| View Poll Results: What's your maximum supported level of audio | |||
| RCA analog stereo only |
5 | 1.90% |
| Optical/Coaxial |
89 | 33.84% |
| Lossless multi-channel through analog RCA, HDMI or Denon Link/IEEE |
169 | 64.26% |
| Voters: 263. You may not vote on this poll | |||
Thread Tools |
#2 | Link |
Um, I find your choices for audio capabilities of readers' HT setups confusing. Shouldn't it be more like:
Dolby Surround/Pro-Logic Dolby Digital DTS and so forth? And that's just for processing. What about total number of channels (5.1, 6.1, 7.1, etc.)? Loudspeaker configurations? Total power? Possibly even tactile transducers (ie. bass shakers mounted in the theater seating)? |
#3 | Link | |
If you'd like to do an extensive research into the subject then go ahead. I'm merely interested to know who has optical/coaxial level and who has lossless capabilities. In other words, I'm interested in the maximum connection for audio your HT supports. |
#4 | Link | |
analog (stereo, multi-channel) optical (Toslink, etc.) coaxial (SPDIF, etc.) - the same as optical, really HDMI (1.2, 1.3) At the end of the day, you want to find out who has old-school connections for Pro-Logic via analog versus who can do DD/DTS via optical/coaxial versus who can do new-school lossless audio/uncompressed PCM via HDMI, right? Last edited by marcusm750; 12-11-06 at 02:02 PM.. |
#6 | Link |
Analog, Optical, Coax.......... my reciever doesnt have HDMI, and il waiting till sometime next year in the spring to get the newer (somewhat cheaper by then I hope) 1.3 HDMI recievers.
__________________
I support High Definition Content regardless of color! ISF Calibration is my friend, and should be yours too Enjoying TrueHD, DTS:MA and LPCM OAR - What else is there!? |
#7 | Link | |
Optical/Coax are S/PDIF digital HDMI/DLink/Analog? The first two are not analog. What a waste of time.
__________________
Kal Rubinson "Music in the Round" Contributing Editor, Stereophile www.stereophile.com/musicintheround/ |
#8 | Link | |
Surely a contributing editor to stereophile would recognize what the three levels represent no? The first one is the RCA stereo connection, incorrectly labelled composite. Labelling it analog would result in some people selecting it that use multi-channel inputs which are analog. |
#9 | Link | |
Uppity
1. 2 ch. Analog (Red/white stereo) 2. non-HDMI Digital connection (S/PDIF) 3. Multi-channel (analog or HDMI) This would be the clearest way. I agree that listing 1 as simply analog would result in overvote as people would think that means multi-channel analog. Listing as composite is wrong as composite is single RCA video and dual RCA audio.
__________________
***Warning*** Do not look into laser with remaining eye!! |
#11 | Link | |
Just Make It Work...
#12 | Link | |
Your corrections to the original poll options have made it better and I hope you get responses of value to you.
__________________
#16 | Link |
I think HDMI should be seprate from multi-channel analog.
As HDMI can output up to 7.1 vs the multichannel out is only 5.1 at the moment. Also coxial and optical should be seprate as coxial may be equal to optical but, coxial if buy it self is often found on lower end systems. But, ill vote the last choise as that's the best I've got in terms of lossless audio in. At,least over 5.1 analogs. |
#17 | Link | |
#18 | Link |
Jedi Master
5.1 Analog inputs (that are bare
), 1 coaxial and 2 optical / toslink. Has a bunch of analog stereo, but I would never use those.I think the poll would be better suited for: 1) Stereo analog 2) Multi-ch analog (RCA) 5.1/7.1 3) Coaxial 4) Optical / Toslink 5) HDMI/DenonLink
__________________
-- "No matter where you go, there you are." SXRD/Denon/Polk/PS3/360 Blu-ray bliss with the great PlayStation 3! SXRD Owner's Thread PSN: Uxi |
#20 | Link |
I use my 5.1 analog ins for lossless audio from my XA1. DenonLink for everything else from my 3910 (DVD-A, SACD, DD-EX, DTS-EX, etc). Here's hoping that when Denon makes an HD DVD player, you can send the lossless over DenonLink as well. Of course that will mean one of their new receivers to decode the signal too
__________________
Coach Jim Tressel: 1 National Title 5 Big Ten Titles 7-1 vs. M*ch*g*n 83-19 (.814) |
#21 | Link | |
#22 | Link |
I don't believe the 3rd option in the poll should include the terms "lossless" and "DenonLink" together. This is a partial quote from the user manual of the Denon DVD3930CI DVD player, page 48, "DENON LINK is a balanced transfer type digital link using high speed transfer elements. Connecting... with little loss of signal quality, resulting in high quality sound production."
So it doesn't read, "no loss of signal quality", but rather, "little loss of signal quality". Last edited by Ronnie 1.8; 12-27-06 at 01:38 AM.. |
#23 | Link | |
__________________
#24 | Link |
I was referring to the analog 5.1 for using lossless audio (TrueHD and DTS-HD) because that is the only way to transmit them right now other than HDMI. The actual audio codecs are lossless, whereas DD, DTS, etc. are lossy codecs. Sorry for the confusion.
It is true that if your DVD player has "better" (which in my case 3910 DOES have better DACs than 3805) DACs than your receiver that using analog ins for 5.1 audio MAY sound better. I prefer the DenonLink for the versatility and I did NOT hear a difference when I got it. I originally had it hooked up both ways (DL and analog) to do A/B comparisons to my ear. I couldn't tell any difference. I like the DL because it is one cord that does EVERYTHING from my 3910 (DVD-A, SACD, CD, DD-EX, DTS-ES, etc). Like I said, others have mentioned here that firewire (DenonLink is a version of this) is capable of lossless audio transmission (TrueHD and DTS-HD), but that would require a player that has firewire AND a receiver that accepts it AND decodes those audio codecs. It would be awesome however because of the ability to apply all the room EQ, PLIIx, etc to even the new audio codecs too! Right now the DenonLink IS as effective as your analog outs for all the old codecs. That's why I use it for the 3910 and use the analog outs from my Tosh player for the NEW audio codecs. Hope that helps explain a little.
__________________
#25 | Link |
That was helpful, thanks. As my Denon 3930CI DACs are better than my AVR3805 DACs, I'll continue using 5.1 analogue. I'll also keep in mind I can use my AVR's 5.1 in's should I decide to buy an HD/BD player. At which point I'll use DL3 for my 3930CI. Cheers!
#28 | Link |
I recently got a good Yamaha HDMI reciever... so now I can access lossless and Truehd.. so if I could change my vote I would!
__________________
#30 | Link | |
Is it a tiny difference or are you now in pure audio bliss? |
| Bookmarks |
| Thread Tools | |
