AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 11-15-06, 09:20 PM   #1   |  Link
Soshnick93
OK to all sony hdtv crt owners!
So for all of you guys that have a sony hdtv crt. like the xbr955 xbr 960 xhr 970.
Post pics of you tv.
Discuss problems.
post your settings.
anything you have to say about a sony hd crt.
my settings are
try them out see how you like them. i calibrated with dve.
picture 70
brightness 60
color 40
hue r1
color temp neutral
sharpness 38 clear edge off.
im no expert so if there is something rong with my settings can you please let me know?
i am having a bit of geometry issues so if you guys have any ideas to fix them let me know.
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Soshnick93 is offline   Reply With Quote
Old 11-15-06, 09:55 PM   #2   |  Link
Jerm357
Heres a pic of mine, Its a Sony 30XS955. You can even see my new DIY subwoofer in the corner
Jerm357 is offline   Reply With Quote
Old 11-15-06, 09:58 PM   #3   |  Link
Soshnick93
so how do u like these sony crts? lol i love my 970. try my settings and what settings do u use? i stink at calibrating so my setings are probly bad.
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-15-06, 10:03 PM   #4   |  Link
Soshnick93
nice setup man. how do u like that antenna. i got this terk hdtva and it sucked. if i get ur antenna will it work better?
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-15-06, 10:30 PM   #5   |  Link
adavis720
I'll bet your lizard appreciates that...
adavis720 is offline   Reply With Quote
Old 11-15-06, 10:31 PM   #6   |  Link
Soshnick93
how big is that sub lol is it that big a s s thing? lol how much was it thats nice
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-15-06, 11:22 PM   #7   |  Link
jpl3447
My settings are:
Advanced menu is set to
DRC Mode: Cinemotion
DRC Palette: Custom 2 (the default)
Color Axis: Monitor
Service menu settings:
2103-1
(RF & V5/V6)
SHAP: 1
SHFO: 3
PREO: 1
SSMD: 3
PPHA: 6
2170P-1
(This is universal)
SRBT: 29
RDRV: 43
GDRV: 27
BDRV: 16
RCUT: 42
GCUT: 26
BCUT: 20
2170P-4 (inputs 1, 5 and 6)
(Normal Axis)
RYR: 14
RYB: 14
GYR: 6
GYB: 4
(The following GAMMs are what I changed from the default)
GAMM=0
GAMB: 1
GAMM=1
GAMR: 3
GAMG: 3
And I followed the advice in this link for centering the picture and subsequently adjusting the overscan. I then adjusted a lower right geometry "off" using CXA-2170D-1 LCP to better than it was before.
I also tweaked the audio per this post . I am a little hearing impaired and trust another person's ears over mine.
These are all for a 34XBR960.
[IMG][/IMG]
jpl3447 is offline   Reply With Quote
Old 11-15-06, 11:33 PM   #8   |  Link
Redfin
In purgatory
I have a 2003 34XBR, something er other...I can't remember the specific model number off the top of my head. I've had two plaguing issues with the set since the beginning -- first, with a 1080 input feed I had the horizontal line that wiped across the screen from right to left. I probably should have had it looked into years ago, but when I set the cable box to 720p it was clean, and after I put off calling for a while, I kind of forgot about it. The second issue I had was with the overall geometry. It had a pincushion type effect along the bottom especially. It wasn't too bad, I guess, because everyone including my wife said they couldn't see anything wrong...but it always kind of bugged me, especially when I could see the curve in the painted lines on the football fields.
Redfin is offline   Reply With Quote
Old 11-16-06, 12:49 AM   #9   |  Link
Jerm357
My settings are........
For standard cable and OTA HD
Standard
Picture - 31
Brightness - 35
Color - 36
Sharpness - 19
Hue - 0
Color Temp - Neutral
Clear Edge VM - Off
Color Axis - Default
DRC Mode - Interlaced
For the HDMI input (OPPO 971 DVD)
Pro
Picture - 31
Brightness - 31
Color - 33
Sharpness - 31
Hue - 0
Clear Edge VM - Off
Color Axis - Monitor
The settings for the HDMI input are all set in the service menu. These are the settings from someone who had there set ISF calibrated. They match up perfectly with the AVIA calibration disc for me.
Changes all under Pro with the color axis set to monitor setting and the OPPO set to 1080i.
YOSW 0
YOF 15
CBOF 45
CROF 47
SBRT 28
RDRV 53
GDRV 35
BDRV 26
RCUT 60
GCUT 19
BCUT 27
WBSW 1
GDOF 34
BDOF 45
GCOF 37
BCOF 63
VMLM 3
VMDL 15
MIDE 20
VMH 0
VMM 0
VML 0
SPIC 0
SCOL 36
SPIO 7
SCLO 7
RYR 14
RYB 14
GYR 6
GYB 4
The antenna works great for me. I get 12 digital channels with it and I dont have to move it around much at all to get them all. I cant realy say if it will work good for you though. It all depends how far you live from the broadcast towers.
Hope these help.
About the sub its an RL-P15 D2 in a 8.5 cubic foot ported enclosure tuned to 17hz.
Its a downfiring design that is about flat down to 15hz in room (not EQed). Its powered with a Behringer EP1500 pro amp. Heres the design threads.........http://www.hometheatershack.com/foru...ject-pics.html
http://www.avsforum.com/avs-vb/showthread.php?t=722363
The first one is has better pics but you have to be registered. It has since been painted black and sounds great. The whole project was about $650 and sounds much better than the SVS 20-39 isd I had right before it.
Old 11-16-06, 07:57 AM   #10   |  Link
Soshnick93
http://s100.photobucket.com/albums/m7/Soshnick93/?sc=3 heres my setup hope u like it lol. so how did u guys get into the serv menu and how did you know what to do?
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-16-06, 07:59 AM   #11   |  Link
Soshnick93
have you guys tryied my settings? the prob suck so can u tell me what i am doing rong? im new i need advice.
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-16-06, 09:53 AM   #12   |  Link
Redfin
In purgatory
Are you unhappy with your picture? Why do you say your settings suck?
Old 11-16-06, 10:53 AM   #13   |  Link
justsc
You gotta give yourself more credit. Your settings look very reasonable. And since all of our tvs are unique none of us can really judge the other's settings.
How did you like your first calibration experience? Intimidating? Enjoyable? A little of both? I am so happy you took this step instead of relying on someone's else's settings. Now you can practice over and over again. We get better each time we calibrate. It's not easy, but we get better over time. Soon you'll begin to see the interrelationships between some of the settings like contrast and brightness. I have to go back and forth between them until I'm happy with both.
Good job with this thread as well - I like it!
justsc is offline   Reply With Quote
Old 11-16-06, 11:03 AM   #14   |  Link
justsc
Model Differences
All,
As you may have noticed already, there are significant differences in how certain Sony models guage settings.
For instance, I have the KV-34HS420 and my setting "ticker" only goes to 62 tics, while the 970 goes to 100 I believe. Obviously, my midpoint is 31, while on the 970 it's 50. For me, I have "Picture" (contrast) at 38, while Soshnick93's 970 is at 70, and both are correct for their given model.
So be sure to ID which model you have along with your settings. The XBR960s, XS955s, HS420s all have the 62 tic "ticker." The 970 has the 100 tic "ticker." I'm not sure about the HS510s and earlier models. So how does one translate? Probably percentages work best.
Cheers!
Old 11-16-06, 11:26 AM   #15   |  Link
justsc
My Settings
I have the KV-34HS420. I also use Comcast's HD DVR STB and it is connected via component cables. I have audio coming out of a home theater system (Sony 5.1). I own the Oppo OPDV971H and it is connected via a DVI-HDMI cable. (sorry, no pics). I tune in analog cable signals via a 1GHz splitter at the wall with it's split going directly to the tv, bypassing the STB's crummy analog tuner.
I have used Avia, DVE and Sound & Vision's Home Theater Tuneup calibration dvds. I actually prefer the latter for ease of use (when calibrating user menu settings).
Each of my inputs has their own settings, and I'll list them accordingly.
For analog cable 480i:
Input=antenna/cable port
Picture Mode=Standard
Picture=33
Brightness=45
Color=31
Hue=31
Sharpness=28
Color Temp=Neutral
ClearEdge=Low or Off
DRC=Interlaced (960i)
For Digital Cable SD @ 480i & HD @ 1080i:
Input=Input 5 (component)
Picture=39
Brightness=50
Color=34
Hue=31
Sharpness=27
Color Temp=Neutral
DRC=Interlaced (960i) for SD and "irrelevant" for HD as this feature is essentially bypassed and defaulted at Interlaced (on my set it's greyed out for 480p and higher input)
For Oppo set at 1080i:
Input=Input 7 (HDMI)
Picture=42
Brightness=53
Color=35
Hue=30
Sharpness=28
Color Temp=Neutral
ClearEdge=Low
DRC=Greyed out but defaulted to Interlaced
I have made numerous, but not extensive, SM adjustments that I will share at another time, when I locate my notes
Cheers!
Old 11-17-06, 11:24 PM   #16   |  Link
Soshnick93
bump
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-18-06, 12:04 AM   #17   |  Link
Jerm357
Im not too sure your ready for the service menu yet . You can realy mess things up in there and cause your display not to work any more if your not careful. You must realy be prepaired and know what your doing before you start with the service menu. Plus you realy should realy wait until you have about 100hours of break in time on yout Tv. In the mean time you should study this thread.........
http://www.avsforum.com/avs-vb/showthread.php?t=531494
Old 11-18-06, 01:35 PM   #18   |  Link
justsc
Agreed.
One must have great respect for the SM, and approach it with a plan. Unfortunatelly, many go into the SM like a bull in a china closet and regret the venture forever. Real damage can be done by taking the SM too casually.
However, approached correctly, working in the SM can be extremely rewarding. The SM is there for authorized service technicians to resolve problems that cannot be addressed in the user menus. That's why there's a special method of accessing the SM.
For now, try to create a list of those things you find bothersome, whatever they are. If you can't solve them in the user menus post questions. As your list of problems that are only serviceable in the SM begins to grow, start asking where in the SM to address them. Create a plan that prioritizes the problems with the most troublesome first.
Plan to attack ONE problem at a time - I can't emphasize this strongly enough. And apply ONE fix at a time. Otherwise you won't know which adjustment paid off.
Part of your plan MUST include writing down the default values of all settings you intend to adjust, BEFORE you adjust them. This is what trips up most folks - after playing with adjustments and finding nothing works they have no idea what value to return it to and are left to trial and error. If they've made numerous adjustments then they're out of luck and may now have a tv with terrible PQ and no easy way to return to what they started with.
KenTech's Sony Service Codes thread is THE best reference for learning about the SM and what you can do to improve the PQ of your set. You don't need to read it all, but start by skimming it and trying to learn about principles, like what overscan and greyscal are and why they're important. That kind of stuff. The more you understand the theory, the better job you'll do. Don't be intimidated. You only address one setting at a time. The thread will always be there so you don't need to memorize it.
Most of all - HAVE FUN. This is supposed to be fun. When you're ready let us know and we'll get you into the SM slowly, one step at a time.
Cheers!
Old 11-18-06, 01:59 PM   #19   |  Link
Compass
Good suggestions, justsc. But it's my understanding that each change in the SM must be written to memory individually for it to be saved. Is this not the case?
And it's always good to be careful, but I think a lot of this caution might be overstated. I had fairly severe convergence and geometry problems (from a picture tube replacement) that I fixed after tweaking around for about twenty minutes. I think I ended up changing and saving a grand total of maybe three SM settings (changed plenty more, only saved a few) with the help of KenTech's thread. It really was not a big deal at all, and I'm glad I didn't read some of these warnings or I might have been too scared to try it!
Heh, yeah, anyway, I certainly agree it never hurts to be careful, as I said, but you'd have to be pretty damn foolish and careless to manage to mess up your TV with the SM imo.
Compass is offline   Reply With Quote
Old 11-18-06, 02:05 PM   #20   |  Link
justsc
Yes, you do have to write changes to memory, on a Sony. That's not the case with all sets however. On my Samsung there's no such protection.
You'd be amazed to read some of the stories about folks who have totally ruined their sets via playing in the SM. They're the type that insist on other's settings so they can avoid the work of using test patterns and calibrating - they just go in there and fire away.
I agree that it's not such a big deal. But there are those who've had to throw away or sell their sets, or otherwise start from pure scratch. It happens more than I would ever have believed, ergo my warnings.
Old 11-18-06, 02:18 PM   #21   |  Link
Compass
Ah, of course, makes sense not all SMs would work the same in all brands. Caution away then. Be careful out there, kids.
Old 11-18-06, 04:47 PM   #22   |  Link
Soshnick93
well i dont really want to do a lot of reasearch can someone just walk me through it to help me fix my geometry problems?
how do u even get into the service menu and what do u do?
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-18-06, 06:20 PM   #23   |  Link
jpl3447
The thing about the 970 is that since it is a relatively new model the Service Menu is not that well explored. For example, know how the user menu goes from 1 to 100 increments? Well in the TV's talked about the the Sony Service Menu thread they go from 1 to 63. And if you read some of the posts towards the end it happens that 970 users are finding that the Service Menu is completely different, at least in some of the code groups.
I am sure there are some similarities and hopefully the geometry problems can be fixed by the same code group adjustments. You know to write down all the default values before changing them right? Anyways with the TV off press within one second of another Display, then 5, then Vol up, then power. That is the sequence that gets you into the SM. To get out of it simply hit power again (to power off) and when you hit power again you will be in normal mode. Try that a few times until you are comfortable at least bringing up the SM and getting out of it. Don't do anything else. Now, I don't know if this is the way to get into the SM on the 970. It is the way with the 910/955/960's. Come back with questions on how to scroll through the SM and change values and make them permanent. Let us know if you are able to even get into the SM in the first place. All this I am telling you is on the third post of the Service Menu thread referenced earlier. That tells you how to navigate it.
Old 11-19-06, 03:18 PM   #24   |  Link
Soshnick93
wat do u mean with the tv off within one second of another display then 5 then vol up wat does that mean lol
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-19-06, 04:34 PM   #25   |  Link
Jerm357
See if you dont even understand this I realy dont feel good about you in the service menu but its your decision so heres goes.........
To enter the Service menu
-with tv off
-hit the "Display" button (all buttons are on the remote)
-hit the "5" button
-hit the "Volume Up" button
-hit the "Power On" button
To navigate use the remote's "1" and "4" buttons
To change values use the "3" and "6" buttons
To save and write a change first hit "Mute" and then "Enter."
Good luck and be carful.
Old 11-19-06, 04:35 PM   #26   |  Link
kigasman
HD NOOB
How does analog material look on the Sony CRT HDTV? I have a 32" Bravia XBR2 and the analog picture sucks; it looks great with HD loop at best buy. but a bit fuzzy with non hd digital dish network signals and analog over antenna. I am very disappointed and unsure if its a LCD thing or a HD / analog signal issue. I have also been looking at a Samsung slimfit tx-s3080wh as the 34" sony is a bit wide overall for me; but that seems to have lots of geometery issues, how are the Sony 34" CRT?
Kevin
kigasman is offline   Reply With Quote
Old 11-19-06, 05:28 PM   #27   |  Link
Soshnick93
sony makes defenitly the most amazing crt tube hdtvs!
__________________
My HDTV
Sony KD-34XBR970
Xbox Live Gamer Tag
Soshnick 93
Old 11-20-06, 03:55 PM   #28   |  Link
justsc
Kevin
Analog and digital SD look great on my 34" Sony crt set. But it took some work with a calibration dvd (e.g. Avia, DVE). Unfortunately, HD sets tend to bring out the worst in analog and SD material.
But, I'm concerned that it looks so bad on such a good Sony LCD set. My Dad's got a 32" Panasonic LCD set and analog material looks wonderful. Your XBR2 set is supposed to be top of the line, and I've seen how good it is. I'm just wondering if you have bad cabling or a bad satellite box?
Old 11-20-06, 07:59 PM   #29   |  Link
raouliii
See if you dont even understand this I realy dont feel good about you in the service menu but its your decision so heres goes.................
Geometry is VERY difficult to correct without good patterns such as crosshatches. It is also difficult to help someone do these corrections via posts. I'm expecting this to turn out bad. I hope I'm wrong.
__________________
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline   Reply With Quote
Old 11-21-06, 11:07 AM   #30   |  Link
DJF(NJ)
LOVE my 2004 XBR960!!!! It's been ISF'd calibrated WITH geometry and is only used with my Toshiba XA1 HD DVD player on the weekends to show its true potential! No problems at all and I really hope this TV lasts a VERY long time.
DJF(NJ) is online now   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.35786891 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
