#1 | Link |
Moto 3416 and HDMI->DVI Failing
I recently had to replace my older Moto (Comcast) box with a new one due to PVR Drive issues. The new one is a 3416 w/12.35 firmware and MSTV). I've got a HDMI to DVI cable that the Comcast office gave me, but I cannot seem to get it to work. My TV will not init and stays on a black screen, and the STB just sits there with 'DVI' on the front panel and eventually locks up, requiring a power cable pull to fix. I've read a bunch of the fixes on Wikipedia, etc. and could not get anything to work. Diag mode shows N/A for the HDCP enabled option in diagnostics, and I cannot get the HDMI connection up to see if HDCP is working. It locks up when both Component and HDMI/DVI is connected. I have a Hitachi 42HDT55 which does not have HDMI inputs. I have the STB set to 1080i and 16:9, but have tried 480p, i, and 720p as well without luck. I've tried all manner of turning things on and off in different orders, etc.
Component does work, but I notice a lowering in PQ while viewing HD material between component and DVI, which is why I would like to get back to DVI. Of course Comcast does not have any DVI PVR boxes anymore... I do have a separate non-PVR STB (older 6412 with DVI out) which works with my TV (DVI to DVI) just fine. Anyone have any ideas?? Thanks...
__________________
-Jerry |
#3 | Link | |
TH50PX60U
#5 | Link | |
Thanks for replying guys!
I tried as you suggested, and unfortunately, the additional HDMI settings selection is grayed out and will not allow me to select it. This was with S Video while the DVI was connected. I'll try again tonight using component instead... Thanks for the help, I'll let you know.
__________________
-Jerry |
#6 | Link |
Actually, the "HDMI Settings" or "Additional HDMI Settings" isn't there at all. Weird... I suspect it is because the DVI isn't hooked up when I am in the menu, because if I do hook it up, the 3416 just locks up and displays DVI on the front screen.
__________________
-Jerry |
#7 | Link | |
New Member
Have you tried doing it "blind". In other words, memorize the steps needed to change the setting if it wasn't grayed out then connect the DVI cable and do it that way without being able to see it on the screen. I've had to do that in the past with my old TV that didn't support 720p.
On a side note, you won't be totally "blind" either because the box does display a portion of the menu right on the box itself. Quote:
| Bookmarks |
| Thread Tools | |
