AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 09-21-06, 04:37 PM   #1   |  Link
codester
New Member
IR codes for Direct TV HR2700
Does anyone know if the know Direct TV HR2700, mpeg 4 receiver, use the same ir codes as the older one?
codester is offline   Reply With Quote
Old 09-21-06, 04:46 PM   #2   |  Link
Edmund
Its the HR20-700, and it uses the same IR commands as the D10, D11, R15, H10, and H20. All DIRECTV branded, so no other named brands sat code will work.
Edmund is offline   Reply With Quote
Old 09-21-06, 04:52 PM   #3   |  Link
codester
New Member
Old 11-04-06, 09:22 PM   #4   |  Link
agtrader
New Member
I have a Sylvania TV/DVD HD tv. I'm on Direct TV and my box is a model D 10. I can't get my Direct TV remote to operate my TV functions. I programmed the AV 1 button on the Direct TV remote to turn on/off my TV but it still does not control sound or channels.
Any suggestions?
Tkx
agtrader is offline   Reply With Quote
Old 11-04-06, 10:20 PM   #5   |  Link
Edmund
Any suggestions?
Tkx
With the code that gave partial control programmed, try the following: First there needs to be tv code programmed to the tv device. Then:
1. av1 or av2
2. press and hold MUTE & SELECT for two blinks
3. enter 9-9-3
4. press SELECT
Old 11-25-06, 08:52 PM   #6   |  Link
rgathright
AVS CLUB MEMBER
Location: Pearl River, La. is home, but working in the Houston area
So what is the H10 code? I have a Theater Master SL9000 remote
rgathright is offline   Reply With Quote
Old 11-25-06, 11:17 PM   #7   |  Link
Edmund
Well it doesn't matter because you're out of luck anyways. The whole current line of directv receivers all use the same codeset, this codeset didn't exist before 2004. So your 10 year old remote doesn't have a code.
Old 03-17-07, 06:58 PM   #8   |  Link
fmshrink
New Member
Question hr20-700
i couldn't find a thread or other information on the hr20-700 (other than the directv descriptions). i'm looking to upgrade my hr20. any information or recommendations on the hr20-700 would be appreciated.
fmshrink
fmshrink is offline   Reply With Quote
Old 05-09-07, 06:20 PM   #9   |  Link
ifanpayne
New Member
I wan to program my MX500 universal remote. What are the codes for the Hr20 700 or where can I find them?
ifanpayne is offline   Reply With Quote
Old 05-09-07, 06:37 PM   #10   |  Link
Edmund
sorry the mx-500 is too old, you'll have to teach.
Old 05-09-07, 06:39 PM   #11   |  Link
cal87
AVS GOLD CLUB MEMBER
Classified Rating: 100% (9)
I'm not sure if this applies to your remote, but for my MX3000, I used the pre-programmed codes from the URC database included with the software for the H20 which also includes power on and off. Works fine.
Edit: just saw the post above.
cal87 is offline   Reply With Quote
Old 05-13-07, 03:36 AM   #12   |  Link
peugenio1914
how would i go about setting up an LCD button for menu items like the To Do List, Prioritizer, etc? there aren't remote buttons for these and i usually get to these by navigating onscreen menus. i'm trying to setup my harmony 880.
peugenio1914 is offline   Reply With Quote
Old 12-21-07, 06:16 PM   #13   |  Link
msiebert
New Member
DTV Remote
How do I program the DTV remote to separately control two different DTV receivers?
msiebert is offline   Reply With Quote
Old 12-21-07, 06:51 PM   #14   |  Link
Edmund
Receivers like the D11, r15, H20 use codes 00001 & 00002. where HD DVR models Hr20/ HR21 use 00001 & 00003. 00001 in each case are the same.
start by programming either 00002 or 00003 to the av1 or av2 device on the white oem remote. slide back to SAT device and enter the menu:
1. menu> settings> setup> remote> receiver mode>
2. you will see either Directv or Av1/Av2, click whichever to reveal both
3. press Av1/Av2, the remote will no longer control the receiver, slide to av1 or av2
4. press DONE and exit the menu
You can leave the SAT device programmed with code 00001 and the av1 or av2 programmed with alternate address and control two receivers with one remote. Or you can program the SAT device with alternate code, and change av1 or av2 to whatever you wish.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.17492104 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
