AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 11-19-06, 04:53 PM   #1   |  Link
kenchi
Arrow Harmony 880 and Playstation 3
Has anyone set this up?
I tried to, but it won't turn on/off the PS3.
The Harmony installation recognizes the PS3 as a Video Game device, but doesn't seem to work for me- any others try this out?
kenchi is offline   Reply With Quote
Old 11-19-06, 05:24 PM   #2   |  Link
DIY Guy
HT Enthusiast
Isn't the remote for the PS3 using blue tooth? The 880 is IR based.
__________________
Steve
DIY Guy is offline   Reply With Quote
Old 11-19-06, 05:26 PM   #3   |  Link
kenchi
yes, I just figured that out. - Thanks for the reply.
Old 11-27-06, 08:45 PM   #4   |  Link
Stupac
Is there a remote like the 880 that will work with the PS3
Stupac is offline   Reply With Quote
Old 12-03-06, 05:35 PM   #5   |  Link
oopsydaisy
Once my PS3 is shipped(Ebay), I plan to try a USB IR receiver/transmitter I currently use on my HTPC. If the PS3 picks it up, the 880 should work just fine, once I program it with all the Blu-Ray playback options needed
oopsydaisy is offline   Reply With Quote
Old 03-09-07, 12:23 AM   #6   |  Link
plissken99
Classified Rating: 100% (1)
Did you ever try this?
I've been looking to replace my Pronto 2000 with something like a harmony controller, and since I just got the PS3, I really want a remote that can do Blue Tooth.
__________________
The more things change, the more they stay the same.
Snake Plissken
plissken99 is offline   Reply With Quote
Old 06-23-07, 12:10 AM   #7   |  Link
MoG
snagabag dot com
AVS CLUB MEMBER
does this work? i'd really like to be able to control my ps3 for movie watching from my 880.
__________________
snagabag.com - just a click away
MoG is offline   Reply With Quote
Old 06-23-07, 02:19 PM   #8   |  Link
UxiSXRD
Jedi Master
See the following threads:
http://www.avsforum.com/avs-vb/showthread.php?t=761809
http://www.avsforum.com/avs-vb/showthread.php?t=817142
Some folks have had great results with the contraption setup from Remote Central and the new Nyko Blu-wave remote IR USB dongle.
I've been trying to get my 720 to control the PS3 through the Windows MCE IR USB dongle that came with my old VAIO and no dice. (I did turn on the 360, which was kind of amusing, though).
__________________
-- "No matter where you go, there you are."
SXRD/Denon/Polk/PS3/360
Blu-ray bliss with the great PlayStation 3!
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline   Reply With Quote
Old 06-23-07, 03:28 PM   #9   |  Link
MoG
snagabag dot com
AVS CLUB MEMBER
Thanks! I found out about the Nyko solution and ordered it for use with my 880.
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.15270901 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
