#1 | Link |
New Member
Time warner and Olevia remote?
I have the Olevia Black 37" Model 237V.
My cable remote does not recognize an Olevia tv. It is a pain to keep up with both remotes. Is there an remote out there that will let me run my HD Cable box from Time Warner and the tv? I need the full function of the cable remote and limited function of the tv remote. |
#2 | Link |
AVS CLUB MEMBER
I just bought the Olevia 342i as a bedroom set and found the same issue - nothing for Olevia remote codes listed on the TW site. Here is a paste from the Syntax website and it worked for me. I've only had the set for 3 days and haven't checked out much of the functionality but all of the basic functions that I need work fine.
"Universal remote control manufacturers specify different codes for the various television brands out there. Please check with the manufacturer list for codes listed under RCA televisions. Any code listed under the RCA brand will work" |
#4 | Link |
AVS CLUB MEMBER
I've seen reference to the LG, Philips, and Yamaha codes working on Olevia products too. I didn't try them since the RCA code worked for my model. Since your needs appear to be minimal, an inexpensive learning remote is probably your best bet. Good luck.
#5 | Link | |
Here is the email response from Olivia regarding the remote codes.
"Hello, We currently don't have codes for this new model. Regular Universal remote will not work with our TVs. You can purchase a Universal remote from us that you can program to control your other device. A Universal learning remote will also work with this model and your other device so it will allow you to control both device in one remote. If we come out of the remote codes it will be posted on your website www.olevia.com. Thank you for contacting technical support. P.S. When replying to this e-mail, please leave the original message so I have history of all information given and received for your case. Best Regards Jay Mondares Technical Support Specialist"
__________________
Mike |
#7 | Link |
AVS CLUB MEMBER
For your limited needs there are hundreds of options. I use products from Universal Remote Control. My low-end remote that I use from the patio is an MX-350 with RF capabilities that I doubt you need. I erased all of the presets and used it to learn the commands for the functions that I need out there. I am sure others would recommend units from Harmony or Philips and they would be excellent choices too. You might consider running by Walmart, Best Buy, etc. I am sure that they have something inexpensive in this space, Return it if it doesn't do what you want.
#8 | Link |
New Member
Sony learning remote works
I purchased the Olevia 532H and was disappointed to discover that none of the remotes provided by Time Warner worked with Olevia - even when trying the various RCA, Phillips, etc. codes. To make matters worse, the universal remote that came with the TV did not properly control my STB from Time Warner.
My solution was to purchase a Sony RM-VL600 remote for ~$20 @ Wal-Mart. This remote has a learning function that allows it to learn functions from other remote controls. Setup was a little bit of a pain but now it works perfectly. Also, the Sony remote does contain a code for Syntax TV's, although this one didn't work on my model. |
#9 | Link |
Can you be more specific about the model of the remote? If it is a remote made by UEI, try TV/0056 or some NEC or LG code, and see if you get ANY reaction from the TV from any of the buttons; the functions may be mixed up. If you do, you may be able to start from there.
#10 | Link | |
I have had quite an experience with remotes recently. I too bought a 532H (and a Sony VCR/DVD player). I tried the following learning remotes with mixed results:
1. Sony VL-600 (mid $20's at Walmart)- doesn't have codes for the 532H or Sony combo VCR/DVD. It will learn codes from both the 532H and the VCR/DVD. It is stated that programming will last about 1 hr after the batteries are taken out which leaves enough time to change batteries and not lose the time spent programming 40 buttons. 2. Philips PMDVD6 (below $10 at BB) - doesn't have the codes for the 532H but does have a code for the VCR/DVD. It refused to learn commands from the 532H remote. I have an Olevia LT37HVS that the Philips remote will learn but it also has a Goldstar code that gets most of the 37HVS buttons to start with. I was rooting for this remote since it was the cheapest, lightest and used flash memory to hold codes but alas didn't work with the 532H. 3. URC R5G (just below $30 at CC) - the package stated that this remote has Syntax Olevia remote codes. I tried all 4 but they didn't work. I also did a code search without any success on the remote. This remote did learn from the 532H remote. But I didn't like the reponsiveness of the learned buttons. The TV would missed button presses now and again. It was annoying when trying to put in a channel from the number pad (that was learned). 4. URC FX1 - this is the non-learning version of the R5G above. I returned it without opening it because the R5G codes didn't work so I didn't expect the same codes to work here. In the end I programmed all the buttons on the Sony VL-600 to work with my setup and am happy for now. |
#13 | Link | |
New Member
I had that same problem with my 227v and my cable box from Time Warner. I just went out a bought Logitec's Harmony 550 and it works perfectly. It's bit on the expensive side I'm happy with it. |
#15 | Link | |
New Member
Learning remotes make life easier/Olevia Doesn't
I've done research on this subject. I have an Olevia 427-S12 LCD HDTV with a Time Warner Cable Explorer 3250HD box. It comes with the Atlas dvr universal remote. If you do a blink back you will come up with 0047 (an RCA code) but it will not work. I emailed Olevia about the issue and have not heard back from them yet. The support information on Olevia's website says For the 3- 5- 7- series
4 series is included in this group as well)"This line of product is new to the market; STB manufactures have not included our brand in their code list yet. We recommend using a learning remote control for both the OLEVIA TV and your set top box." Learning remotes receive the infrared beam from your existing remotes and store the frequency and pulses in memory. The tricky part of choosing the right one is understanding what it is you want to control and how much you are willing to spend. After that just read up on CNET and be cautioned that all learning remotes are not created equal. Some entertainment equipment manufacturers use pulse frequencies that are higher than what the learning remote can detect and store in its memory so don't buy the most basic or you may have to fork out more money later. GOOD LUCK I am going with the Logitech 720 because of the features it offers. It's around 200 bucks so the money saved by buying the OLevia LCD wasn't the windfall I thought it was. LOL I don't have to spend that much or buy the Logitech but decided to go with it after looking at 10 different models. I will be using for more than just the STB and the LCDTV so it is a worthy investment in my case. Last edited by olevia427woes; 01-13-07 at 10:39 PM.. Reason: adding |
#16 | Link |
New Member
I also recently purchased an Olevia 237-V 37" HDTV. I am also having zero luck in finding the right code for my Cox Cable remote.
What is really weird is that this is my second Olevia 37" HDTV. For the life of me, I can't remember the exact model # that I bought last year and, unfortunately, my ex-wife now has the TV. But I do remember that using Cox Cable on that TV the cable code was easy to set and worked perfectly. Now, with the new Olevia HDTV I just bought, (the 237-V), I can't get anything to work. Cox remotes have a code you can put in that will find out what the code is. I've done it a hundred times and NOTHING works using that technique. This leads me to believe that Olevia is using different coding probably based on the use of different vendors for various parts and pieces. No other explanation I can think of. What is most frustrating is the LACK of communication from Olevia regarding this problem, (which, by all indications, is a huge problem.) Olevia needs to let us know what is happening and when it's supposed to happen. That's just my opinion but good customer service dictates nothing less. I might be crazy, but no TV manufacturer is egotisical enough to think that the remote control they include with their TV's is going to be used more than 1 hour a year. So what's up with all this code crap? I suppose Olevia can just sit back and say "hey, you got a remote control with the TV". Yeah, I'm frustrated at having to go purchase a learning remote in hopes that it will work. The only thing that keeps me from blowing a fuse is how well the Olevia 37" performs. (Remote control codes excluded!) Not to mention that I love my Cox Cable remote because it's very handy. |
#17 | Link |
Before a mob forms to go string up Olevia
, I'll explain a possible way to make the remote work with the TV for the very determined people (and with the right type of remote). While I don't have the Olevia TV, I do have an HP TV that didn't work with my Comcast remote until I found this solution, so I feel your frustration.First, to explain what the problem is: The new Olevia models seem to be using a fairly common protocol (NEC), but they change the device number from their previous models. Most the the remotes have the protocol built in, and should be able to be programmed to talk to the TV, but the TV isn't listening since none of the built in codes have the right device number to tell the TV to pay attention to the commands. As for a possible solution, many remotes are made by UEI and lot of those have a 6 pin header that can be used to upload upgrades using a computer to add a new instructions with the correct device number. Check the battery compartment of the cable remote and see if you can find a 6 pin header (4 pin in a single row, which I've seen in some remotes is not the same thing). If there is, there is a good chance you can upgrade the remote to add the correct protocol for the TV. Around the header, it should say either "JP1" "JP1.1" or "JP1.2". On my Comcast URC-1067 remote, .2 part of JP1.2 was hidden by the plastic case, so look carefully. You can now go to this site and read about JP1 cables and how you can use it to connect to a computer to upgrade and program remotes made by UEI. There's also a lot more information at the forum You can either buy the cable from the links provided on that page (I think only diygadget actually still sells the cables), or make the appropriate one yourself depending on your remote and the type of interface you have available on your computer. You can find the instructions here; "simple interface" for JP1 remote using parallel computer interface, or JP1.x for JP1.1 or JP1.2 remotes. You need to get some software (Remotemaster or Keymaster, and IR), and some RDF and map and image files for your remote from here, and this should be the upgrade file for the new Olevia TV's that uses the RC-LTL remote. This may seem like a lot of work just to get a remote to work with your TV; I said it's only for the really determined ones. But it does make your remote lot more capable besides making it upgradable (which by itself is pretty big). I happen to know how to solder passably and had most of the parts around so it wasn't too difficult nor expensive, but it might not be so easy for others. Just a little disclaimer; as I said, I don't have the Olevia TV in question here, so I haven't actually tried the upgrade file myself. I'm going on what I know about these remotes, and examining the upgrade file that someone else had made and uploaded to the JP1 site. However, there's been about 30 downloads of that upgrade, according to that site, and I haven't seen any complaints, and there's one comment that confirms that it's worked for his 232V as well. |
#18 | Link |
New Member
um, thanks for the post Kupakai and my frustration is almost to the point of trying this, however why cant Olevia put out an update that would fix this for the thousands of people who are pissed off? guess im gonna try going to the learning remote. gonna look into those now. any that resemble a dvr/tivo remote?
#20 | Link |
New Member
I have a UR5-8400 remote made by Universal Remote Control - for Time Warner Cable, NYC. I talked with Universal's customer service, sent my remote to them, they updated the remote's code list, and programmed code 432 as the TV. Free of charge, I can now control my 532H with my remote that controls the rest of my system. OH YEAH!
#21 | Link |
New Member
The code to punch into the Olevia remote to operate the Dish Net satellite receiver is 3030. I haven't yet found a code to put into the Dish Net remote to operat the Olevia HDTV. However, a good learning remote which can operate both the Olevia and the Dish Net units is the Sony RM-VL600, for about $25.
#22 | Link |
Wine & Travel
Sony RM-VL 600 as a "quick fix"
I also use the Sony RM-VL600. It is excellent, if somewhat limited (not so many buttons, and no "soft" buttons you can label like the Harmony remotes). It does handle macros, though, so you can program it to turn everything on or off (for example).
Sony has been selling it direct, refurbished, for $15! Some weeks they even offer free shipping! http://www.sonystyle.com/webapp/wcs/...52921665092997 This is the best quality "budget" solution with learning and macros (4 "one touch" macro buttons and 8 "hold down for two seconds" macro buttons). The learning function is made easier by the ability to learn several buttons in sequence at the same time - saves a lot of button pushes and finger muscles! It is - by far - easier to use than the "universal" remotes supplied by cable and satellite companies ... IMHO, of course! |
#23 | Link |
New Member
The Sony RM-VL600 works great
Thank you to those on this forum that endorsed it.
I purchased an Olevia 242T from Target. I love the TV but could not get my Comcast remote to accept any of the Olevia codes provided. I tried an RCA Universal that supposedly was a learning remote, but it didn't seem to work. So based on your recommendations I went and picked up the RM-VL600, and it works great. I've got everything programmed to it and I've tucked the originals safely away in a drawer. |
#24 | Link | |
Wine & Travel
Sony RM-VL 600
#26 | Link | |
New Member
#27 | Link | |
#28 | Link |
New Member
The remote I just obtained from Time Warner is a Universal Electronics ATLAS OCAP 5-Device Remote Control with the number 1056B01 on the back. The setup TV code used for my Olevia 537H was 1610. Other numbers are listed in the users' guide (1144, 1240, 1331), but it was only the 1610 which worked for my television. Now I only have to use the one universal remote to control my cable viewing.
| Bookmarks |
| Thread Tools | |
