AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Blu-ray & HD DVD Areas > Blu-ray Players
Forum Jump
Old 10-17-06, 02:01 AM   #1   |  Link
shamus
AVS CLUB MEMBER
SAMSUNG bd p-1000 Firmware 1.0 here!!!!
http://samsung.com/support/productsu...lu%5Fray%2Esec
Found by jivc79...
Firmware fixes:
Dts "judder" problem fixed
Allows 4:3 pillarboxing (BD material only)
Improved load times
Changes hour glass to "colored dots"
Corrects analog outs, if reversed
Allows playback of BD-R/BD-RE discs
Improved PQ of BD and DVD playback
Parental control problem fixed
Fixes HDMI compatability problems with certain displays
Loses region free abilities
shamus is offline   Reply With Quote
Old 10-17-06, 02:12 AM   #2   |  Link
boden11
PDF manual wants me to download Korean fonts?
boden11 is offline   Reply With Quote
Old 10-17-06, 02:27 AM   #3   |  Link
shamus
AVS CLUB MEMBER
Yes.. I had to that too in order to see it. Manual doesnt say what it does, just how to do it...
Old 10-17-06, 03:43 AM   #4   |  Link
shamus
AVS CLUB MEMBER
Can someone walk me through this???? I just downloaded Nero 7, and cant make any sense of it!!!! I also have Windows Media. I made two attempts to burn, with no luck!!!! Im out of disks so I will pick up some more tomorrow. If someone can post a step by step list of how to this it would be great. My only knowledge of this stuff is ripping and burning audio CD....
Old 10-17-06, 06:36 AM   #5   |  Link
Spizz
I'll be keeping my eye on this thread. Can't wait to see what it addresses.
Spizz is offline   Reply With Quote
Old 10-17-06, 08:03 AM   #6   |  Link
jivc79
New Member
i just ordered my sammy on friday using my amex points i had accumulated, as soon as it arrives if its not already updated ill burn the iso and see what i can find, read all 8 pages late last night of the other topic and didnt notice the mention of that firmware link, so i created an account and mentioned it
jivc79 is offline   Reply With Quote
Old 10-17-06, 10:59 AM   #7   |  Link
Gary Murrell
Yngwie's Biggest Fan
Classified Rating: 100% (1)
we need details on this, here is my take:
all the CD's being sent are for the DTS Fix, very very soon will be the NR fix(according to Samsung), I am guessing this website update is the DTS Fix, and then soon the NR Cd's will start being sent and that download will be put up
someone call Samsung tech. and confirm what the website download is for? we will all owe you one
-Gary
__________________
Gary's HT/Review System
Gary Murrell is offline   Reply With Quote
Old 10-17-06, 11:23 AM   #8   |  Link
bferr1
A friend downloaded this and said it was a 8mb file. Since the Toshiba firmware updates are usually in the 40-60mb range, I'd figure this can't be the big PQ/BD-J fix. It has to be the DTS fix.
I no longer own a Sammy, since I've exchanged it for the Panny, and my friend doesn't have any DTS BDs. Can someone try a Lionsgate or Paramount title to see?
bferr1 is offline   Reply With Quote
Old 10-17-06, 11:29 AM   #9   |  Link
wostertag
-Gary
Gary - Just got off the phone with CS. All they would say is it is for "Disc Compatability". lol
wostertag is offline   Reply With Quote
Old 10-17-06, 11:31 AM   #10   |  Link
bferr1
^ That has to be for DTS compatibility, then.
Old 10-17-06, 11:47 AM   #11   |  Link
dneily
dneily's Avatar
AVS GOLD CLUB MEMBER
Classified Rating: 100% (4)
I just completed the update process, tried all of the menu options and tested a SD-DVD with DTS and DD 5.1.
The update took a total of 11-1/2 minutes.
Here is the sequence and the messages displayed:
1. Powered up the Samsung and ejected the empty tray.
2. Inserted the CD-ROM with the burned ISO image.
3. On-screen message #1: "Verifying System F/W"
Front panel message: "No DISC"
4. On-screen message #2: "Do you want to update System F/W?
PSD: 60605.1 --> 61011.1
DMN: 60526.1 --> 60929.1
LDR: 529F"
"Yes" and "No" radio buttons with Yes outlined in yellow.
5. I used remote to select "Yes"
6. On-screen message #3: "Main F/W Update Now Processing. Please do not turn off the power."
Front panel message: "CD-UP"
7. On-screen message #4: "Sub F/W Update Now Processing. Please do not turn off the power."
8. After 11-1/2 minutes, the disc automatically ejected and the power automatically turned off.
These are the changes I've noted so far. Note that I have not played a BD yet.
1. Test tones work properly now (but only for PCM; they don't work at all for Bitstream).
2. I get DD 5.1, DTS, and PCM output.
dneily is online now   Reply With Quote
Old 10-17-06, 11:57 AM   #12   |  Link
shamus
AVS CLUB MEMBER
#1 The test tones shouldnt work for bitstream, so thats good!!!
#2 Are you saying the Samsung now decodes those audio codecs(Dolby Digital, DTS) and can be output through the analogs???
Old 10-17-06, 11:58 AM   #13   |  Link
bferr1
Did the picture glitch (drop frames) during DTS playback?
Old 10-17-06, 12:00 PM   #14   |  Link
shamus
AVS CLUB MEMBER
Thanks again!!!
Old 10-17-06, 12:02 PM   #15   |  Link
wostertag
Always did.
Old 10-17-06, 12:06 PM   #16   |  Link
shamus
AVS CLUB MEMBER
Originally Posted by wostertag
Always did.
No it didnt... It never decoded internally so it could be passed through as PCM.
Old 10-17-06, 12:10 PM   #17   |  Link
dpags
This is the fix I'm looking for. Total Recall will be the first disc I throw in after I do the upgrade.
dpags is offline   Reply With Quote
Old 10-17-06, 12:13 PM   #18   |  Link
wostertag
Well then how come since I have not applied the firmware update and I have a June build date, can I currently listening to the DTS soundtrack of T2 throgh my analog outs? I'm doing it right now.
Old 10-17-06, 12:14 PM   #19   |  Link
gonzalc3
Did it eliminate the hourglass and fix the y/c delay?
__________________
Christian
My DVD and Blu Ray collection
Xbox 360 Live Gamertag: Christian Yves
JVC RS20, ST 130, MK THX S150 system, Marantz AV8003, Oppo BDP 83,B&K 200.7, Anthem D2v coming soon
gonzalc3 is online now   Reply With Quote
Old 10-17-06, 12:20 PM   #20   |  Link
shamus
AVS CLUB MEMBER
Well then how come since I have not applied the firmware update and I have a June build date. I am currently listening to the DTS soundtrack of T2 throgh my analog outs?
Hmmmmm The manual says it wont decode, but I recall someone(Chad or Michael) saying it will decode as long as its on a BD disk. Try a standard DVD and see if it will decode anything on that.
This was a big complaint for me since I couldnt use Avia to calibrate my speakers properly for analog out and just stuck to good ole optical out.
Old 10-17-06, 12:33 PM   #21   |  Link
wostertag
Shamus - Bingo!! No go on the DTS from an SD/DVD. Never thought to try it, I always used the optical for SD/DVD. Looks like it plays DD on SD/DVD, but only 2 channel? They both work as 5.1 with a BD, though! Anyhow, going to upgrade now, will report back any new findings.
Old 10-17-06, 12:38 PM   #22   |  Link
shamus
AVS CLUB MEMBER
Ok great... Im not going crazy!!! Please check that right away cause that would be huge if it can now decode it. I cant wait to try this uncompressed PCM now that I will be able to calibrate my speakers!!!
Thanks and let me know!!!
Old 10-17-06, 12:39 PM   #23   |  Link
Gary Murrell
come on guys spill , my Sammy will be here tomorrow or thursday, someone let us know what this update does
thanks
-Gary
__________________
Old 10-17-06, 12:44 PM   #24   |  Link
shamus
AVS CLUB MEMBER
thanks
-Gary
Gary, I called also today and it seems it wont fix the DNR chip. The only thing I could get out of them is it fixes "compatibility" issues... whatever that might be??
Old 10-17-06, 12:47 PM   #25   |  Link
billymerritt
The update reverts to setup defaults, need to check all settings to see if they are correct for your particular needs! DTS stutter gone, picture quality seems the same to me. It is a 52.7MB file, so must have had more fixes than just the DTS problem.
__________________
Bill
billymerritt is offline   Reply With Quote
Old 10-17-06, 12:51 PM   #26   |  Link
bfdtv
Keep in mind that Toshiba does their firmwares differently. With the way the Toshiba was designed, each firmware update entirely replaces the previous one, even though most files are unchanged. Samsung may simply include the patches or changed files.
The PQ "fix" will probably take the form of changed settings for the Genesis chip, which would only require a few bytes.
bfdtv is offline   Reply With Quote
Old 10-17-06, 12:54 PM   #27   |  Link
shamus
AVS CLUB MEMBER
Some people had problems with their analog outs being reversed.. I believe it was addressed in an earlier firmware that was never posted. Thats probably fixed too.
Old 10-17-06, 12:59 PM   #28   |  Link
Gary Murrell
this is the DTS fix, no doubt about it
thanks Shamus
-Gary
__________________
Old 10-17-06, 01:00 PM   #29   |  Link
Alan Gouger
Not Really Here, Or Am I?
Just burned my CD and will update my Sammy later today. I can confirm it is 52MB in size.
I would also like to know the answer to Garys question, does this update replace the hour glass ?
Alan Gouger is offline   Reply With Quote
Old 10-17-06, 01:03 PM   #30   |  Link
bscolvin
I can not get mine to update says cd. Help Please
bscolvin is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.28461289 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
