#1 | Link |
Big Fan of Goodly HD
AVS GOLD CLUB MEMBER
Bluray does not support 1080p30!! Did not know this!
Hi Folks,
I was browsing the posts this morning and bumped into a story about the Nine Inch Nails concert video being released on both HD DVD and Bluray. It was filmed using progressive (non-interlaced) 1080p cameras, which are becoming the latest thing now. As you know, these record in 1080p30, instead of 1080i60. Now the HD DVD is being released as 1080p30. BUT... the Bluray disc version is being released as 1080i60 because Bluray cannot support progressive video at 1080p30. Whoooaahh... Stacey confirmed this here http://www.avsforum.com/avs-vb/showt...&&#post8916888
__________________
JL Fathom f113 = Love! |
#6 | Link |
Well, I'm not sure if you realize that 1080i60 and 1080p30, done properly, is exactly the same thing as long as the source is recorded progressively? You take one full frame of 1080p video, split it into 2 interlaced fields and record on disc. During playback, both interlaced fields should be reassembled into one full frame, exactly the way it was when recorded and maybe double the frame rate to 60 Hz. Of course the key word here is "if done properly", because you could also reassemble field number 2 of frame 1 with field number 1 of frame 2 and have horrible motion artifacts. Also I don't understand why they have to have 1080i60, why not simply double the frame rate and record 1080p60? Do those people know what are they doing??? Not many TV's can handle 30 frame rate anyway and most of the time 1080p30 needs to be changed to 1080p60 by the player before the signal goes to TV. It's not like BR discs don't have enough space to handle extra data?
#7 | Link |
AVS CLUB MEMBER
1080p30 is still fairly uncommon so I don't know of any current deinterlacing chips that can deinterlace or inverse telecine 1080i60 back to 1080p30. It is not really hard to do. For instance my UnComb filter on my web page does it simply. But you first have to know that you are even supposed to do it and any automatic detection of that vs all the other forms of deinterlacing and inverse telecine can get tricky. So I sort of doubt most TV's can do it correctly yet. But hopefully I'm wrong.
- Tom
__________________
Yes, it just doesn't look right because it seems too real. But we want it and are willing to pay for it. Sell it to us. Tom Barry See my video filters at www.trbarry.com |
#8 | Link | |
For instance, if HD DVD was saving movies to disc as 1080i60, instead of 1080p24, this point would be (rightly) highlighted as an oversight. Film is native 1080p24. Video, at 1080p30, should be saved in it's original format also. Even though the video could be theoretically reassembled by a VP or your TV set, it represents an unusual format that most TVs probably might not understand how to re-assemble - as they would not likely EXPECT to have come across 1080i60 video that DOESN'T have interfield motion.
__________________
#9 | Link | |
Gary |
#10 | Link | |
What a blow to Blu-Ray! A concert in HD will have to be 1080i60! STOP THE BLU-RAY DISC MACHINES!! This is it!
Why dont you petition HD-DVD to have playback at oh, i dont know,1080p24? Oh thats right, ITS NOT IN THE SPEC FOR THE HARDWARE. And none of HD-DVD players in existance or being made do 1080p24. Theres plenty for Blu-Ray. Of course, that would be the best solution in terms of FILM, which is what these devices were mainly intended for. But hey, you get 1080i30! ROCKIN!!! Seriously, this thread is so hilarious on so many levels. |
#11 | Link | |
AVS CLUB MEMBER
People has been successfully doing 24p/72p from HD DVD for a long time either by using software player or video processor. HD DVD player with 24p output feature will come shortly. It is certainly in their agenda otherwise why bother discussing it under a special DVD Forum meeting early this Nov? I expect 24p to be a standard feature next year for players from both camp. AFAIK, the only two 24p capable blu-ray players has not on the market yet. BTW, both HD DVD and blu-ray are encoded at 24p for film. This no 30p in spec thing might force blu-ray to encode it as 60i which might mean they have to convert the 30p master into 60i before sending it into the encoder. If this is true, will it make any difference for the end user? I personally don't think so. But some blu-ray supporters and Joe Kane disagree. Thelion? Hope some insiders could clarify the situation. |
#12 | Link |
The impact of this is the inability to burn 30p home videos to BD AND have it play on a BD player. Note the AND. Thus, if you own a new HD camera such as the Canon XH-A1, you have to figure out some other means of distribution. The bleeding edge of technology has its price. Everything is always a year away or 365 days late.
It may have been envisioned that 30p would be subsumed by 60p, in the BD camp. A slight waste of bandwidth, but who cares if you have the space? |
#13 | Link | |
AVS CLUB MEMBER
#14 | Link | ||||
#15 | Link | |
AVS CLUB MEMBER
I couldn't believe you are still spreading this no 1080p24 for HD DVD FUD. Give me a break. Other blu-ray supporters at least only attack on the 24p output issue which I think is fair and worth a push.Also the 24p to 60i/60p conversion is happening on the player side for HD DVD and with proper implementation HD DVD could also output the "pristine 24p" This 30p-60i might happen on the encoding side for blu-ray which means 30p master might be forced to 60i before encoding. If this is true, tell me which do you consider to be more of a problem? |
#16 | Link |
Yay - 30p HD DVDs.
So, which player will have 1080p 30 fps output? What is the difference between video stored as 30 frames progressive and the same information stored at 60 fields interlaced? Sounds a lot like 30fps PSF (Progressive Segmented Frame) to me. |
#18 | Link | |
Currently none of the HD DVD players do 1080p at any frame rate. The Pioneer is expected to do 24 fps and perhaps the Sony when they are released. Perhaps someone can fill in whether the XA2 HD DVD player will handle this though from what I have heard it is a post-decode deinterlacer like the current 1080p BD solutions and is priced similarly. |
#19 | Link | ||
AVS CLUB MEMBER
Someone using software player has doing 24p/72hz from HD DVD on his CRT FP for a long time. Decoder suppliers confirmed it was doable for HD DVD also. Quote:
To make the matter worse, for blu-ray the 30p master-60i might happen before the encoding. So if there is anything loss during the 30p-60i conversion such as filtering, it couldn't be undo. However for HD DVD, the 24p-60i is happening inside the player. If the conversion is not perfect, you always have a chance for a new player or video processor to get it right. BTW, how many video footage are shoot in 30p mode? AFAIK, blu-ray doesn't have 25p in spec also and has to encode 25p native as 50i on disc. Is this also true? |
#20 | Link |
Innocent Bystander I
If you weave it, you get 1080P60. But weave is the wrong default setting for 1080i because of all the sports and musicVideo programming at true 1080i which should be 'bobbed'. Which means unless you set the mode on your player (which can be done in PC, but doubtful on TVs), it can work --- if you have the option, just select 'film' or 'movie' and it will weave. (It might try to do some 3:2 thing too, which would be bad).
I'm not aware of the use of 1080P30 as the 'latest thing'. Where can I get this 'latest thing'. My HDR-HC3 and HDR-UX1 both can only do 1080i60, not 1080P30. If it is the latest thing, there's no question, I have to get it. So where can I find this amazing gadget? |
#21 | Link | |
AVS CLUB MEMBER
![]() This is a real issue. I'm not saying it is a big deal, but I think Blu-ray would be better if they supported 1080p30 storage in the long run, than not supporting it. At the least it would help compression with those sources since compressing full frames should be easier than compressing interlaced fields. I know they already have more headroom, but 1080p30 storage would be nice. What the HD DVD players end up doing with things stored as 1080p30 in the long run makes a difference also. Hopefully they will be able to output 1080p60 from that where basically the only thing they are doing is frame doubling. They could interlace to 1080i60 before output, which is what I suspect the HD-A1 and others like it do. --Darin
__________________
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me." |
#22 | Link | |
The clincher is : I don't know of a TV that takes 1080P30. There are ones that can take 1080P60 or 1080P48/72 --- if your HDMI output chip can really generate 1080P60, turning on the weave flag and sending 1080i YUV to that HDMI chip should make it work. Still, it should be enabled if it is indeed the newest cool thing under the sun (which I doubt). |
#23 | Link | |
#24 | Link | ||
AVS CLUB MEMBER
Last I thought this thread is about no 30p for blu-ray, no? |
#25 | Link | |
AVS CLUB MEMBER
I was not aware of that. If most can do this, to which format do they convert? And in which format is the video then passed to your TV or display? - Tom
__________________
#27 | Link | |
AVS CLUB MEMBER
I am also a little bit worried about the 30p master-60i process before encoding. If you use interlaced compression algorithm for a progressive source, would it be any different from the native progressive encoding? Blu-ray might have the same concern for native 25p source. AFAIK, it only has 50i in spec. |
#28 | Link |
Warbulator Expert
I fail to see where this is some kind of giant problem. It's not like the entire world of movie entertainment was captured at 30fps progressive in the first place, it was captured at 24fps on film and the newer digital cameras also are used at 24fps.
Even if you store a native captured 30p at 60i there is no temporal distortion to recover the 30p for display. This is unlike the awful mess we have with 24fps converted to 30fps and trying to recover the original 24fps without error to eliminate the judder. b2b
__________________
"Listen, You Pencil Neck Geeks.." 'Classy' Freddie Blassie ~ 1918-2003 A Toshiba spokesman, said that "from an engineer's point of view, the Blu-ray is a masterpiece.." |
#29 | Link | |
Dreamer
The National in the Panasonic can perform 2-2, but its not reliable either. At least it drops to video instead of weaving when it should not. ![]() Your best bet is an external box from ABT, Gennum or Silicon Optix. (As I said in the original thread.) 1080p30 is rare, so it is far from the end of the world. This and the limit on the number of B frames in BD is surpising. |
#30 | Link | |
Gary |
| Bookmarks |
| Thread Tools | |
