AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 08-30-06, 08:27 PM   #1   |  Link
KillerBox
:) Anyone around here got the remote codes for a Mickey Mouse TV and DirectTV?
My son has one of those Tube 13" Mickey Mouse TVs and a new DirectTV control box. I read somewhere on the internet that the TV was made by Memorex but, I tried all of the codes from DirectTV for Memorex and could not get it work. Does anyone have any suggestions?
KillerBox
KillerBox is offline   Reply With Quote
Old 09-01-06, 11:31 PM   #2   |  Link
cbane
If you still have the original remotes..... just use those.
__________________
Corey
Sound Home Theaters
Authorized Fujitsu Plasma Dealer
Custom Remote Programmer
San Diego
cbane is offline   Reply With Quote
Old 09-01-06, 11:50 PM   #3   |  Link
Edmund
If this is the white dtv remote, do a codesearch:
1. Tv
2. press and hold MUTE & SELECT for two blinks
3. enter 991,wait for two blinks
4. enter 1
5. keep pressing and releasing CH UP key, if and when the TV powers off
6. press SELECT to lock in code
Edmund is offline   Reply With Quote
Old 10-12-06, 03:22 PM   #4   |  Link
Edmund
Try codes 10178, 10171, and 10463.
Old 05-11-07, 11:52 AM   #5   |  Link
gthorson
Having the same problem as Killerbox. The codes from Edmund did not work. Any other suggestions?
Greg
gthorson is offline   Reply With Quote
Old 05-11-07, 11:56 AM   #6   |  Link
Edmund
Greg
How did you test the codes by pressing TV ON & OFF keys? Well use the middle power key in the tv device, along with try all other keys.
The equivalent tivo remote codes to the codes I posted in this thread helped other Disney tv owners:
http://www.tivocommunity.com/tivo-vb...d.php?t=317947
Tivo code 0008= UEI code 10171
Tivo code 0091= UEI code 10463
Old 05-11-07, 01:08 PM   #7   |  Link
gthorson
Thanks, Edmund. It turns out the problem was actually with my RC23 remote. Once I reset it, it accepted the 10463 code. That code effectively controls the Mickey Mouse 13" TV on both the R15 and HR20 receivers. Now I need to work on the Mickey Mouse DVD players...
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12778401 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
