#1 | Link |
Polaroid 2001G HDD and DVD Burner Upgrade
I've been playing around with the Polaroid 2001G. I discovered that is was possible to do an easy plug and play HDD upgrade after reading the Polaroid thread on this forum. So I thought I'd give it a try. The Polaroid comes with an 80gb Western Digital drive. I was able to install a 200gb Seagate, a 250gb Western Digital, and a 500gb Maxtor.
My next step was to move the drives to the outside of the case. I thought making the storage removable would be pretty cool. So I ordered a two foot rounded IDE cable. With it still not delivered yet my impatience took over so I rigged the following today: - a one foot ide ribbon cable fished through the case - direct external power cable to power the HD drives - 500gb Maxtor HDD - 250gb WD HDD - 80 gb WD HDD Not pretty but it proves it does work. When the new ide cable arrives I will clean up the current installation. I also will add a removable drive enclosure to protect the drives. Here are the pics: 1- the drives 2- the "rigged" IDE cable fished through the case (ugly I know) 3- one of the HDD's sitting on top of the SA8300HD cable box (it's running with the Polaroid). 4- The 80gb drive running the Polaroid 5- The 250 drive running 6- The 500gb running The recording times shown are at SP (2 hour mode). The 250gb drive is almost full with 51 titles recorded to the drive. I can pretty much add storage at will. Last edited by nextoo; 12-26-06 at 10:39 AM.. |
#5 | Link | |
suplex
More than 234 Hours in SP Mode!!! Holy 500gb Hard Drive!
Boy am I thankful for people like you (nextoo) who experiment and then prove to us that it CAN be done. I have a Pioneer DVR-640 with a 160gb HDD, and although it really has been enough, I might like to toy with upgrading it someday. However I think the Polaroid is known for "allowing" itself to be upgraded where I have heard that some other brands may not work or "lock" themselves if you try anything. Also, with HDD's being less and less expensive these days, what a great upgrade you gave yourself with the 500gb HDD. Now you can just leave it on SP mode for good. What does it give you on it's longest Speed with 500gb, like 3 months?
__________________
Never Underestimate The Power Of Forums. |
#6 | Link | |
#7 | Link | |
#10 | Link | |
your next "mission"
Bob R. |
#11 | Link | |
Well done Nextoo...very brave. |
#13 | Link | |
#14 | Link |
Minor update here.
I decided to format the drive that originally came with the Polaroid under XP2. The process went as planned. After allocating and formating the drive under XP on a PC I put the drive back into the removable enclosure and booted the Polaroid. The Polaroid recognized the drive. I was able to use the drive as normal. Record, delete, etc. When I moved the drive back to the PC the drive was recognized. I had assigned the drive as letter Z under XP when I formatted it. This drive allocation was retained post Polaroid use. I thought I was almost home but even though the drive is recognized, when I open the drive window under explorer no files are listed. It is as if the drive is empty. Getting closer. My goal here is to be able to move the hard drives to a PC so I can move and edit files. I want to eliminate the step of burning to an optical disc in order to get the files to a PC. Using this method I will be able to move huge files and not be hobbled by the 4.7gb barrier. Close but no cigar. Last edited by nextoo; 10-14-06 at 06:57 PM.. |
#15 | Link | |
Nextoo
I hate to ask you this, but anyway you could point me to the directions on how to do this.... The Polaroid thread has 21 pages of info and I can't seem to locate it doing a "Search this thread" method.....
Was it really as simple as a "Plug and Play"? ![]() |
#16 | Link | |
#17 | Link |
I had the Polaroid at one time, took it back due to fan noise. How did you rig it up for an external drive? Sorry for the stupid question, but looked back at some of your posts in the Polaroid thread, and don't quite understand how you did it.
Something about a USB port on one of the internal boards? Chris |
#18 | Link |
Here's the first report as discovered by Dartman that the Polaroid is plug and play:
http://www.avsforum.com/avs-vb/showt...&&#post7739060 I can only say I took advantage of Dartman's discovery. I will take the credit for finding out that the Polaroid is essentially copy protection free though.... ![]() Last edited by nextoo; 10-14-06 at 09:50 PM.. |
#19 | Link | |
By the way you can also "down grade" the HDD . I found an old 40gb drive laying around that works fine too. |
#22 | Link |
HT Fan-Addict!
Just wanted to say thanks for all of the info on this unit. Anyone with a Scientific Atlanta HD box needs a recorder with component inputs and this is by far the most interesting (notice I did not say best) one on the planet. I picked one up yesterday and may get a second this weekend.
__________________
Home Cinema > Home Theater!!! |
#23 | Link |
Larrimore, please elaborate on this SA HD box. Model?
Are you saying it can be used as a HDD recorder with component inputs standalone, in other words, in conjunction with say a Comcast Motorola STB? With component inputs, are there any 5.1 or digital audio inputs? Thanks Tom |
#24 | Link |
I don't know if they're all like that, but the SA 8300HD will only output widescreen via the component output. I thought I read somewhere else that the Moto box will output widescreen via the s-video, but I could be mistaken. Another way around that is to get a recorder that will allow you to manually set the 16:9 flag. My Sony RDR-GX330 does, but I haven't played it too much.
#25 | Link |
Project is pretty much complete.
A word of caution on the HDD upgrade. I am having no problems with WD 250gb drives. I have filled and emptied them many time and have done a significant amount of editing with no problems. I am having some performance problems with a 500 gb Maxtor. I don't know if the problem is the brand or the size. At this point I have made a decision to only use WD 250gb drives. Plus the 250's are around $50 with a rebate or sale. The 500's are around $200. No brainer with removable capabilities. Also the 500's are almost too big from an organizational perspective. Final pics: 1. 7 drive bays. I need more HDD's to fill them. The 8th is running with the Polaroid.2. Hard drive enclosure running and recording. (black case on the right) 3. Another view. |
#27 | Link | |
This drive has 8 megs of cache - a "JB" model. The "BB" model with 2 megs of cache should work too. The 80GB stock drive is a 2 meg cache "BB" model. I've also used old generic 40GB drives with no problems. The only drive I had a problem with was the 500GB Maxtor. |
#28 | Link | |
The cache size makes a difference in speed in a PC application. Will it matter for this DVD recorder? Would it benefit the player with a higher cache size? |
| Bookmarks |
| Thread Tools | |
