AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Digital Video & Audio Devices > Home Theater Gaming > PlayStation Area
Forum Jump
Old 12-06-06, 01:37 AM   #1   |  Link
Darknight
720p HDTV owners, DO NOT UPGRADE TO 1.3 until you've read this
Sorry for this seperate topic, but I wanted to stress that people saw this before just randomly updating their system.
In the old firmware, 720p had higher priority over 1080i. The new firmware update reverses this so 1080i has higher priority over 720p. The problem here is, if you play the following, this is what you'll get:
A game that only supports 720p, you'll get 720p
A game that supports up to 1080p, you'll get 1080i instead of 720p
Blu-Ray movie 1080i
If you try to disable the 1080i resolution to always get 720p, the problem is when you play Blu-Ray movies, you'll only get 480p.
This is a significant step backwards and before you update your system, be sure you know what kind of functionality change you'll be getting. I'm going to hold out for now till they fix this.
Darknight is offline   Reply With Quote
Old 12-06-06, 01:41 AM   #2   |  Link
dogdoctor
too late...glad I like Monday Night Football in 1080i. but thanks for the delayed heads up though, hopefully others will benefit.
dogdoctor is offline   Reply With Quote
Old 12-06-06, 01:42 AM   #3   |  Link
firefighter81
I don't notice any difference between 720p and 1080i anyways. Maybe I'm not looking for the right thing, dunno
firefighter81 is offline   Reply With Quote
Old 12-06-06, 01:43 AM   #4   |  Link
GeorgeLV
Originally Posted by firefighter81
I don't notice a huge difference between 720p and 1080i anyways. What's the big deal?
60 fps vs 30 fps. Possibly lower performance, etc.
GeorgeLV is offline   Reply With Quote
Old 12-06-06, 01:44 AM   #5   |  Link
firefighter81
Oh ok, well I don't play alot of high speed games yet, maybe that's why I'm not noticing. I'll do some experimenting.
Old 12-06-06, 03:11 AM   #6   |  Link
Chris Dotur
Well, I just bought mine today, and it made me update to the latest software before I could do any online stuff at all. So I didn't have a choice--I'll live with it for now, and since I just got it, we'll have to see how much it affects me.
I've got a Panasonic PTAE700 projector at 720p.
Chris Dotur is offline   Reply With Quote
Old 12-06-06, 03:13 AM   #7   |  Link
Marc Alexander
Inactive Member
Originally Posted by Darknight
Blu-Ray movie 1080i
Is this the case with both HDMI and component?
Marc Alexander is offline   Reply With Quote
Old 12-06-06, 03:33 AM   #8   |  Link
Hughmc
I have a GW3 788p native LCDRPTV.
When I first got the PS3, I set the PS3 max resolution to 1080i, instead of 720p and left the 480p and 720p unchecked. It defaulted to 480p for demos and R:FOM BD game that are 720p. I went back into the display settings and although I didn't select anything other than 1080i, 480p would be auto checked.
If I were to watch an HD channel like Fox through sat or cable in 720p, my tv would not down convert to 480p, but rather up convert to my tvs native 788p. The same was true with 1080i channels. If I fed my tv 1080i channels it would convert to my tv's native resolution of 788p. I always thought 1080i looked better on my tv though so that is why I tried with the PS3, figuring maybe it would be the same, but obviously it wasn't. As we now know it can't up convert.
I tested it again after the update tonight. I set the max res. to 1080i and left 720p and 480p unchecked. It still took the 720p demos and down converted to 480p, although it didn't auto check 480p. I then tried the 1080p demo of NBA 2007 again having the PS3 resolution set to only 1080i and I don't know what it is doing. So the PS3 is not letting my tv do the conversion like my sat box would is my guess. Or am I missing something and confusing this issue. After messing with this and typing all this I am .
Hughmc is offline   Reply With Quote
Old 12-06-06, 03:56 AM   #9   |  Link
dogdoctor
Sony GW4 automatically detected 1080i as max resolution. Watch Casino Royale in 1080i - stunning. Loaded resistance and it dropped to 720p as it should. As far as I'm concerned, good update.
Old 12-06-06, 04:19 AM   #10   |  Link
Hughmc
Dog, I am thinking it is not a negative update as suggested either.
Old 12-06-06, 05:19 AM   #11   |  Link
totalz
no matter what, $ony is still screwing up on simple thing...
if the user prefer 720p, 720p is what he should get, period.
totalz is offline   Reply With Quote
Old 12-06-06, 08:35 AM   #12   |  Link
divideby0
I have yet to see the difference between 1080i and 720p in a game, fast moving or not....Sure we read on the net there is a diff., but I have yet to see one myself... when I have tried to.
sounds this update is good for DVDs...
divideby0 is offline   Reply With Quote
Old 12-06-06, 09:14 AM   #13   |  Link
Kid Red
So this update basically makes the PS3 send a 1080i signal instead of a 720p signal when it's 1080i or 1080p? Why is that bad? My TV will just downconvert everything to 720p like it always does.
Kid Red is offline   Reply With Quote
Old 12-06-06, 10:47 AM   #14   |  Link
QuadESL63
Blu-Ray movie 1080i
Is there any differences between the new and the old firmware versions w.r.t. to this? Blu-ray movies are always in 1080i (my 720p projector cannot accept 1080p) and 720p Resistence is always 720p.
QuadESL63 is offline   Reply With Quote
Old 12-06-06, 10:47 AM   #15   |  Link
tokerblue
- This is AVS, why introduce another conversion step when it isn't necessary?
tokerblue is offline   Reply With Quote
Old 12-06-06, 10:51 AM   #16   |  Link
lovswr
Becuase if your display device is native 720p then if you can get 720p with no conversions that is better. What your set is doing is converting to 540p first!
__________________
carry on with your HD-Lite Directv loving banter! <--Comedy Gold
Don't fall for the HDMI 1.3 Hype!
lovswr is offline   Reply With Quote
Old 12-06-06, 11:17 AM   #17   |  Link
dark1x
This doesn't apply to all TVs, however.
My Pioneer plasma properly handles 1080i, for instance (rather than throwing out half of the vertical resolution).
Take a look here...
http://www.hometheatermag.com/hookmeup/1106hook/
dark1x is offline   Reply With Quote
Old 12-06-06, 11:21 AM   #18   |  Link
JackLT
What if you just check 720p and nothing else?
__________________
Test Your Display,
Tips for Large Monitor Use
: 720p, 1080p Test Patterns, Tips Just Click Here
JackLT is offline   Reply With Quote
Old 12-06-06, 11:51 AM   #19   |  Link
kaze0
I guess this explains why i didn't think Terminator looked all that hot on my HD70? Its dumping half the resolution?
kaze0 is offline   Reply With Quote
Old 12-06-06, 12:11 PM   #20   |  Link
joeblow
joeblow's Avatar
AVS CLUB MEMBER
Off-topic... hey JackLT, your sig link has some cool tests; you think they'd be fine to use for my Sony SXRD if I store the jpegs on my PS3?
joeblow is offline   Reply With Quote
Old 12-06-06, 12:24 PM   #21   |  Link
jayselle
Thanks for the warning. I will not be updating my firmware.
I have a native 720p DLP that will accept 1080i but I would rather have it take it's native resolution.
Why is this so hard for Sony? My DVR has no problems doing this. I say output 720p for HD content. For stations that broadcast in 1080i it converts to 720p. For the analog stations that broadcast 480i I allow it to pass that through for the TV to convert to 720p.
jayselle is offline   Reply With Quote
Old 12-06-06, 01:01 PM   #22   |  Link
Anthony1
Anybody using the PS3 with a Mitsubishi HD1000u projector? My projector is supposed to arrive today via UPS, and I'm not sure whether I should use the new firmware or not. I guess I'll hold off for now, until I hear from a HD1000u owner.
Anthony1 is offline   Reply With Quote
Old 12-06-06, 01:25 PM   #23   |  Link
Kid Red
I don't understand the bitching here, really. Half of the HD channels broadcast in 1080i. A lot of people with 720p sets also have an upconverting DVD to whoa, 1080i.
So now rather than getting a 720p signal, I'm getting a 1080i signal from PS3? It's not like this is strange for my TV which has been sent 1080i since I bought it.
Old 12-06-06, 01:26 PM   #24   |  Link
Neo57
Hey Hughmc,
I just received my ps3 last night. I plan on setting it up tonight. I know we have the same tv's. The GWIII. I was wondering what settings you ended up choosing/using. I'm more than likely going to be connecting via hdmi to dvi cable.
Neo57 is offline   Reply With Quote
Old 12-06-06, 01:27 PM   #25   |  Link
Kid Red
I noticed no difference since upgrading. So it's not all 720p owners that need to be concerned.
Old 12-06-06, 02:08 PM   #26   |  Link
Shinraven
this is bS ! sony needs to get their act together.
Shinraven is offline   Reply With Quote
Old 12-06-06, 02:39 PM   #27   |  Link
JyuOH
Agreed, I don't see why its so complicated, if MS could get it right why can't a hardware company? Well hopefuly it gets worked out sooner or later.
JyuOH is offline   Reply With Quote
Old 12-06-06, 02:42 PM   #28   |  Link
jayselle
And you think you're getting the full resolution you should be? How do you think your display converts 1080i to 720p?
Old 12-06-06, 02:46 PM   #29   |  Link
Kid Red
The same way it's been doing it is my point. I've had an upconverting to 1080i DVD player and half the HD channels I watch are 1080i and look the same if not better than the 720p feeds. So I don't see the difference or what the big deal is. It's what I's used to. And I don't see any difference before and after the update. RFOM is still fast, no hiccups, no jaggies, everything looks as it did at 720p.
Old 12-06-06, 02:54 PM   #30   |  Link
Shinraven
people are bitching cuz sony was talking smack about HD gaming starts...when we start. 1080p blah blah.....they cant even get 720p / 1080i without a nice mess.
its to be expected that a company would have issues out the gates. but this is becoming lame. considering this thing cost $500 +. not cool
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.28046608 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
