#1 | Link |
Finally - the REAL VTF-3 HO is here !
Just thought some of you here would be interested. I'm coming from a Velo CT-150 and had good intentions of comparing it to my new HO. One quick listen to the HO and the CT-150 has now been unplugged and in the washer room ever since
. Keep it comin' Craig.http://www.hsuresearch.com/forum/showthread.php?t=2275 |
#2 | Link |
Interesting...so the final version of the VTF-3 HO ($799), in 22Hz mode, delivers measured performance that falls between the PBS12-Plus/2 ($1199) and Velodyne DD-18 ($4499).
With the Turbo eyesore installed ($899), the VTF-3 HO performs 2-3dB under the DD-18. Looking forward to more detailed measurements / tests. |
#3 | Link |
I like this hobby
AVS GOLD CLUB MEMBER
Let's see if we can keep this nice ...
Velodyne DD-18 on Lightning scene ... ![]() DD-18 on Pods Emerge scene ... ![]() Hsu VTF-3 HO in 22 Hz setting, Lightning Scene ... ![]() Hsu VTF-3 HO in 22 Hz setting, Pods emerge scene ... ![]() SVS PB12-Plus/2 in 20 Hz tuning, Lightning Scene ... ![]() SVS PB12-Plus/2 in 20 Hz tuning, Pods emerge scene ... ![]() Hsu VTF-3 HO Turbo Lightning scene... ![]() Hsu VTF-3 HO Turbo Pods emerge scene ... ![]() |
#5 | Link | |
I like this hobby
bfdtv - the bottom 2 graphs were done in the 16 Hz tuning with the Turbo installed. I am hoping we get lucky and get some warm, dry days before winter rolls in, so some 2 meter GP tests can be done.
We have had the wettest, coldest October I can recall. I don't yet no how to overlay the graphs .. JeffD2 has done some for me in the past, and if anyone wants to do some overlays, feel free. |
#6 | Link | |
listen for yourself
There is one config that does not have an amp setting. That would be Turbo with one port. Supposedly this is around a 12hz tune.
__________________
-curtis Volunteer Mod at the A s c e n d A c o u s t i c s Forum Somewhere between what someone posts and what I think, is the truth. |
#7 | Link |
I like this hobby
Curtis, I had not identified the last graphs as being in the 16 Hz setting, and that was "my bad", as I went under the assumption everyone knew that adding the turbo meant the 16 Hz setting was the ONLY way to use the Turbo.
You know what they say about ASSuming ... ![]() |
#8 | Link | |
listen for yourself
__________________
#9 | Link |
AVS CLUB MEMBER
Hi Craig,
For the sake of clarity and understanding what we are seeing, were these all at the same main volume settings or do these correspond to a maximum level before audible distress?
__________________
Mark Seaton Seaton Sound, Inc. "Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham |
#10 | Link | |
I like this hobby
Mark ... These are max output before audible distortion is noticeable. I also had the SPL meter next to the microphone, and checked SPL levels there against what was showing on the TrueRTA screen ... it was always within 2 dB.
I also ran the subs @ about 10 dB "hot" ... to keep my sanity. Basically, what you are seeing is an in room, Let's torture each subwoofer with a devastating disc and see what they can do, session. |
#11 | Link |
All about the sound
Wow 10 dB hot, Craig when you're not testing and just watching a movie how hot do you normally run your sub(s)?
Also what was your MV on when you made these graphs and do you use AVIA or VE when calibrating?
__________________
"What do you mean it's too loud? My ears aren't even bleeding yet!" Radden Home Theater |
#12 | Link |
I like this hobby
I normally run 2 dB hot, just for the extra impact. I am not even watching the movie for these scenes. What I have learned about this disc is to set dialogue at appx. 70 dB ... then turn the sub output up by an extra 7-8 dB, and run the scenes while watching the meters. I then usually work a few extra dB in output during these scenes before hitting the max each sub can do.
I know it may sound unusual, but what I am trying to find out is how hard can these subs deliver the bass in these scenes. It is not even close to how I listen normally. I do find it interesting and informative as each sub is in the same spot, in the same room, playing the same scenes in a "peak hold" setting for this particular exercise. Last edited by craigsub; 10-15-06 at 09:53 PM.. |
#14 | Link |
I like this hobby
Jon - The Turbo does add a nice element of that infrasonic, tactile feel to the bass response. Obviously, I have had a lot of subwoofers through our systems here, and most of them have been excellent performers.
The new PB12-Plus/2 is, in its own right, a very good subwoofer. It is deep, powerful, and "tight". However, in direct A/B comparisons, subjectively, the VTF-3HO is actually even better. It has more of that percussive ability of the DD-18, and also energizes the room with more pressure than does the SVS. The SVS does move a little more air in the 30 Hz region, but the Hsu is a better balanced overall package. It is remarkable for a single 12 inch driver design. Does this mean someone should run out and sell his SVS ? No. Does this mean everyone will experience what I am here ? No. Does this mean Hsu is back in the game with an excellent performer that goes toe to toe with any subwoofer under $1500 ? Absolutely. We have a lot more "work" to be done here - including running dual HO's, and trying the single driver Ultra against the HO. Hopefully, we can keep this "nice", and get more results. |
#16 | Link | |
listen for yourself
__________________
#18 | Link | |
listen for yourself
__________________
#20 | Link | ||
Mert Decoder
Hey Curtis - you are good luck. Fedex just pulled up and I now have a new HO driver. No I didn't keep the cute Fedex employee...sheesh. (I made that terrible on purpose...I swear) Quote:
#21 | Link |
Hey, I'm a Troll ;)
Agreed about Illka and it would be nice if HSU would actually put up some frequency response graphs on their own website for "each" of their subs.
That way you can easily compare their own data amongst each other and if we get some more datapoints outside of their data we can start making educated extrapolations. |
#22 | Link |
gimme DIY or death
Ed Mullen or Ilkka measurements would be pretty nice on this sub....
__________________
.___ _ / __| |_ ___ _ ___ __ Equipment schematic \__ \ ' \/ -_) '_\ V / . my Wireless setup! |___/_||_\___|_| \_/ DIY interconnects |
#28 | Link |
Hello - would it be safe to say then - that this would be a definate upgrade from my SVS 20-30 PC+ using their latest 12.3 driver? From this thread it appears to be a definate yes.
I have had a pre-order in since February and to be frank I forgot about it completely until HSU called. I originally was planning to sell the SVS when the HO was ready. Not so sure now. Thoughts? |
#29 | Link |
I like this hobby
Eli ... You nailed it ... all three are just outstanding. In fact, I may try the SVS with the baseplate off - my previous Plus/2 (.2) sounded better as did the Ultra, in this room. For the $$$$, both the Plus/2 12.3 and VTF-3 HO are REALLY impressive.
Mucho, Absolutely, for the few $$$$, the upgrade is well worth it. Should you sell your current sub and grab the HO, or just upgrade the current ? That is a very close call. |
#30 | Link | |
Where is the VTF-3 HO on the HSU site?
dlipter Never mind..........http://www.avsforum.com/avs-vb/showt...hsu+vs+rythmik Last edited by dlipter; 10-17-06 at 10:36 AM.. |
| Bookmarks |
| Thread Tools | |
