AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 12-08-06, 02:33 PM   #1   |  Link
superflysocal
low to moderate priced seat shaker
Had some questions on seat shakers and how they are hooked up. Here are some i am considering. Can someone tell me how they are hooked up? Can any unit (1 unit) be used for more than one seat somehow (to save $$)?
a. bass shaker pro
b. buttkicker 2 (is this the same as buttkicker lfe?)
c. Clark transducer silver
superflysocal is offline   Reply With Quote
Old 12-08-06, 03:46 PM   #2   |  Link
KenLerch
Shakers
You usually split the signal from the Subwoofer out on your AV amp/tuner, unless you have a second subwoofer out. The Buttkicker products offer a wireless send and receive unit to transmit the signal over to an amp that should be positioned near your seats. If you don't go wireless then you need to run a cable from the AV amp to your dedicated shaker amp. Then you wire from the dedicated amp to your shakers. Ideally you should have one per seat, but you can save on the number by mounting them under a riser. If you go that route put your riser up on isolators to isolate them from the main floor. You can also get away with fewer if you are using a sofa-type setup. Just use some rubber isolators, again, to keep the furniture de-coupled from the floor. If you can afford the Clark Synthesis, go that route. The performance is amazing and very precise in that you can differentiate foot steps from an explosion and vice versa.
__________________
Ken Lerch
StargateCinema.com
KenLerch is offline   Reply With Quote
Old 12-26-06, 11:42 AM   #3   |  Link
superflysocal
how do you mount the clark silver? is it designed for 1 per seat?
Old 12-26-06, 02:25 PM   #4   |  Link
KenLerch
Clark Silver Mounting
Yes, it is designed for one per seat and should mount directly under the seat itself and pointing upward toward your nether regions . Here's a link to a nice "how-to" from a DIY that installed three under his "Jurassic Couch" creation.
http://www.clarksynthesis.com/review...ssic_Couch.htm
The process would be similar if you mount to individual HT seats like Berklines, etc.
__________________
Ken Lerch
StargateCinema.com
Old 01-10-07, 11:13 AM   #5   |  Link
Neuner
Don't know if this is up your alley but Here Is a Link for a DIY Tactile Transducer.
I made one of these in college & it worked awesome! Alot better than any Buttkicker I've experienced. Probably more of what the Clark is like. The upper cutoff frequency is self regulated by the amount of weight that is applied. We had a 12" version strapped to the floor joists in house we rented and with only 50W it shock the whole house. During the opening scene of 'Independence Day' a water glass from 12' away from the source vibrated off of a coffee table. It really transitioned in well with the subwoofer.
Neuner is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10985804 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
