AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
View Poll Results: How reliable has your XBR960 been?
I have had no problems or glitches whatsoever. 62 58.49%
I have had a minor problem or glitch, but it did not repeat or happens infrequently 27 25.47%
I have had serious reoccuring problems and glitches 8 7.55%
My TV died, and needed to be replaced or repaired 9 8.49%
Voters: 106. You may not vote on this poll
Forum Jump
Old 08-02-06, 09:55 AM   #1   |  Link
RWetmore
KD-34XBR960 reliability
I'm trying to get a sense of the reliability of this set. If you have had problems, try to specifically identify them. Thanks.
RWetmore is offline   Reply With Quote
Old 08-02-06, 10:57 PM   #2   |  Link
RWetmore
Feel free to post comments (this will keep the thread and the poll going!). Thanks.
Old 08-05-06, 01:59 PM   #3   |  Link
RWetmore
To the top
Old 08-07-06, 08:43 PM   #4   |  Link
RWetmore
I want to keep this going
Old 08-07-06, 10:08 PM   #5   |  Link
Mathesar
My first XBR960N came out of the box with a couple flaws , the contrast would bloom much earlier than it should (for example white text would start looking blury with the Picture setting at 30),it also had a noticable 'flicker' effect when viewing 720 or 1080i sources which was confirmed not normal by a sony tech visit, instead of having it worked on I returned it for another XBR960N.
The replacement looks much better in fact I can crank up the contrast to near max without any blooming (I dont leave it turned up that high tho) ,also this one doesnt have any flicker issues. The only downside is the replacement has worse geometry in the corners, especially in the bottom right corner but it hasnt been a big issue, also Ive experienced the infamous wont power on symptom which was fixed simply by unplugging it for a minute,this has only happened once in the 6 months ive had it.
Mathesar is offline   Reply With Quote
Old 08-08-06, 10:52 AM   #6   |  Link
mortaldivine
My TV blinked/flashed every 5 min when I got my tv. Repair man had to come out and fix it. Then theres the ghosting which is really annoying, dark side of the screen , non-uniform brightness across the screen , and my tv could go for some convergence and geometry touchups. Oh and I almost forgot, the new light blue tints appearing on the corners of my screen.
nurfed
mortaldivine is offline   Reply With Quote
Old 08-08-06, 03:08 PM   #7   |  Link
CR_Client
No problems whatsoever. Or, if I've had any problems, I haven't seen them.
One or two minor geometry things that aren't worth calling a "problem", as they could easily be fixed by an ISF calibration, which I have neither the time nor money for.
CR_Client is offline   Reply With Quote
Old 08-08-06, 05:09 PM   #8   |  Link
Q of BanditZ
HD Enthusiast
Not two years yet, but so far...all good.
__________________
Great ISF Job by Chad B.
Q of BanditZ is offline   Reply With Quote
Old 08-08-06, 05:54 PM   #9   |  Link
calguy99
New Member
Originally Posted by Mathesar
a sony tech visit
Is a Sony tech visit covered as part of the warranty. Will they come out and calibrate your display if you are not happy with it as part of the warranty?
__________________
(Insert really cool sig file here)
calguy99 is offline   Reply With Quote
Old 08-08-06, 05:55 PM   #10   |  Link
iamhives
Flashing like Mortaldivide after the TV warmed up. whcih developed after maybe 6 months o ownership. Involved the repairman replacing the insulation with RTV 106 silicon sealer/insulation around the pins at the back of the tube. He said its a relatively common problem and basically a manufaturing problem with the insulation that causes arcing after the TV warms up enoug. Sony is very aware of this as there is a technmical service bulletin that addresses this exact symptom very specifically. Sort of annoying to have to get my neighbor to help lift the TV up/down from/to a high armoire where the TV is placed on different days.
But its fixed now and looks beautiful
iamhives is offline   Reply With Quote
Old 08-09-06, 11:18 AM   #11   |  Link
epiphane
My's a 910...close to 3 yrs old w/o any problems...
...as I look towards the ceiling with fingers crossed...
Cheers
epiphane is offline   Reply With Quote
Old 08-10-06, 10:14 AM   #12   |  Link
CCMOO
After owning my unit three weeks, I had one vertical black line that appeared one morning, disappeared after an hour, and never came back. Other than that, it's been terrific.
CCMOO is offline   Reply With Quote
Old 08-15-06, 12:39 PM   #13   |  Link
RWetmore
Let's keep this going.
Old 08-19-06, 10:47 AM   #14   |  Link
RWetmore
and going....
Old 08-19-06, 01:16 PM   #15   |  Link
sphinx99
Mine lasted a few weeks before it wouldn't turn on anymore. Furthermore, having gotten used to geometry and conformity conveniences of digital display devices, my '960 was chock full of geometry issues and non-uniform color. I definitely got the sense of "pushing the technology a little too far" from my experience. I also surveyed at least a dozen floor models before purchase and was surprised that every one of them had bowing, color spots, or some other malady--problems pretty much absent from all other displays I'd seen, even other, cheaper CRTs. I'd bought it anyway in spite of this, and learned my lesson...
Very confusing. I was expecting an ownership experience a little closer to the 24" computer CRTs I used to have.
sphinx99 is offline   Reply With Quote
Old 08-19-06, 07:34 PM   #16   |  Link
Mathesar
I still use a 24" Sony PC CRT (GDM-FW900) and would have to agree ..If only the XBR960 could have the same near perfect geometry and convergence as one of these units ..in fact ive never seen a CRT with such straight geometry / corner to corner focus / convergence , But Im still very happy with my XBR960 and at least it doesnt suffer from any color blotch issues.. I do wish it wasnt so dark when viewing HDTV channels ..I have to really crank up the brightness to eliminate black crush on mine but this seems like a common complaint with XBR960 users, but I notice some channels are brighter than others so maybe I shouldnt blame the TV.
Old 08-19-06, 10:06 PM   #17   |  Link
RWetmore
The best way I have found to eliminate the black crush is to find an accurate greyscale with the highest _DRV and _CUT settings possible. Start by putting RDRV and RCUT all the way up to 63, then just adjust BDRV, BCUT, GDRV, and GCUT keeping RDRV and RCUT at 63. The _CUT and SBRT (brightness) adjustments on my set definately have a non-linear relationship to one another (in fact virtually no relationship at all according to my test patterns) With high _DRV and _CUT values, you can achieve better shadow detail without washout.
Old 08-20-06, 09:49 AM   #18   |  Link
Mathesar
Thanks for the tip Ill give that a try.
Old 08-20-06, 09:35 PM   #19   |  Link
MotorCityJoe
I just got my XBR960 about a week or so ago. No problems whatsoever.
MotorCityJoe is offline   Reply With Quote
Old 08-22-06, 12:26 PM   #20   |  Link
joebxr
9 months of pure pleasureable TV viewing and not a single problem. Love the look on friend's faces when they see the beautiful picture quality.
joebxr is offline   Reply With Quote
Old 08-25-06, 06:44 PM   #21   |  Link
RWetmore
To the top...
Old 08-26-06, 02:44 PM   #22   |  Link
ncstatesman
keep it going baby!
I'm looking to get the '970 as the 960's are no where to be found in some warehouse
ncstatesman is offline   Reply With Quote
Old 09-02-06, 09:39 PM   #23   |  Link
RWetmore
to the top again...
Old 09-04-06, 02:15 PM   #24   |  Link
darusgrey
I've had an infrequent problem with my xbr960, ussually every few months I'll turn it on and no picture will display even though theres sound, etc.
I unplug it from power, wait 10seconds, plug back in, and works.
It happens so infrequently that its not much of a concern, though its happened total of 4 times now over the almost 2yrs I've had it.
darusgrey is offline   Reply With Quote
Old 09-04-06, 03:21 PM   #25   |  Link
julio388
sony superfine pitch technology is known to be prone to reliability issues. Thats why sony decided to get rid of it. sorry guys if the supefine pitch was such a great technology why did sony left it out in 970 xbr. To many complaints of picture failures.
julio388 is offline   Reply With Quote
Old 09-04-06, 03:29 PM   #26   |  Link
MotorCityJoe
^^Dude stop trolling. Your statement is NOT consistent with this poll at all. This poll was created for XBR960 owners to state specific problems/no problems related to this model. It is NOT intended for people to come in and give their 'opinions' on why they think SFP is no longer included in newer models.
Old 09-04-06, 04:52 PM   #27   |  Link
julio388
dude the truth hurts. sony super fine pitch was a failure. scraped by sony because of reliability issues. can you answer one simple question? where is the superfine pitch tube today? if sony had such a great technology, unique "superfine pitch" why would they leave it out on 970xbr. Truth the technology was not mature enough to be ready for prime time. sony rush it to the market because they was losing market share to lcd and plasma. remember 910xbr then 960 xbr sony revised the technology because of technical issues. new phosphors , new electron gun, grill, etc. but there were still reliability issues. the cost to manufacture the technology , to bring it to the market was not there. sony panic to stop the bleeding of there crt division by rushing a tecnology that was simply "not ready for my close up". the truth is out there.
Old 09-04-06, 09:15 PM   #28   |  Link
RWetmore
Man...chill out. There are a whole number of possible reasons why Sony may have decided not to include the SFP in the 970. The most obvious is likely due to the simple cost/competition ratio of the current landscape. With many display technologies coming down in price significantly, the SFP tube is no longer a cheaper alternative for similar size LCD sets, and thus Sony may have concluded it wouldn't sell well. The 970 is a significantly cheaper alternative than similar sized LCD sets; the SFP is not (in many cases it would be more expensive). In the end, I suspect Sony pulled the SFP simply because there wasn't a big enough market for it, and it wasn't profitable, especially with CRT going extinct soon anyway.
Old 09-05-06, 10:04 PM   #29   |  Link
Mathesar
I agree 100% , Im just glad I got my hands on an XBR960 just before it was discontinued, despite minor geometry issues it has a truely amazing picture,Im still in awe when watching HDTV channels
Old 09-05-06, 10:34 PM   #30   |  Link
julio388
you have been warn, sooner or later you will start to have problems. unreliable. The truth is out there.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.32723403 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
