AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Audio theory, Setup and Chat
Forum Jump
Old 08-28-06, 04:41 PM   #1   |  Link
Ingeborgdot
Question on ups for ht.
Is anyone familiar with the Belkin AP30800-10 ups? Also the APC model J10 or J15 power conditioner with backup? Which is better? I don't have anything to see to compare, just numbers I see on the web to compare. I know the Belkin has 8 outlets w/6 for ups and other 2 for surge. The APC has 12 for ups as far as I understand w/ it being a conditioner also. Does Monster Cable make anything in these two price ranges that compare? I doubt it as they are much more expensive but I am just asking. Thanks.
Ingeborgdot is offline   Reply With Quote
Old 09-01-06, 02:01 PM   #2   |  Link
Glen B
I recently bought a Belkin 30800-10 UPS. Its an attractive unit and works well but its transformer hums all the time (YMMV). I have a CRT TV, Onkyo 5.1 receiver (running 3 of the 5 channels), DVD recorder, wireless switcher and two cable boxes plugged into the UPS backup outlets. One thing I'm very sensitive to and find very distracting and annoying is transformer and fan noise. It gets so quite at my house that one night when in bed I kept hearing a hum that was keeping me from falling asleep. Upon further investigation, I realized that it was the hum from the Belkin unit that was travelling up to the bedroom upstairs. I have tried installing some padding under the tranny but that didn't seem to help. I'm going to try some additional padding and see if that works.
Glen B is offline   Reply With Quote
Old 03-11-07, 04:30 PM   #3   |  Link
ValueDriven
New Member
Me Too on Belkin AP30800-10
I recently purchased the BELKIN PureAV AP30800-10 Surge Protector/UPS. It hums for me too! It's not real loud. Noticable when everything, except the AP30800-10, is turned off for the night. Contacted Belkin & they claim that it is not normal. Anybody else have experience with this unit? Does yours hum? What did you do, or what did Belkin do/suggest? Thanks
ValueDriven is offline   Reply With Quote
Old 03-11-07, 09:37 PM   #4   |  Link
Kal Rubinson
When i reviewed the unit a year or so back, I asked Belkin and I was told the hum was normal. From the posts here, it seems so.
__________________
Kal Rubinson
"Music in the Round"
Contributing Editor, Stereophile
www.stereophile.com/musicintheround/
Kal Rubinson is offline   Reply With Quote
Old 03-11-07, 10:18 PM   #5   |  Link
jwatte
It's all good!
What are you getting the UPS for? If it's actually to drive a power amp during a power outage, you need a high-wattage unit (1500 VA or up would be ideal). If it's for power conditioning, then read on.
In general, a consumer-grade UPS will not power the line using the batteries. When the power goes out, they will turn on the batteries and inverter, and use a stepper function to simulate something that looks a little bit like a sine wave for AC. However, the signal has tons of harmonics, compared to pure AC power, so when you're on battery, expect 60 Hz (and harmonics like 120, 180, ...) buzz in your system.
High-grade UPS-es (typically costing thousands) will continually charge batteries, and continually pull power from the batteries, inverting to AC. They may also synthesize real sine waves using basically a really large oscillator. These guys can actually help a lot if you have very dirty power, because the rectifier and then the inverter basically act as a very, very steep filter for interference. That's not something you'll see from a $300 consumer unit, however.
A UPS may also be coupled with a power conditioning device, which is intended to remove harmonics from the incoming AC signal. This can help if you have really noisy power lines, and a weak power supply in any of your components. However, the fact that the consumer-grade devices come with power conditioning and UPS in the same unit, does not mean that it's an online, sine-wave, "active" UPS.
If what you want is clean power, I suggest focusing on some power conditioning unit. I've got an order in for the 1000 VA balanced power supply with conditioner from Transcendent Sound, and I can let you know how it works once I build it (got the kit) and actually get my remodel done (so it'll be two months or so). Or you can go ask others in the same situation for recommendations.
jwatte is offline   Reply With Quote
Old 03-14-07, 09:18 PM   #6   |  Link
WallyWest
I have an APC unit I use only for my TV. Because my convergence goes back to default settings when the power goes out. As well as some other custom settings.
Anyway, it doesn't hum at all. Completely silent. I've always liked APC stuff, but most of my experience with them has been related to computers.
WallyWest is offline   Reply With Quote
Old 03-14-07, 09:23 PM   #7   |  Link
loudog2
So if I have a pureav pf60, should I just get a 2-4 outlet ups? Then connect it into the pf60?
loudog2 is offline   Reply With Quote
Old 03-16-07, 07:48 PM   #8   |  Link
jwatte
It's all good!
If you have a PF60, you could get a 1500 AVR UPS, and then plug the PF60 into the UPS. The UPS will emit somewhat non-clean power, so the PF60 after the UPS will filter that out.
I've used CyberPower, APC and various no-name UPS-es, and prefer CyberPower (but YMMV).
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14201188 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
