#1 | Link |
Large subwoofer next to my home theater equipment = problems?
I will have a 15" subwoofer pretty soon that I am building (which hits 117 db), and it will sit next to my entertainment unit which has/will have a Toshiba HD-A1, my computer, my 360, a PS3, a Wii, my receiver, and my DISH Network ViP622 DVR, and an equalizer. Many of the things I just mentioned have HD's in them. Can the subwoofer damage my equipment? My DVR specifically says "This product contains a Hard Drive which can be damaged by shock or vibration"
Do I have anything to worry about? Last edited by rocko1290; 10-05-06 at 04:39 PM.. |
#4 | Link |
Have you guys ever heard of a subwoofer damaging VHS tapes due to magnetic interference? I can put it to the left or right of my TV unit over towards the corners behind the speakers. One side is close to my storage unit for VHS/DVDs and the HTPC, the other corner is a few feet from the A/V rack with all the components on it. It's more out of the way over by the tapes, it would be a couple feet from them.
Not talking very large one, 8'' 100W nominal power. |
#8 | Link | |
Average Guy
It probably is going to depend on the size of the magnet, the shielding, distances. That said, a sub with a 8" driver shouldn't be that much of a threat over 2 or 3 feet away. |
#9 | Link |
When I first set up my HT, I had skips on my CD player when playing at moderately high volume. I resolved it by using a cheapo DIY dampening solution under the equipment.
Now that I also have a PVR and HTPC in the same area, I wonder what if anything is happening to the hard drive heads from the LF acoustic impulses. |
#11 | Link | ||
Why, what would happen to the bulb? There's no filament to break. Quote:
#12 | Link | ||
Knows more than you?
__________________
Randy |
#17 | Link |
[quote=Targus]Why, what would happen to the bulb? There's no filament to break.
Some of the least expensive units still use tungsten based bulbs (with filaments), however even the mainstream arc based MH bulbs with no filaments can suffer exlposive failures and strong vibrations while hot could supposedly aggravate that. (At least every projector manual I have read warns against exposing the projector to areas prone to excessive physical vibrations). |
#19 | Link | |
Aren't these what the DiY croud are using now? |
| Bookmarks |
| Thread Tools | |
