AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Subwoofers, Bass, and Transducers
Forum Jump
Old 08-07-06, 05:50 PM   #1   |  Link
kvillella
New Member
Need help with a Sub here.
I just recently bought this on ebay:
Sony Dream System Sub-woofer Model SS-WS5
and it doesnt have a power in/out cord. What exactly does this mean? does this mean that it runs off the power from the speaker wire? I am really confused about this? Can someone please answer? thanks
kvillella is offline   Reply With Quote
Old 08-07-06, 06:16 PM   #2   |  Link
RTracey
If it doesn't have a power cord, that means it's a passive subwoofer - in other words, it's dependent on your receiver/amplifier to power it. I'm pretty sure that means it won't work off the LFE/sub-out channel from the receiver/amplifier - you'll have to connect it to one of the speaker connections.
Ross
RTracey is offline   Reply With Quote
Old 08-07-06, 06:42 PM   #3   |  Link
kvillella
New Member
AHHH, ok, ill try that, I think my recevier has a sub R/L speaker connections. you think it'll work?
Old 08-07-06, 06:53 PM   #4   |  Link
RTracey
probably, but only way to find out is try them.....
Ross
Old 08-07-06, 07:26 PM   #5   |  Link
Kal Rubinson
Small passive 4ohm subwoofer. See http://cgi.*********/ws/eBayISAPI.dl...tem=5869624606
Kal
__________________
Kal Rubinson
"Music in the Round"
Contributing Editor, Stereophile
www.stereophile.com/musicintheround/
Kal Rubinson is online now   Reply With Quote
Old 08-07-06, 07:30 PM   #6   |  Link
ransac
Knows more than you?
It is a passive sub and won't work with the LFE out from your AVR. It needs an amplified signal, so you have to connect it to your mains output. I can't find anything else about this sub, so you have to look at the connections and controls and tell me what you see.
__________________
Randy
ransac is offline   Reply With Quote
Old 08-07-06, 07:38 PM   #7   |  Link
Kal Rubinson
All it seems to have is a pair of spring-lock terminals. It needs an amplifier to drive it.
Kal
__________________
Kal Rubinson
Old 08-08-06, 11:43 AM   #8   |  Link
kvillella
New Member
I thought the AVR would act as the amplifier. Am I wrong?
btw, thanks for the help.
Old 08-08-06, 12:21 PM   #9   |  Link
PLincoln
Classified Rating: 100% (1)
the AVR only supplies a low level signal out of the LFE output
PLincoln is offline   Reply With Quote
Old 08-08-06, 05:28 PM   #10   |  Link
kvillella
New Member
ok, thanks for all your help.
Old 08-08-06, 05:35 PM   #11   |  Link
cyberbri
Most regular receivers don't have amplification for the subwoofer. Most subwoofers are powered, with the amp on the back. You got a passive subwoofer, no amp, that came from a HTiB system that ran off of an amp channel in the system's receiver. You can run it off of a channel of the regular receiver, but then you can't hook a speaker up there. Basically it's junk unless you pick up a separate mono amplifier to run it.
cyberbri is offline   Reply With Quote
Old 04-07-07, 10:46 PM   #12   |  Link
Gujustud
I'm wondering the same thing. I've got a STR-DE915 amp in my bedroom connected to my computer. I'm only running two fronts from it.
If I get this sub, would I get more power from connecting it to the terminals where the fronts are connected, or should I connect it to the rear channels, or the B channels (and run A+B)?
Gujustud is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14521599 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
