#1 | Link |
8300 HD Partial Show Reording
I am having a problem on both my 8300 HDs. They appear to recrd an entire show, at least they show recording in the guide, and the DVR menu for the entire show length. Then when the show ends it ends up only being a partial recroding, such as 37 minutes for an hour show, even though it appeared to be recording for the entire hour.
Any help would be appreciated. |
#5 | Link | |
8300HD SARA1.89.27.1
signal strength
Or, just search the thread for "dbmv". |
#6 | Link |
New Member
Sometimes this happens to me as well, but more often it splits up a recording into 3 chunks. It always happens with "The Colbert Report": it'll be split into three pieces, each starting where the previous one left off. Funny thing is that one night I noticed the problem around 12:30 so I set the DVR to record the 1:30a repeat, and it split it into 3 chunks as well! I haven't called Comcast yet because this software is so buggy I wouldn't even know where to start with the complaints.
If you look further down the "Recorded Programs" list, do you see the missing 23 minutes in a separate chunk? |
#10 | Link | |
New Member
#12 | Link |
Happening to me to.
This has happened to me a few times. I recorded prison break and it only recorded 35 minutes of the show. Then the very next show "24" it recorded only 40 minutes of the show. One weired thing was the status bar was red on the left side and green on the right side. When the show completed the status bar was green on the left side and red on the right. Both shows played perfectly until the cut off so I know its not a signal problem and I know I didn't run out of hard drive space because it did fully record a show later that evening. I'm wondering if my external drive momently lost connection with the box. I only had 2 programs on the drive when this happened. I now have 17 programs on the drive and the problem has not re-occured.
__________________
8300HD sara 1.89.17.1 WD5000AAKS 500GB 7200 RPM 16MB SATA 3.0Gb/s APRICORN EZ-BUS-DTS-EKIT Enclosure |
#13 | Link |
Recording stops prematurly resulting in a partial recording
I did a little more investingating.
As we all know the 8300hd stb allows you to record 2 programs while watching 1 pre-recorded program (all ready on the hard drive). With that in mind I started a timed recording and let it record for about 10 minutes. I then started channel surfing and at around the time I started channel surfing the timed recording stoped and I was left with a partial recording. I then started another timed recording on the same channel and just let it finish and it was perfect. I tried this a few times and I found that on certian channels like fox and nbc the recordings would stop prematurly and on other channels like CBS and ABC they would be fine. If you start 2 recordings and start channel surfing this would almost always happen which is to be expected because you can record 2 programs while watching 1 pre-recorded program as mentioned earler. This seems to me to be a software issue with the box. The software should be programmed to warn you that you are recording 2 programs and can not channel surf. Also this should never happen when only one recording is taking place and also needs to be addressed in the box programming. I would like to suggest to anyone having this problem to confirm my findings using the above process.
__________________
| Bookmarks |
| Thread Tools | |
