory 5 still insists on re-encoding your video, try processing the file with HDPatch (see below). Another use for HDPatch is to replace false bitrate values. Files improperly marked with high bitrate numbers may force Movie Factory 5 to re-encode the video to make the files compatible. See the notes on HDPatch below for a technique to replace false high bitrate numbers with more accurate ones.
IMPORTANT NOTE for using this technique with 1088i and 720p videos:
If the file you are using is 1088i (DirecTV) or 720p, see below to patch your video so that it can be used with Movie Factory 5. If you don't follow the instructions below, you may be able to create an HD DVD folder, but the process will take much longer and the resulting video will be degraded dramatically from the original. In the worst case scenario, Movie Factory 5 will reject the file as incompatible.
3. Create the HD DVD folder on your computer with Ulead Movie Factory 5.
a. Start Ulead Movie Factory 5 (and wait, it loads slowly). Select “New Project.”
b. Under “Create a Video Disc” select “HD DVD.” Click “OK.”
c. In the upper right, select the movie film icon with the + sign (second icon from the left). In the browser, select the video file you just converted. The file should load in quickly. Long delays in file loading are being investigated. See some possible solutions in the frequently asked questions section below. Tip: avoid trimming the video at this stage of the process. Trimming here may result in video re-encoding. It's better to do all editing in VideoRedo, prior to importing your file into Movie Factory 5.
d. Deselect the button on the left marked “Create menu.” (Leaving this button on will allow you to create custom menus for your project, but they will slow the process. For many projects, menus will be unnecessary. This also allows you to check more easily that your project is processing without re-encoding.)
e. Click on “Add/Edit Chapter…”
f. Clicking “Auto Add Chapters…” brings up a box in which you may have the program add chapters at fixed intervals in minutes. Playing and moving the play button for the movie allows you to use the “Add chapter” selection manually. (Chapters allow you to navigate quickly through the video on your HD DVD player.) When you've added all the chapters you want, click “OK.”
g. Click “Next” and use this screen to check playback and chapter stops in your program. When you're satisfied with playback, click “Next” again.
h. Click on the “Project Settings” button in the lower left of the screen. Make sure the box labeled “Do not convert compliant MPEG files” is checked and click “OK.”
i. Click the box labeled “Create HD DVD folders.” Click on the folder icon at the end of this option to select the folder where you wish to create the HD DVD folder. (You may create such a folder in the browser at this point, if you do not have one prepared.)
j. Click the “Burn” icon in the lower right. If things have gone well, you should see “Total progress: Prepare output content…” and “Detailed progress: Video/Audio multiplexing…” appear with blue progress bars almost immediately. If you see the message “Convert title…” you are in for a long wait and your video may not be compatible. Time to check the settings. and refer to Frequently asked questions bwlow.
k. When the process completes, click “OK.” Your HD DVD folder is ready to burn.
4. Burn your HD DVD folder to a DVD recordable using Nero Burning ROM.
Technique 1 - preferred (works with Nero version 7):
(Contributed by pteittinen.)
a. Launch Nero Burning ROM and select "DVD-ROM (UDF)" on the left side of the screen (you may need to scroll down).
b. Under the "Multisession" tab, select the "No Multisession" radio button.
b. Click on the "UDF" tab.
c. In the "Options" pull-down (or the checkbox under "Advanced," depending on your version of Nero), select "Enable Xbox (TM) compatibility mode."
d. Disregard any warnings and continue.
e. Click "New."
f. Drop the HVDVD_TS folder you just created into the root directory of the compilation (column on the far left).
g. Burn the disc by clicking on the Disc/Lit Match icon at the top.
Technique 2 (works with Nero 6 and 7):
a. Start Notepad or any word processor that allows you to create a .txt file. Leave the document blank (don’t type in anything). Select File>Save and save the blank document as text (.txt format) in a handy place on your hard drive – call it VIDEO_TS.VOB (.txt will be added automatically). Open Windows Explorer and find your new text file. Right click on it and go to rename. Delete the .txt from the end. Ignore the Windows warning and click “Yes.” Your file should now appear as VIDEO_TS.VOB. Special note: if you can't see the .txt extension in Windows Explorer, it probably means you have your computer set to hide file extensions. Open Explorer and select from the menu Tools>Folder Options... . Select the "View" tab. Find the box for "Hide extensions for known file types." and deselect it. Click "OK." You should now be able to see the .txt extension.
b. Start Nero Burning ROM and select the Nero Burning ROM application.
c. In the left column, select DVD Video and click “New.”
d. In the right column, select the drive where the new VIDEO_TS.VOB file is located. Drag that file onto (on top of, not above it) the VIDEO_TS folder in the leftmost column. (Make sure it’s in the VIDEO_TS folder, not in the root directory.)
e. Go back to the rightmost column and find the HD DVD folder you created in Ulead Movie Factory 5. Drag that folder into the leftmost column. Make sure NOT to put it into the VIDEO_TS folder. This folder must reside in the root directory.
f. Load in a recordable DVD (single or double layer, depending on the size of your project). Make sure your DVD burner is selected in Nero (click the “Choose a recorder” button).
g. Click the Disc/Lit Match icon to burn the current compilation. Ignore any warning messages the system displays by clicking “OK.”
Try your new HD DVD in your HD DVD player.
Alternate software:
(Note that some have experienced problems with Womble MPEG2VCR, VideoRedo and HDTVtoMPEG2. HDTVtoMPEG2 is freeware, but has known problems creating compliant MPEG streams with this process. Womble and VideoRedo cost $50 each. Use the trial versions with this process and your system before you buy.)
A variety of other software packages may be used to edit transport stream video files and convert them to MPEG2 program stream. If you have a program that will convert .ts to .mpg, try it. If you have substantial success, please post your results here.
You can find Womble MPEG2VCR here:
MPEG2VCR frame accurate transport stream (.ts) to program stream editing software
Using Womble MPEG2VCR (version 3.14) to convert transport stream video files to MPEG2 program stream format:
1. For videos consisting of one large .ts file, select File>Open MPEG Movie and Editor Project… . Select your video file from the browser.
2. For videos consisting of multiple files, hit F6. In the “Clip” box, select the “…” button to bring up a browser window. Select all the ts files that make up your video (either lasso or select/shift select all the files you want to include). Hit “OK.”
3. Edit out the sections of the video you don’t want included. Find the beginning of a section (such as a commercial) you want to exclude and hit the “I” key (for in). Find the end of that section and hit the “O” key (for out). Hit the “X” key (for cut). Repeat until you’ve gotten rid of all the material you don’t want.
4. At the bottom of the MPEG2VCR Clip List window, there are two rows of buttons. Select the button on the second row, third from the right (the icon with a red top). In the box labeled “MPEG Format” select the third radio button from the bottom, labeled “MPEG-2 Program Stream.” In the box labeled “File Name” select the “…” button. In the browser, select where you want to save the new program stream file and type in a name for it. Click “Save.” Click “Save” again and MPEG2VCR will convert and save the file for you.
Using Movie Factory 5 with 720p and 1088i files (a file patch utility by texmex):
Do not be put off by the length of the following instructions. Once you've done this once, it shouldn't add more than about 30 seconds to a minute of additional time to the process of creating HD DVDs. This utility is extremely easy to use. As with the process in general, problems have been reported with some files.
For HDPatch to run, you will need to install the Microsoft .Net Framework 2.0. It can be found here:
Download and install the software. You may have to restart your computer when the install completes. Failure to install the Microsoft .Net Framework will result in an error message when you attempt to run HDPatch.
The latest version of HDPatch can be found in the file attachment at the bottom of this post.
What Is HDPatch Used For?
HDPatch can be used, primarily, to solve two problems in the Movie Factory 5/VideoStudio 10+ HD-DVD workflow (other uses are outlined below):
1. 1088 files: many streams from various sources are encoded with a vertical resolution of 1088 (i.e. 1920x1088 or 1280x1088). MF5/VS10+ does not recognize this as a valid HD-DVD resolution and will attempt to re-encode these streams. HDPatch will modify the stream headers to correct the resolution, changing the 1088 to 1080. Once "patched," Movie Factory 5/VideoStudio 10+ should process the stream without re-encoding. And don't worry - you're not losing 8 pixels of video. Those extra 8 pixels are usually gray filler.
To use this feature:
1. Process your .ts, .tp or .m2t file with VideoRedo to convert transport stream to program stream.
2. Run HDPatch. Select your converted program stream video by clicking on the "..." box at the end of the "File:" line. In the browser, find the file you converted.
3. In the menu select Preset>Fix1088.
4. Select the "Patch Stream" button at the bottom.
The patch should be virtually instantaneous. Your file is now ready for normal processing in Movie Factory 5.
2. 720p files: Movie Factory 5 (before version 5.3.0.0) and VideoStudio 10+ do not recognize 720p as a valid HD-DVD format. They will attempt to re-encode 720p files during the authoring process. In order to avoid this, you can use HDPatch to "prep" a 720p file for authoring.
2. Run HDPatch. Select your 720p stream by clicking on the "..." box at the end of the "File:" line. In the browser, find your file.
3. In the menu select Preset>>720p> Pre - patch 720p for MF5/VS10+.
The patch should be virtually instantaneous. Complete the process outlined above to create the HD DVD folder on the hard drive.
Before you can burn the HD DVD to disc, you must patch the .EVO file within the folder.
1. Run HDPatch and click on the "..." box at the end of the "File:" line. In the browser, find the first .EVO file in the HD DVD folder you just created.
2. From the menu, select 720p>Post - Patch EVO/IFO for burn.
3. Select the "Patch Stream" button at the bottom.
The patch should be virtually instantaneous. Your HD DVD folder is now ready for burning in Nero Burning ROM.
Patch the 720 file back to its original settings:
Once you've burned the HD DVD folder to disc, you should return the original MPEG file to its normal settings. Failure to do so may result in the MPEG file not playing correctly.
1. Run HDPatch. Select your 720p stream by clicking on the "..." box at the end of the "File:" line. In the browser, find the original MPEG file.
2. In the menu select Preset>720p>Post - Revert MPEG source to 720p.
Your original 720p MPEG file is restored virtually instantaneously and should play normally.
General MPEG patching:
HDPatch also can be used for general MPEG header patching. Maybe a file is incorrectly flagged as 4:3 when it is actually 16:9. HDPatch can be used to correct the headers in such a file.
Patching files with false bitrate information:
Sometimes video files have inaccurate bitrate information in the header. A file with a stated bitrate of, for example, 65000000 may force a video re-encode in Movie Factory 5. Changing the header information to a realistic number (20000000) often prevents a re-encode. If after normal VideoRedo conversion, Movie Factory 5 insists on re-encoding, try the following:
1. Run HDPatch. Select your MPEG file by clicking on the "..." box at the end of the "File:" line. In the browser, find the file.
2. In the dialog, click in the "Bitrate:" box. Change the excessively high number to one that no OTA or satellite HD signal is likely to exceed (i.e. 20000000).
The patch should be virtually instantaneous. Try using your file again in Movie Factory 5. If all has gone well, it will be accepted without re-encoding.
Frequently Asked Questions/Helpful Suggestions:
Q. The video on my HD DVD player pauses or video freezes up several times during playback and then continues. What can I do to prevent it?
(Contributed by KoolKiwi)
A. Since the HD-A1 correctly interprets MPEG timestamps, any timestamp gaps will result in an apparent freeze (actually a pause) in playback. This can be caused by software editing programs that do not correct timestamp gaps during editing (such as when you edit commercials out of a .ts file with HDTVtoMPEG2).
To avoid this, run the original .ts file through Mpeg2Repair (log only) to check for any timestamp gaps. MPEG2Repair can be found at the bottom of this guide with other helpful tools.
1. On the line labeled "Input File:" select the "..." button. Find the transport stream file that may have timestamp problems.
2. Click the button labeled "Find PID's."
3. Check "Log Errors."
4. On the line labeled "Log File:" click the "..." button. Click "Save." Any timestamp error notations will be saved to a text file in the same directory as the .ts file.
5. Click the "Start" button in the upper right.
6. Check the timestamp of the file you just processed by opening the text file in Notepad or any word processor. Look for a line that reads something like this: "Info: 1.233011 seconds of video timestamp gaps." If any timestamp gaps are found in the log file, the .ts should be processed through VideoRedo's "Quickstream fix" (with output to a new .ts), before using the normal VideoRedo process to convert the resulting .ts to .MPG for use in Movie Factory 5.
To use the VideoRedo "Quickstream Fix" function:
1. From the VideoRedo menu, select Tools>Quickstream Fix... .
2. Under "Input Stream:" click the "..." box and find the stream with the timestamp errors. If necessary, click the "Select Stream" button and find the stream you want to fix. (This should be necessary only if there are multiple videos within the .ts file - i.e. if the file has video subchannels.)
3. Under "Output Stream:" click the "..." box and find the location where you want to save the timestamp corrected video.
4. Click the "Start Quickfix" button.
When the process completes, you can run the new .ts file through VideoRedo as usual for output as a program stream file in Movie Factory 5.
Q. My video files load into Movie Factory 5 extremely slowly. How can I speed up the process?
A. [Update: Using VideoRedo's beta release (version 2.5.2.491) seems to solve many of the slow loading issues (as of late October, 2006). Please follow the instructions above to speed up the loads. Until we have more reports, I'm leaving the following notes here.] No definitive answer is available. Contributors are looking into this issue. Generally speaking, slow file loads occur more often in VideoRedo than Womble's MPEG2VCR (a trial version is available). Try using MPEG2VCR instead. Many users have reported that MPEG2VCR loads are virtually instantaneous, while files created with VideoRedo MAY take a long time to load. MPEG2VCR, however, does seem more prone to creating lip sync errors. At present, the only way to know what your results will be is to experiment. One possible solution to lip sync errors is to use the timestamp repair procedure outlined in the first question above.
Here's another contribution that you may find helpful if you are having problems with Movie Factory 5 accepting your video file as HD DVD compliant (and it insists on re-encoding). This suggestion comes from the_Tom, who uses a Motorola 6200 cable box.
One thing that is necessary in order for MF5 to consider the mpg file you feed it to be "compliant" and thus be willing to skip "converting" it, is for the file's header value for max bitrate to be within the HD-DVD spec. One way to ensure this when using VideoRedo is to set the bit rate to 20Mbps (20000000) in its Save/Options dialog. Doing so may not be necessary in all circumstances, but it should always be "safe" as long as the actual max bitrate in the video is less than that, which it almost certainly will be (the highest actual that I have yet seen was around 18M).
Here's how to do this:
1. Start VideoRedo. Load and edit your transport stream file normally, following the instructions above.
2. In the menu select File>Save Video as... .
3. Select the "Options" button in the lower left of the dialog box.
4. Set the "Bit Rate:" drop down to "20Mbps" and click "OK."
5. Click "Save" to save your file as an MPEG program stream.
Another way of achieving much the same thing is to use HDPatch (as outlined above - repeated here for clarity):
To download the files below, right click and select "Save target as... ." Just left clicking often will not work.
__________________
Joe Clark
Joseph Clark is offline   Reply With Quote
Old 07-30-06, 05:36 PM   #2   |  Link
Joseph Clark
Feedback Needed
Here's the guide. I need everyone to take a look and tell me what I missed/got wrong. I'll make changes ASAP.
__________________
Joe Clark
Old 07-30-06, 06:11 PM   #3   |  Link
Brajesh
Classified Rating: 100% (35)
Superb work! Thanks much.
__________________
HDMedia Fan
Brajesh is offline   Reply With Quote
Old 07-30-06, 06:32 PM   #4   |  Link
WiFi-Spy
Elitist Mac User
wow, mods please make this sticky
__________________
http://twitter.com/tylerpruitt
WiFi-Spy is offline   Reply With Quote
Old 07-30-06, 11:38 PM   #5   |  Link
robena
People should be warned that Womble is extremely sensitive to drops.
If a TS file is not perfect, the audio sync will be lost very easily. VideoRedoPlus uses special techniques to avoid this problem.
__________________
Robert
robena is offline   Reply With Quote
Old 07-31-06, 02:25 AM   #6   |  Link
stevenjw
Goldmember
Classified Rating: 100% (2)
Great job guys! About time we have a sticky. There I've said it again for everyone. I'm not looking to step on toes, but I hope we can keep this thread short with just updates, process improvements, and Q/A to its use only. Read this thread first, give it a try, and if it still doesn't work or you have something to add, THEN post. Otherwise, we'll end up with another very long thread and not a Guide. Thanks.
I've used Nero 5.5.10.0 with both Techniques 1 & 2 to burn the folder to DVD-R without issues. Is there any reason, other than it being older, that this earlier version isn't supposed to work?
I get a long pause and an occasional error message after hitting play and entering the HDV content from the rendered MF5 menu. Is this normal or due to using MF5 to add a menu? I have burnt an .iso file that someone kindly provided with HD test patterns using Nero 5.5 and it works flawlessly. It's not using the default title menu supplied with MF5. Perhaps its due to editing with Womble MPEG2VCR and saving as mpeg2 program stream.
MF5 appears to me to be a much more user friendly tool verses VS10+ (make sure you select HD-DVD) and it's cheaper. I don't have any 5.1 audio yet (R5000 is in the works), just whatever is recording by my Sony HDR-HC1 on HDV tape (DD 2.0?). Based on Ulead literature, it appears that 5.1 support is added with VS10+ (not VS10 or MF5). However, I've remember reading posts in the original thread that indicated 5.1 audio will work using MF5. Can someone please verify that MF5 does or does not work with more than 2 channels?
__________________
...Steve
My HT gear/photos and DVD/HD-DVD/BD collection
"People should not be afraid of their governments. Governments should be afraid of their people." - V
[based on a Thomas Jeffereson quote]
stevenjw is offline   Reply With Quote
Old 07-31-06, 03:28 AM   #7   |  Link
christefan
guide
With some people having problems with Movie Factory 5 how about including instructions for Visual Studio 10? also the Movie Factory compatability box is only up to VideoReDo 445 which is not the currant version, i have a question into them about better performance in the latest versions with Ulead software. Great work sofar-thanks from all of us-steve
christefan is offline   Reply With Quote
Old 07-31-06, 03:44 AM   #8   |  Link
Joseph Clark
I love VideoRedo, but I still can't get it to create MPEGs that will work with this process. I thought I had it working the other day, but it choked after I tried to load a longer file. MPEG2VCR works very consistently for me. Most of my files have been clean, but I haven't noticed any serious lip synch issues with ones that have minor glitches.
__________________
Joe Clark
Old 07-31-06, 03:52 AM   #9   |  Link
Joseph Clark
The reason Nero 5 wasn't mentioned was that it wasn't tested or reported on. Good to know it works. We haven't really done much of anything with menus. We should add a section for that later. In my experience, working with menus led to some pretty inconsistent results, but I haven't done a lot of it. MF5 menus are like regular DVD menus, not like the menu overlays we're coming to expect from commercial HD DVDs. Most people don't have any problem maintaining 5.1 audio with MF5, as long as the video isn't re-encoded, but some have. It may depend on the version of MF5 you have.
__________________
Joe Clark
Old 07-31-06, 03:56 AM   #10   |  Link
suprmallet
Film Grain Samurai
Okay, since this is the official thread, I'll ask this here:
Once you got your finished DVD, when you pop it into the player and it recognizes it as an HD DVD, does it still give you an OSD when you hit play/pause/rewind/ff like it does for a regular DVD?
suprmallet is offline   Reply With Quote
Old 07-31-06, 03:58 AM   #11   |  Link
Joseph Clark
If someone will post a workflow for VS10+ I'll add it. I think someone did in the original thread, but I'd appreciate a refresher. (I have VS10+, so I can test the workflow easily myself.) As far as VideoRedo is concerned, I have version 445 and my auto web check of the site tells me it's the latest. Which version do you use?
__________________
Joe Clark
Old 07-31-06, 04:12 AM   #12   |  Link
Joseph Clark
If by OSD you mean the regular symbols for those functions, such as >, >>, <<<, then yes. And, interestingly, the Toshiba remembers where you leave off in one of these home brew HD DVDs when you hit stop. On the commercial discs, if you hit stop it doesn't remember that stop point when you hit play again.
BTW, "official" doesn't mean too much, except that the topic has become a sticky because of all the interest. The same people will be posting here. In many ways, from my point of view, the most significant contributions to this thread have come from texmex, whose technical expertise has legitimized the thread in a way none of the rest of us have. I'll be contributing soon to his PayPal account (which he posted after requests from some of us for him to do so).
texmex, let me ask you to post it here again, in this new thread. And thanks for all your work in providing the utility for us.
__________________
Joe Clark
Old 07-31-06, 04:30 AM   #13   |  Link
suprmallet
Film Grain Samurai
Thanks for the answer. I thought it was odd and was almost worried that it was reading it as a regular DVD, even though the display said HD DVD.
Old 07-31-06, 06:24 AM   #14   |  Link
pteittinen
A Swollen Member
There's not much difference in the flow when using VS10+. When you start the app and find yourself in the main screen with the large preview screen and timeline at the bottom, just open the Tools menu and select Create Disc. From there on the procedure is practically the same.
I say practically, because VS10+'s disc creation offers some options the MF5 does not:
1) Under Project Settings > Change MPEG Settings > Customize... > General you can select Frame Type as Lower Field First, Upper Field First or Frame Based (*a).
2) Under Project Settings > Change MPEG Settings > Customize... > Compression, when you select Audio Format as Dolby Digital audio, you get to choose between 2/0 and 3/2 channels. For 3/2ch the bitrate choices are 384 and 448kbit/s (*b).
(*a): Frame Based means Progressive Scan. I've tested this and it actually works. Another app reported the resulting video stream as progressive instead of interlaced. Toshiba played the stream with some freeze frames every now and then. I've yet to test whether those freeze frames were in the encoded video stream or not. Addendum: if you want to force VS10+ to re-compress your compliant-with-Ulead interlaced content into progressive, you need to untick the "Do not convert compliant MPEG files" box. Or you could feed it something non-compliant, like 1280x720 MPEG4 ASP I shot with a Sanyo HD1.
(*b): I never got MF5 to pass DD5.1 audio through, no matter what. With VS10+ DD5.1 audio is passed untouched when Audio compression specs match the audio specs on the original file. Note: it's perfectly possible the specs don't need to match when the "Do not convert compliant MPEG files" box is ticked, but I haven't had time to test that.
pteittinen is offline   Reply With Quote
Old 07-31-06, 06:26 AM   #15   |  Link
pteittinen
A Swollen Member
Auto web check doesn't report beta versions. You can find the latest betas in their forum. They're already up to version 2.5.1.481, released July 26th. I've had nothing but success with it.
Old 07-31-06, 11:33 AM   #16   |  Link
stevenjw
Goldmember
Thanks for the replies. I haven't felt the need to spend money on an upgrade from Nero 5.5.10.0, especially since it works and there are free alternatives.
I used the default Menu for creating some of my HDV tapes on DVD-R. I wanted to give the disc a more polished look and didn't know that some were experiencing problems with it. FYI, the menu works fine, complete with working initial frames playing in the preview window. The Toshiba hangs after a few seconds trying to play the HD content. The disc will eventually play, but it's a pain. I'll try my next one without it.
Sounds like there's no definitive word on DD5.1 and some of us aren't lucky enough to have the 5.0.0.0 version of MF5. I'm still using a trial for MF5 and was hoping to save a little over VS10+. I'll try UL10+ next. Looks like I may need to spring for this version just to be safe. Thanks pteittinen for pointing out how to use VS10+. Once you get to the create window, it looks a just like MF5, but with the added options. Note: you need to select HD-DVD from the lower left pull-own vs. DVD since you don't get the initial wizard screen like you do in MF5.
__________________
...Steve
Old 07-31-06, 11:59 AM   #17   |  Link
pteittinen
A Swollen Member
My MF5 has a version number of 5.0.0001.0 and the About screen lists Dolby (R) Digital 1.0 as well. No DD5.1 regardless
Yeah, good point. Didn't think to mention that because I select it almost without noticing
Old 07-31-06, 12:01 PM   #18   |  Link
galaxy_jason
Jason Ware
Not having much luck, can anyone help?
Tried the posted procedure with a WMV sample (coral reef from the MS site).
Burned to a DVD+RW. If I use the procedure to burn a standard DVD (DVD project in Ulead) it works just fine (Toshiba sees it as a DVD). But if I try an HD-DVD
project in Ulead the Toshiba loads the disc, says "HD-DVD" on the front panel then
stops with 00000,etc on the counter. On screen it says, cannot play disc.
Any ideas? This is with the lates versions (trial) of Ulead and Nero 7.
galaxy_jason is offline   Reply With Quote
Old 07-31-06, 12:08 PM   #19   |  Link
pteittinen
A Swollen Member
I got that, or something similar, repeatedly when messing around with different UDF versions. That would point towards something going wrong with your burn.
Old 07-31-06, 12:19 PM   #20   |  Link
galaxy_jason
Jason Ware
Hmmm, what do you mean by different versions? I used the settings
as outlined in the guide...
One other question that is not clear in the Guide. Should the mpeg
options in MF5 be set to 1920x1080 or 1440x1080 to play on the
Toshiba?
Old 07-31-06, 12:30 PM   #21   |  Link
pteittinen
A Swollen Member
Hmmm, what do you mean by different versions? I used the settings as outlined in the guide...
Before I stumbled upon the Xbox compat. method, I tested every UDF file format version available in manual settings. None of them worked, but Toshiba recognized the discs as HD DVD - it just wouldn't play them. Rather much like what you were describing. That made me think that something went wrong with your burn.
Toshiba?
If you have the "Do not convert compliant" box ticked, it shouldn't matter, I think. The options are there in case you're feeding MF5/VS10 something non-compliant, and the application needs to re-compress the file for compliance.
Old 07-31-06, 12:47 PM   #22   |  Link
Joseph Clark
I just downloaded the beta and am going to give it a try.
__________________
Joe Clark
Old 07-31-06, 01:19 PM   #23   |  Link
Joseph Clark
No luck with VRD again - 10 minutes + to load in the file, another ten to uncheck the menu button before I gave up and went back to Womble. When I get this type of response, it's always been a waste of time to go on. I usually end up with MF5 rejecting the file as incompatible at the end. I did let it continue a few times, and it took hours to insert chapter stops, then more often than not it reported an incompatilbe stream at the final stage.
__________________
Joe Clark
Old 07-31-06, 01:34 PM   #24   |  Link
Joseph Clark
I just finished processing the same file through Womble as VideoRedo. It took less time for Womble to convert the file from .ts to MPEG (10+ GBs) and run it through to the final stage of MF5 than it did for the VideoRedo MPEG to load into MF5. One thing I do note about the files is that the VideoRedo MPEG is over 5.2 MB larger than the Womble MPEG. It's Backdraft from Dish and the difference in the edit points in the two programs couldn't have been more than half a dozen frames. I just edited out the start and end segments.
texmex, when you get back from vacation, maybe you could take a look at some MPEGs created by the two programs and check for significant differences?
__________________
Joe Clark
Old 07-31-06, 03:07 PM   #25   |  Link
galaxy_jason
Jason Ware
Could it be the source? Has anyone successfully converted any of the
microsoft contentshowcase files? (sorry I'm new here so it won't let
me post the direct link)
I don't have access to a .ts or .mpg stream.
Old 07-31-06, 03:19 PM   #26   |  Link
pteittinen
A Swollen Member
Could it be the source? Has anyone successfully converted any of the microsoft contentshowcase files? (sorry I'm new here so it won't let
Of course it's the source, if you're using some WMV files. Ulead considers only 1920x1080i and 1440x1080i MPEG-2 video as compliant. Everything else it re-encodes with its internal MPEG-2 encoder according to specs set in the Project Settings window.
Old 07-31-06, 03:22 PM   #27   |  Link
galaxy_jason
Jason Ware
OK, do you know of any compliant sources I can download to try out. Need
to use something that is known to work first before experimenting with new
material.
Thanks for the help and replies.
Old 07-31-06, 03:33 PM   #28   |  Link
Blasst
Blasst's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (1)
After reading the first thread on this authoring technique, I have a couple of questions still. Since I have a HC3 camera, I can go straight to Ulead since it is already in mpeg2, correct? When I get to Nero to burn, I am not getting the . "In the "Options" pull-down or checkbox, select "Enable Xbox (TM) compatibility mode." The option is not there. Could anyone give a man down some pointers? Thanks.
Blasst is offline   Reply With Quote
Old 07-31-06, 03:50 PM   #29   |  Link
pteittinen
A Swollen Member
OK, do you know of any compliant sources I can download to try out. Need to use something that is known to work first before experimenting with new material.
You could try Ron's test patterns at http://www.w6rz.net/
Old 07-31-06, 03:56 PM   #30   |  Link
pteittinen
A Swollen Member
You visited the Multisession tab and selected No Multisession first, right?
Joe, a brief edit to the guide: it's an Options pull-down, not a checkbox.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.40886092 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
