#1 | Link |
It's clear that the introduction of HD DVD has prompted many to hook up their HD DVD/BluRay player to their amplifier via a multichannel connection. And this has introduced them to a world of calibration pain caused by the LFE (Low Frequency Effects) channel. Many have previously encountered this with SACD and DVD-Audio, but now a mass of newcomers need guidance.
So, here's my attempt for a definitive guide to what's what in the exciting world of LFE. Any feedback welcome. Executive summary Many current receivers do not handle LFE over HDMI correctly. See the bottom for a list of good and bad receivers. Players are also considered. Read on for the explanation. Introduction Initially, I'm only going to consider LFE in a system without bass management. The LFE channel was originally found on multi-channel film recording formats, such as Dolby Stereo 70 mm Six Track. The purpose was to make more room for loud explosions, rumbles etc. The normal sound channels were calibrated so they could produce up to about 105dB SPL of output. Pretty loud, but not quite enough for the sort of low-frequency effects that you feel as much as hear. So, to increase the impact, they added an extra channel, dedicated to low frequency effects, to be sent to a dedicated subwoofer. And this channel was calibrated to play 10dB louder than the rest - it could output 115dB SPL of energy. And 10dB difference is quite a lot - it means a signal over 3 times the amplitude. Calibration This 10dB boost is achieved by calibration in the monitoring amplifiers at the studio; a full-scale LFE signal on the tape is set up to play 10dB louder than a full-scale signal on any other channel. The cost is increased noise - the channel has been turned up, so the general hiss and noise on the magnetic recording will also be 10dB louder. But this is not too much of a problem, as all sounds above 150Hz are filtered out anyway on playback. The channel is only handling low frequencies. To reproduce the effect heard in the studio, cinema playback systems are also calibrated the same way - a 10dB boost is added to the LFE channel amplifier. Calibration tests generally hide this 10dB difference; a basic pink noise test will contain a signal that should play at 75dB SPL for each channel. For the normal channels, that means a signal 30dB below full scale (105dB-30dB = 75dB), but for the LFE channel it is a signal 40dB below full scale (115dB-40dB = 75dB): 1/3 of the signal amplitude. If those test signals are used to calibrate the amplifier so they all output at 75dB SPL, then everything is set up okay. The LFE channel now has 10dB of extra headroom above the other channels and can produce the full 115dB SPL when required. Interconnects One important point is that the 10dB boost to the LFE is performed at the final amplification stage. The potential extra volume of the LFE channel could not pass through interconnects, analogue recordings or digital recordings without going over the specified limits by a factor of 3. This, indeed, is the whole raison d'ętre of the LFE channel. It's a channel where by convention everything is recorded 10dB low to make room for louder bangs. So at all points in a system - analogue interconnects, PCM signals, encoded Dolby Digital - the LFE channel is "10dB too low". A 75dB SPL signal on the LFE channel will be 3 times, or 10dB, smaller than a 75dB SPL signal on the other channels. It will only sound correct when fed to an amplifier that amplifies LFE by 10dB more than it amplifies the other channels. This 10dB difference is dictated by Dolby and DTS, and the international standard ITU-R BR.1384-1: Quote:
The LFE channel progressed from early analogue magnetic formats, to the digital channel in cinematic versions of Dolby Digital, and in turn to the home versions of Dolby Digital, DTS and MPEG Multichannel found on DVDs. The rules remain the same: the encoded LFE signal needs a 10dB boost. In receivers with integrated decoders, this is handled automatically in the internals, and the user is generally unaware of it. It is only when we try to connect amplifiers to external decoders that things can go wrong. Many receivers do not offer the necessary boost for LFE coming in from an external decoder. LFE level adjustment Some receivers with integrated decoders do offer an adjustment for the LFE level - an option to NOT boost the LFE by 10dB. This is needed for some early music mixes using DTS; the studio mixers, being unaccustomed to 5.1 production, hadn't calibrated their LFE channel 10dB high. Thus the recorded LFE signal on those discs is at equal level with the other channels, and doesn't require boosting. The unboosted LFE option on the receiver is often called "LFE -10dB", with the standard boosted option being "LFE 0dB". Alternatively the options might be called "LFE 0dB" and "LFE +10dB". Whatever, the higher option is correct for films and almost all DD and DTS multichannel music. Since those early errors, both Dolby and DTS have specifed that LFE in music releases should be mixed for a 10dB LFE boost to match film soundtracks. However, SACD still differs... more on this below. Bass redirection When Dolby Digital and DTS reached the home, there was one important difference. Cinema speakers are MUCH bigger. A normal sound mix will generally contain deep bass in all the front channels, as well as low-frequency effects in the LFE channel. Home speakers usually don't handle deep bass that well, so it is usually advantageous to redirect bass from the main speakers to the subwoofer. Home DD and DTS receivers offer a bass management function to do this. With bass management enabled, there is now an important distinction between "LFE" and "Subwoofer" channels. LFE specifically refers to the LFE channel of the original soundtrack. But the subwoofer channel contains both the LFE channel and redirected bass from the other channels. Bass summing A very important thing to bear in mind when redirecting bass is the 10dB calibration difference between the LFE and other channels. A combined subwoofer channel must be calculated as: SW = LFE + Lower10dB(Redirected bass)or equivalently SW = Raise10dB(LFE) + Redirected bassbut not SW = LFE + Redirected bassThis keeps the relative level of bass signals originating from the LFE and other channels consistent. If a piece of equipment gets this balance wrong, the error is uncorrectable further down the signal chain. LFE vs SW (subwoofer) labelling Equipment usually gets this labelling right. A receiver will have an SW pre-out, and an SW terminal on its multichannel analogue input. Multichannel outputs on players will include an SW terminal. This accurately reflects the fact that in general the player is expected to do bass management, so will be outputting LFE+redirected bass on that channel. And the SW input to the receiver will be passed straight to the SW pre-out - it expects bass management to have already been done. LFE interconnects can usually only be found in the digital domain. This reflects the fact that when using digital connections, the receiver is expected to perform bass management. The player passes the LFE channel unaltered, without redirecting any bass. Plain LFE information is carried in DD and DTS bitstreams over SPDIF/TOSLINK, and in PCM or DSD streams over Denon Link, i.Link or HDMI. Early DVD-Audio and SACD players did not offer any bass management for PCM or DSD, so in effect they only offered an analogue LFE out. This meant they could not be easily integrated into a conventional system with a receiver that only had an SW input, and no bass management for multichannel input. This lead to a market for separate bass management devices, such as the Outlaw ICBM. Current players now generally offer bass management for all formats on their multichannel outputs. SW analogue output from players Okay, what level should the subwoofer output be? If it were just the LFE track, then you'd expect it, as discussed above, to be 10dB lower than the other channels to fit the 10dB higher maximum LFE output. But if the player is performing bass management, then the subwoofer output also has to contain redirected bass; this extra signal could push the signal back above its nominal limit. To prevent overloading their output, or the receiver's input, players with bass management conventionally lower the SW output by a further 5dB. (This 5dB value is specified by Dolby, see references). Sometimes this 5dB drop switches in and out depending on whether bass management is being performed (ie if any speakers are set to SMALL). The final SW output will typically be: SW = LFEor: SW = Lower5dB(LFE + Lower10dB(Redirected bass)) = Lower5dB(LFE) + Lower15dB(Redirected bass)So, in those two cases the SW output from the player will be respectively 10dB or 15dB lower than the other channels. A receiver should offer the ability to specifically boost the SW input on its multichannel analogue interface to compensate. LFE digital output from players When outputting a Dolby Digital or DTS bitstream from a player, the LFE channel remains encoded in the bitstream, untouched by the player. The receiver's decoder has the responsibility to boost the LFE by 10dB, and almost invariably they will get this right. DD and DTS remain the most foolproof way of transmitting LFE. When outputting a PCM multichannel bitstream over Denon Link, i.Link, HDMI or similar, the LFE channel will be transmitted "as-is", and will need boosting by 10dB in the receiver. The receiver should do this automatically. If it fails to do this before performing bass management, then you will be unable to calibrate the system correctly - boosting the subwoofer to compensate will have the side effect of over-emphasising bass from other channels. "DVD-Audio/HD DVD/Blu-ray's bass is too quiet" No. They're mixed exactly the same way as Dolby Digital or DTS on DVD-Video. The LFE track is recorded 10dB low. People are only noticing a problem because they've switched from a DD/DTS bitstream link which works to a multichannel interconnect lacking the necessary 10dB-15dB boost. If they had been listening to DD or DTS decoded in the player through the multichannel interconnect they'd have seen the same problem. And the problem is that their receiver isn't boosting its SW/LFE input sufficiently. It is not really an option for the player to boost its analogue SW output, as it would be in danger of overloading a receiver's input circuitry when a maximum volume LFE signal appeared - feeding a 6 volt signal into a nominally 2 volt input. You might get away with it if the amplifier was purely doing an analogue passthrough, but it would overload any receiver with multichannel ADCs. And similarly the player absolutely cannot boost its digital LFE output. There's no headroom to do this. "Super Audio CD's bass is too quiet" Same basic answer as the previous section, except for one wrinkle: SACD doesn't actually use a 10dB boost for its LFE channel (which poses the question - why have it at all?) To maintain compatibility, some multi-format SACD players apparently lower the LFE internally by 10dB, then carry on the rest of their processing as normal. This then leads to the output: SW = Lower10dB(music LFE)or SW = Lower15dB(music LFE + Redirected bass)So the net boost of 10dB or 15dB is still needed in the receiver to achieve correct playback, consistent with other formats. Some players, usually SACD-only, do not do this 10dB adjustment, leading to the output SW = music LFEor SW = Lower5dB(music LFE + Redirected bass)This could arguably result in better quality, by making better use of the range on that input, but means the receiver has to have its SW input switched to +0dB or +5dB respectively just for SACD with that player - inconvenient if it's multiformat. SACD over a digital interconnect This is unclear, and will depend on the digital interconnect type. Normally one would expect digital output to be "raw". But what happens when the raw LFE doesn't need a boost, because it's come from SACD? The full connection standards aren't publically available (eg CEA-861-D for HDMI). Is there a standard for LFE level over these connections? If there is, then the standard would be that LFE over digital interconnects should always need a +10dB boost at the receiver (as per ITU-R BS.775-2 and ITU-R BR.1384-1). Then any player outputting SACD data would have to attenuate its LFE by 10dB so the receiver could still apply a 10dB boost, as it does for DD+/DTS HD sourced data. If there's no standard, or players vary, then a receiver may need an option to disable the 10dB boost. To be on the safe side, I'd recommend that receivers offer this switch, maybe by tying it to the "0dB/-10dB" setting for its internal DD and DTS decode. Summary of requirements In summary, here is what should be happening with each interconnect type: Analogue 2-channel
References
Known equipment behaviour We can collect known equipment behaviour here. Please post your experiences, and I'll incorporate. Receivers offering dedicated 0-15dB analogue SW gain
Players incorrectly summing bass and LFE
Other odd player behaviour
Last edited by KMO; 04-16-07 at 06:01 PM.. Reason: Samsung DVD-HD850 fluffs SACD bass summing |
#2 | Link |
Iron Mike
That was GREAT. Wish it were available when I was learning all of that stuff. The only criticism I might have of it is that were I not previously aware of this issue, I might still be confused. There is a lot of great, very easy to understand info here, but there is a LOT of info.
Nice work. |
#3 | Link |
Onkyo TX-SR702 options.
Multichannel Analog-- 0dB (default), +5, +10 or +15dB. Manual says if too loud (sic) set to 0, +5, +10 or +15. DTS-- -infinitedB, -10db0dB (default), 0dB (default). Manual says if too loud set to -infinitydB or -10dB. Dolby Digital-- -infinitedB, -10db0dB (default), 0dB (default). Manual says if too loud set at -infinitydB or -10dB. I don't know how to get the other information, or when THX Select settings are used what changes occur.
__________________
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd. -Bertrand Russell Last edited by trekguy; 11-09-06 at 03:24 PM.. |
#4 | Link |
AVS CLUB MEMBER
If I'm reading this right, this explains why a HD-DVD player connected to a Pioneer VSX-84TXSi via HDMI runs the LFE channel low. It's receiving raw PCM and doesn't apply the 10db boast to the LFE channel like it would on a DD or DTS bitstream.
__________________
Jeff Gamertag - Ktulu1 "Assiduus usus uni rei deditus et ingenium et artem saepe vincit" - Cicero |
#5 | Link | |
#6 | Link | |
#7 | Link | |
OP now corrected.
__________________
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd. -Bertrand Russell |
#9 | Link |
KMO,
According to this thread, the Sony STR-DA5200ES has a +10db for the SW: http://www.avsforum.com/avs-vb/showt...99#post8913999 |
#11 | Link | |
Obsessive music guy
#12 | Link |
soundlovr - good point regarding our basic SPL sensitvity. You may not realize that KMO has been translating to eqivalent voltage waveforms or digital numerics --- as in sqrt(10) = 3.16. But hey it is still a 10x power change!
__________________
plug in to play |
#14 | Link |
Get a player with a built in Dolby Digital decoder, and some Dolby Digital test tones (eg Avia). Note that on Avia, the subwoofer calibration tone does not use LFE. Only the LFE frequency sweep tone does - use that.
Ensure the receivers "LFE level" setting for its own DD decoder is set appropriately - if it offers "-10dB" and "0dB" you want "0dB". If it offers "0dB" and "+10dB" you want "+10dB". Otherwise, check the manual, but it's probably the highest option that you want. Switch between getting the player to decode DD and pass PCM to the receiver, and passing the DD bitstream up to the receiver for it to decode. You'll probably see an absolute level difference on all channels in the two cases, due to dialogue normalisation, or other subtleties - maybe 4-5dB. If you see a bigger discrepancy (>=10dB), the player's doing something odd, or you've got some level trims set up that affect the HDMI output (set them all to 0dB). Figure out what that difference is. The LFE tone should change by the same amount. If the receiver isn't boosting LFE from PCM, but is when doing its own DD decode, then the LFE in the PCM case will be 10dB lower relative to the other channels. It may be that the receiver has some setting to adjust LFE level over HDMI PCM/DSD. It may be unified with the level for its own DD decoder (as in the Denon AVR-3806), or it may have a separate setting (as in the Onkyo NR-5000E). Conceivably it may even be unified with the multichannel analogue input SW level. Try whatever settings you can in the receiver to adjust it. But note that boosting the subwoofer speaker level is not a solution if you've got any bass processing happening, as that will also boost the redirected bass by 10dB. The receiver has to understand and get the LFE level right before it redirects bass (see the maths in the main article). An LFE control setting in the receiver is desirable because it may be the only place to deal with SACD or old DTS music discs that don't need an LFE boost, if the player doesn't offer its own controls, or automatically lower LFE output for SACD to match. If the player has level trims that affect HDMI output, then you can compensate in the player (as long as the player isn't bass redirecting). Set all level trims other than LFE to -10dB, and LFE to 0dB. |
#15 | Link | |
Here's a quick table highlighting the point. The maths may not be precise, but it's illustrative: For a normal channel: 75dB SPL = 0.07V, or 1/27 scale digital signal 85dB SPL = 0.2V, or 1/9 scale digital signal 95dB SPL = 0.7V, or 1/3 scale digital signal 105dB SPL = 2V (maximum), or full scale digital signal For LFE channel: 75dB SPL = 0.02V, or 1/81 scale digital signal 85dB SPL = 0.07V, or 1/27 scale digital signal 95dB SPL = 0.2V, or 1/9 scale digital signal 105dB SPL = 0.7V, or 1/3 scale digital signal 115dB SPL = 2V (maximum), or full scale digital signal So for any given intended volume, the LFE waveform will be 3 times smaller than the other channels. You could try to adjust trims on the output device to make it match the other channels, and that would be fine while working with nice gentle 75dB or 85dB test tones, or when working with content that never uses the extra range of the channel. But when the LFE wants to output 115dB, by turning it up you've just generated 6V and overloaded the receiver's input, or massively clipped the digital waveform with a 3-times overload. That's why the LFE is recorded and transmitted down 10dB. The amplifier at the end is calibrated to turn it up an extra 10dB, so it can push out 10dB more than the other channels. But that extra 10dB can't be applied until you've reached a point where there's room for the extra signal. And there isn't room over any digital PCM link (unless you're actually turning down all the other channels by 10dB instead), and it's something to be wary of over an analogue link, unless you know the receiving device can handle 6V input okay. (Any device that digitises the input is likely to suffer; an analogue device like a power amplifier or powered subwoofer may well cope okay). |
#16 | Link |
AVS CLUB MEMBER
For the Pioneer 74TXvi, which I only ever use with digital connections (ilink or HDMI), I can report that it has a dedicated variable SW channel level adjustment from -10 dB to +10 dB which affects digital input and, I presume, multichannel analog input too. Given the performance of the 80TX series, I would be surprised if the 74txvi correctly applied automatic +10 dB boost to LFE data over the digital input, though I still haven't formally checked it.
Given the sophistication of AVRs these days, it's sad that they still don't tend to correctly process bass for all formats. |
#17 | Link |
I think you're referring to the global subwoofer output trim? What I'm looking for is a separate setting that adjusts the multichannel analogue subwoofer input specifically, to make sure you can give it the special 10-15dB boost it needs, without messing up the other sources. That could either be a special setting, or offering a complete set of different speaker trims for the multichannel input.
Yes, I'm amazed they can't get this sort of basic stuff right, given how complex so much of the stuff they do is. |
#18 | Link |
AVS CLUB MEMBER
Right, I wasn't so much answering your query as just adding to the 'devices' info database. There is no dedicated 'LFE' or MC input level setting..it's all down to the global channel level settings. [Edit: this refers only to digital input, not analog]
#19 | Link |
Hi krabapple; that sounded a bit odd to me, so I double checked. It actually does have a +10dB boost option for the multichannel analogue SW, like the 84, at least according to the manual for the European version here (page 51).
But bizarrely, like the 84, it's a totally hidden feature, so you wouldn't find it unless you happened to read that page of the manual. |
#20 | Link |
KMO,
I'm growing increasingly tired of trying to figure this out with my 84TX. I compared the DD from an SD DVD last night to the PCM 5.1 Blu Ray version last night of Black Hawk Down and the PCM was significantly weaker in the LFE. I'm about ready to jump ship unless you think there's a way to make this work. I don't really listen to music on this system that often, mostly movies. Would you recommend the Denon 3806 as one that handles this issue correctly? And if so, do you want a great deal on a barely used 84TX? ![]() |
#22 | Link |
Funny, Jacksonian
There are two workarounds - 1) a player that can lower all the other HDMI channel levels by 10dB; and then turn the master volume up 10dB in the reciever. 2) in a system with all channels set to Large in the receiver, turn the subwoofer trim up 10dB. Any other "fix" will be a compromise that boosts redirected bass too much.The 3806 looks good to me. It's pretty much my top candidate at the moment, but I'm put off by its lack of HDMI 1.2; I want SACD digital interconnect in the DSD domain, but I don't want to have to use a proprietary interface like Denon Link. But on the other hand, a separate audio link appeals to me more than the compatibility grief of HDMI. Hence the i.Link of the Pioneer seemed attractive. If that's not an issue to you, I can't see anything else to fault it, in terms of technical facilities. Sound quality etc, I can't say anything about. I agree 2xHDMI is mingy. My other main candidate is the Marantz SR7001 (4xHDMI 1.2). But I haven't heard anything from anyone about HDMI PCM LFE through it - and I also need to know what it does for HDMI DSD LFE. The Denon has a clear documented PCM/DSD LFE setting in the manual; the Marantz doesn't mention it. I'm pretty certain the other Denons in the 06 range will work much the same as the 3806, but I haven't gone through their manuals. Feel free to have a go yourself... |
#23 | Link | |
#24 | Link |
The first workaround wouldn't; that's an adjustment in the player's PCM HDMI output. Bitstreams would go out intact, and would be processed as normal and correctly by the receiver. You'd just have to turn the master volume up 10dB when using PCM HDMI.
The second would screw up everything else, yes. You could counteract that screw-up by disabling the 10dB LFE boost in the receiver's own DD decoder to match (use the -10dB setting), and it would all work out. But the Pioneer lacks that setting too. You'd have to keep raising and lowering the subwoofer trim. |
#25 | Link | |
#26 | Link | |
AVS CLUB MEMBER
You're quite right, the 74txvi has this too, I missed it because I haven't used *analog* inputs at all. I was thinking only of digitial LFE/multichannel. For digital input (ilink, HDMI, and possibly optical) you can only adjust channel levels as part of the global channel level parameters. I'll edit the previous post to note this. It's always been unclear to me whether the 70 and 80 series of Pioneer AVRs apply MCACC (room correction) to the multichannel input -- do you know? I see from the manual that you cannot apply 'listening modes' or a few other features. Also, can they do DPLIIX on MC analog inputs? |
#27 | Link | ||
AVS CLUB MEMBER
Pioneer VSX-84TXSi/VSX-82TXSi(VSX-AX4ASi/VSX-AX2ASi) are models that do NOT apply +10 dB boost to digital input -- I presume this includes bitstream. Quote:
Since there are 6 available saved setting for PIoneer AVR configs, I suppose one could create a config for each situation, with different sub trim -- movies vs SACD for example. |
#28 | Link | |
Thanks |
#29 | Link | |
#30 | Link | |
. Because it's the common case used by 98% of users. It's only when you go raw multichannel, either analogue or digital, that things go pear-shaped. |
| Bookmarks |
| Thread Tools | |
