#1 | Link |
Question about RG-6 vs. RG-59 cabling for HDTV quality
So in my new house the cable outlet that where my TV will connect to is RG-59 cabling (or so the Time Warner installer said so). I need to connect the cable via a female type "F" adapter to a longer cable to connect into my cable source down in the basement. So I went out and bought a female F adapter and RG-6 cable. In reading about RG-59 and RG-6 cabling, I am beginning to wonder if this setup will affect my HDTV quality?
I have a 42" Sony 3LCD projection HDTV that runs off of it. I went out and bought all of the equipment and hooked it all up and I can't reaaally tell the difference between RG-59 or RG-6. There's no way for me to tell if using a complete RG-6 cable solution the entire way will make enough of a difference to notice. Does anyone know if I will get a noticeable quality difference between an RG-59 to RG-6 solution compared to a complete RG-6 setup? I would really appreciate it. Also how do I tell if the cable is RG-59 or RG-6? |
#2 | Link |
Unless the signal is really marginal to start with, you won't see a difference between RG-6 and RG-59 assuming they are of equivalent quality. The difference in signal level is only a few dB per hundred feet. The cable may be marked RG-6 or RG-59. If not, RG-59 is around .233" diameter and RG-6 is around .274", varies a bit depending on manufacturer, shielding, etc.
#3 | Link | |
I just want to make sure I'm set with the signal quality before I run this cable over the finished basement ceiling. ![]() |
#4 | Link |
Beatle Fan
rg6 vs rg59: Suprax, I would run the 6 any time you can get a chance to replace the wire. The first thing my cable provider did when I switched to HD was to change the wire coming from pole to house to RG6. Had to run new wire upstairs with amp for a strong HD signal. I have 2 HD tv's and all RG6..hope this helps..
#6 | Link | |
Like I mentioned earlier I have a RG-6 outlet in the same room and I compared the 2 today and to be honest I really can't see any difference. The overall HD signal looks a TINY bit less sharp than at my last place so that's probably just the cable signal to my house. |
#7 | Link |
And if I can piggyback another quick question. When putting the end on a cable, does it matter the amount of metal sheathing is touching the connector part or not? Is the only important part the actual wire in the middle of the cable? When I made the cable today, it didn't come out very pretty but seems to work fine.
#8 | Link |
Beatle Fan
try to cut as much of the metal sheathing away as possible. I use the twist on connectors. Here is a link to the amp that my cable company put in for me before the upstairs run.. http://www.antronix.net/Products/cat...amplifiers&i=5
#9 | Link |
I shoot people 4hire
AVS GOLD CLUB MEMBER
RG6 has wider bandwidth and having it vs. RG59 will give you greater options, especially if you wish to use that cable for a sat feed some day. For component video it really doesn't matter. If one can detect a differece here, then I would be looking for some screwup in the RG59. RG59 OK for video and Off air TV antenna. OK for cable too but the RG6 has better shielding and is stronger. If your area is prone to bleed thru on cable then switching to 6 will be a step in the right direction. New installs and replacing, always RG6 but only to increase your options.
__________________
Don |
#10 | Link | |
AVS CLUB MEMBER
RG6 vs RG59 .... I was advised NOT to use some RG6 - it "won't work"
See the bottom of the page on the forum topic :
RG 59/u vs. RG 6/u...is there a big difference?? http://www.avsforum.com/avs-vb/showt...7&page=1&pp=30 Also posted a link to a FAQ which states "RG6 Dual or Quad Shield should not be used for base band applications such as video projectors, plasma TV’s, component video, etc. ......." A friend advised that "Steve ,I reiterate,rg6..will not carry hdtv signals..you must use rg59(a particular style)hdtv..and it takes 3 per tv,for video only." I know three cables are needed for video. Could someone illuminate me with some links to further advice or provide some detail as to what cable to use for HD via component ? Thanks kindly, Steve D. |
| Bookmarks |
| Thread Tools | |
