AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 11-23-06, 04:03 PM   #1   |  Link
auburnu008
Harmony 880 control my lighting?
I have searched and tried to find the answer, but it seems I am more confused than ever. I have rope lighting around a projector screen and am wanting to use my harmony 880 to turn the lights on and off with my 880. I would also like to have a dimming feature also if possible. The rope light is the only thing I want to control. The rope light is the only thing plugged into the outlet. Can someone please help me and let me know exactly what I need to order for this? Thank you so much for all your help!
__________________
War Eagle!
My Theater Build thread
auburnu008 is offline   Reply With Quote
Old 11-24-06, 08:29 AM   #2   |  Link
bigdee65
Hi, I am new to the forums but I think I can help you out. There might be different ways of going about this but the main one that sticks in my head is to get yourself a lamp dimmer that can be controlled using Infrared. The only company that I really know of that offers one of these is Lutron.
Because I am new here I can't post a direct link to the product I am talking about so go to google and search for SPS-300LD-RP. The product name is Spacer System SPS-300LD-RP 300 Watt Incandescent / Halogen 120 V Table Lamp Dimmer.
What you need to do is plug the Spacer System Lamp Dimmer into the wall and then plug your rope lights into the Dimmer. Once you do that the 880 will be able to communicate with the rope lights and control them via IR.
Hope that helps!
bigdee65 is offline   Reply With Quote
Old 11-24-06, 11:34 AM   #3   |  Link
auburnu008
Thanks alot bigdee65. I appreciate the help!
__________________
War Eagle!
Old 11-25-06, 01:35 AM   #4   |  Link
shamus
AVS CLUB MEMBER
That would probably work. I got a lutron light switch dimmer (maestro) that comes with a remote and the Harmony controls it perfectly. If you can put your outlet on a wall switch it would do the trick. Got mine at Home Depot.
shamus is offline   Reply With Quote
Old 05-20-07, 09:53 PM   #5   |  Link
Matth3w
Would this work with the 720 as well? Anything that would allow you to control a light switch and not just a lamp?
Matth3w is offline   Reply With Quote
Old 05-22-07, 09:28 AM   #6   |  Link
AnthonyB
HT Nutcase
or the X10 solution.
IR543
and a lamp module
AnthonyB is offline   Reply With Quote
Old 05-22-07, 06:21 PM   #7   |  Link
Matth3w
will this work with a 720?
Old 06-26-07, 10:23 AM   #8   |  Link
Jasonn B
So did this work out for you?
Jasonn B is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12911391 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
