AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Subwoofers, Bass, and Transducers
Forum Jump
Old 10-03-06, 08:33 PM   #1   |  Link
Spezzy
16 Y/O DJ-Audiophile
High SPLs with deep (12hz-15hz) extension?
I recently got myself into DJing and have loved it so far. Making quite a bit of money. Currently bringing my DLS-5000R with me since I don't want to buy dedicated subwoofers just for DJing since I'll be dropping it in a few years. I've been recommended the Danley DTS-20 since that supposedly has alot of output and deep extension. Reason I still want the sound quality and extension is I'm still going to be using this in my house. Are there any other subs out there with as much power and extension as the DTS-20 for around $3500-$4000? I really don't want to spend much more that $2500 though, but if it is something I can keep for years to come I'll buy it.
Spezzy is offline   Reply With Quote
Old 10-03-06, 11:57 PM   #2   |  Link
SteveCallas
American Gladiator
Does it have to be premade or are you willing to build it?
__________________
My Setup
LLT Explained
SteveCallas is offline   Reply With Quote
Old 10-04-06, 06:35 AM   #3   |  Link
Nick Danger
Horn Lover
I'd take a look at the rest of the Danley line ... They have some smaller units with similar output, perhaps not 100%, but very respectable.
Nick Danger is offline   Reply With Quote
Old 10-04-06, 06:43 PM   #4   |  Link
Spezzy
If I can beat those specs and have it cheaper I could build it.
Old 10-04-06, 08:37 PM   #5   |  Link
crackyflipside
Bass Addict
Then browse the DIY section.
You know you want to...
crackyflipside is offline   Reply With Quote
Old 10-04-06, 08:39 PM   #6   |  Link
Pradeep
Given that you want to transport it to venues, I would think a 7ft tall sonosub would be a little too large
The Danley would be hard to beat for the performance and enclosure size.
Pradeep is offline   Reply With Quote
Old 10-04-06, 11:02 PM   #7   |  Link
billybob_jcv
Doh!
I wouldn't try to do this with one unit. IMHO you don't need 12-15 hz in a DJ sub. You could DIY a DJ sub that rocks at 30 hz and is transportable, then either use the Danley or another DIY sub that stays in your theater and can be as big as you need to hit 12 hz.
__________________
If you think this post was dumb, you really should read my blog=> http://bumpedhishead.blogspot.com/
billybob_jcv is offline   Reply With Quote
Old 10-04-06, 11:33 PM   #8   |  Link
theirishgonzo
Location: third star to the right and strait on till morning
i have 4 avalanch 18 in a ib and driven with 3200 wats from a qsc amp
subs were 400 a piece
amp was 1k
120 db@12hz priceless
__________________
if you are lucky enough to be irish you are lucky enough
theirishgonzo is offline   Reply With Quote
Old 10-04-06, 11:42 PM   #9   |  Link
billybob_jcv
Doh!
Isn't it a little hard to move your house to every DJ event?
__________________
Old 10-05-06, 12:31 AM   #10   |  Link
Exocer
I like speakers!
Classified Rating: 100% (1)
I totally agree with you billybob.High SPL Infrasonic bass for Dj work seems like a waste...
You should probably build something cheap that provides plenty of output from 30hz up, with no expectation of using it in your HT of course.
When you're done with DJing, sell those subs off and build something specifically designed for your HT.
__________________
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW!
-Rob
My Natalie P project
Exocer is offline   Reply With Quote
Old 10-05-06, 03:23 AM   #11   |  Link
kesa32
what about the LAB 12's
go pretty hard and better suited to your needs
kesa32 is offline   Reply With Quote
Old 10-05-06, 10:30 AM   #12   |  Link
cecaa850
amp was 1k
Ditto;
I have the same drivers with a different amp. With less than 2k invested, I can hit 110 dB at 10 Hz at my seated position which is 14 feet away from the drivers.
__________________
120@20@14'
cecaa850 is offline   Reply With Quote
Old 10-05-06, 06:34 PM   #13   |  Link
Spezzy
amp was 1k
Where could I find these Avalanche 18s? And what do you mean by IB?
Old 10-05-06, 07:03 PM   #14   |  Link
Spezzy
Not really going for the LFE for DJing, but for the sound quality. It's whats seperating us from the other companies in our area.
Does the DTS-20 have more output than say 2-4 DLS-5000Rs?
Old 10-05-06, 08:16 PM   #15   |  Link
spyboy
Spets
10 DLS-5000's won't get you much response below 25Hz. So, you need to know whether you are interested in a ton of output in the 35-100Hz range, or less output in that range and much more output from 25Hz down to ~12Hz, which the Danley. The Danley will be absolute killer for home use.
spyboy is offline   Reply With Quote
Old 10-05-06, 08:55 PM   #16   |  Link
Spezzy
But output wise, which would be the absolute killer?
Old 10-05-06, 09:43 PM   #17   |  Link
Willd
Willy
You could get a single high performance PA driver from TC-Sounds, put it in a vented box tuned around the low-mid twenties, and get seriously nice output and SQ.
Willd is offline   Reply With Quote
Old 10-05-06, 11:20 PM   #18   |  Link
Spezzy
Thanks guys, I'll look into the DIY option through TC sounds. Would it still be reasonable for HT use?
Old 10-05-06, 11:25 PM   #19   |  Link
Willd
Willy
Very resonable...
Old 10-06-06, 09:13 AM   #20   |  Link
cecaa850
Read about IB here:
http://ibsubwoofers.proboards51.com/index.cgi
Avalanche 18's haven't been made in about a year or so, however Ascendant Audio will be putting a few up on e-bay in the next week or two.
__________________
120@20@14'
Old 10-06-06, 11:02 AM   #21   |  Link
Mark Seaton
Mark Seaton's Avatar
AVS CLUB MEMBER
Get a real sub for pro use that actually gets low. A DTS-20 would not be fun to transport. 4 of the DLS-5000s would probably keep up with a DTS-20 above ~35Hz, but below there the DTS-20 will run away with the show.
First understand that most pro subs have rediculously generous/creative specifications so far as low frequency extension. If you really want something portable and hugely impressive, pick up one of the Danley TH-115s. It has handles and integrated wheels and is a rather managable package to move in a large vehicle. If you have the space and the budget, a pair of these and a cheap but respectable pro amp will get you noise complaints reguarly while getting MUCH deeper, louder and cleaner than anything people are hearing in most clubs or from other DJs. These are 10x more efficient than the DTS-20s in the range they operate, and while the super deep stuff is fun, for DJ'n these would be the way to go. I believe they cost less than the DTS-20 as well at $2250-2500 last I had heard. Get a good pro amp and you are ready to roll. The Crown XTi series of amplifiers have EQ and crossover functions on-board and will get you rockin' & rolling.
You might also want to see if you can hunt down a Yorkville dealer and check out the Unity Series, U15 that uses a liscenced design of Tom Danley's. For the money and size, there isn't much that sounds better. Prop them on top of the TH-115s and you are good to go. If you splurge just a little more you could even get a pair of the Danley SH-100s which would also do very well.
Don't bother with most home products for continuous DJ use!
__________________
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline   Reply With Quote
Old 10-06-06, 12:32 PM   #22   |  Link
Stereodude
Listen to Mr. Seaton...
He knows bass!
Stereodude is offline   Reply With Quote
Old 10-06-06, 07:30 PM   #23   |  Link
Spezzy
Thanks, I'll have to look into all of that.
Reason I still might consider the DTS-20 (self powered version) is I can get it used a bit from a friend for $2700 and I don't have to pay for shipping. Can the Crown XTi 1000 run 2 TH-115s hard enough or should I look at the more powerful ones?
Old 10-07-06, 10:44 AM   #24   |  Link
Ivan Beaver
Danley Sound Labs
I agree totally with Mark Seaton. You will probalby be dissappointed if you try to use the DTS 20 for DJ type music. Not that it will sound bad-It sound great with music and special effects, but it just won't get as loud as you probably need it to, unless you are doing very small events. Just moving the thing is a beast.
Why is your friend selling his? Just curious.
When you say loudest, you HAVE to say at what freq your are interested in. Without that spec, everything is meaningless-at least to those who really care. If all you want is LOUD, then use an Community M4 driver. It will get stupid loud, but only in the midrange area. Not very good for bass, but it is loud. You have to tie a freq to it in order for ti to mean anything.
For example, many manufacturers like to have seperate specs for the sensitivity and low freq capabilities of their cabinets. You HAVE to tie the 2 spec together to mean anything. There is one MAJOR manufacturer who rates their 2x18" cabinet sensitivity at 1800Hz. Is that really where you want to run your subs at? But it give a good high number that is real, it just doesn't do you any good.
Many times the low freq response (stated -3dB) is quite good looking, untill you really look at it. Often times it is 6-9dB below the rated sensitivity. How do they calim this-it all depends on how you interpet the numbers. If for example they claim +-3 dB as the response. This gives you a 6 dB window in which they can claim "flat" So the Sensitivity is actually at the very top of the window, and the "flat response is -6dB down from that. NOW you take another 3dB down to get the speced -3dB response. So it is really 9dB down from the peak. That is A LOT of power to make up-almost a factor of 10 X power.
You really have to look at the REAL specs if you want to get an idea of how they actually perform. You also need to know quite a bit about how the specs were actually measured, there are lots of games to play there also.
Danley uses quite conservative measurements-outdoor at a distance of 10M. Anybody with almost any type of measurement system can measure the same published specs. There are no special pulse tones, loading of mics or cabinets etc.
While the DTS20 is great for home, you need something that is quite a bit louder for DJ use. The TH115 would be great for a couple of reasons. Easy to transport, the loudest cabinet (that I know of) down at 40Hz, greater power capacity, easy to stack etc.
You can power them with any amp you want. You will get more out of them than other simular cabinets with the same power input because the sensitivity is so high. If you REALLY want to get the most out of them, I suggest something on the order of 2000Watts/cabinet. That is a BIG amp or you can use a smaller amp and bridge it. Just don't load it down below it rated BRIDGED impedance.
Be sure to use a Highpass filter (low cut) around 25hz. I prefer butterworth 24dB.octave to prevent overexcursion. Your low pass (high cut) will depend on the rest of your system.
Ivan Beaver is offline   Reply With Quote
Old 10-07-06, 04:46 PM   #25   |  Link
mynym
Check out a LAB12. It will give you some extreamly low bass and will out perform most quad sub 15 setups. Horns as you prohbably already know are extreamly efficient and LOUD.
mynym is offline   Reply With Quote
Old 10-07-06, 07:51 PM   #26   |  Link
Ivan Beaver
Danley Sound Labs
The TH115 is around 1/2 the weight and 1/2 the weight of the Lab 12. It also goes lower in singles than the Lab12.
Since he is wanting to only have a single sub for both purposes, the TH115 would be easier to tranport into his house and take up less space in his room.
The Lab 12 would be less expensive-assuming he has both the skill and tools to build it properly. It is not a beginners project. It also takes multiples to smooth out the freq response and go low. It is also a lower impedance so you cannot hook up as many to a single amplifier.
Old 10-09-06, 12:16 AM   #27   |  Link
Spezzy
I really don't know why he is selling it, but I think he is in a bit of a financial problem.
I thank you for your advice on the highpass filter and low pass filter, as I don't know too much about that.
I think I will go with a single TH115 and a Crown XTi 4000. If there is any more advice on an amp that isn't more than $1000 and can power the TH115s very well, please let me know.
I emailed EDA marketing a few days ago for Danley pricing but I still haven't received a response. Does anyone know how much or where I can buy a TH115?
Thanks for all the help so far guys.
Old 10-09-06, 09:05 AM   #28   |  Link
Ivan Beaver
Danley Sound Labs
I don't know why EDA hasn't responded to you. I am not sure if they deal with end users or just dealers.
You can get one from dB Audio & Video 770-534-7620. They are usually in stock.
Don't expect to do much price shopping with the Danley products. The selling prices are going to be within just a couple percent difference.
The TH115 will do fairly well in the home situation because of the high sensitivity. You can put a boost down low to pull up the deep bass. BUT DON'T do that when in a large room and pushing it. Of course, that applies to any loudspeaker.
Old 02-24-07, 03:25 AM   #29   |  Link
tberg73
New Member
hi
tberg73 is offline   Reply With Quote
Old 02-24-07, 07:55 AM   #30   |  Link
TC Sounds
You need something tuned at 25Hz, heck even 30Hz or 35Hz, it wil give you a lot more SPL in the areas matter more for what you are going to do.
its not about linearity or deep bass, its about filling a room with sound, and you need not concern yourself with anything below 25Hz
I would check out these bad boys, trust me
http://www.worxaudio.com/product_desc_true.php?id=62
http://www.worxaudio.com/product_desc_true.php?id=64
TC Sounds is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.30743909 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
