AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 12-13-06, 02:37 PM   #1   |  Link
dcp
IR sensors, hubs, flashers
Looking to mount an IR sensor on the wall and relay signal to control 3 or 4 components in a cabinet.
Was a bit surprised at the prices top achieve this using systems on Crutchfield.
I could be boneheaded but couldn't find stuff on Partsexpress.com
Anywhere else to look?
Any recommendations on how to do this less expensively?
dcp is offline   Reply With Quote
Old 12-13-06, 02:57 PM   #2   |  Link
ptsenter
I'm using X10 pyramids to relay IR codes - very inexpensive.
ptsenter is offline   Reply With Quote
Old 12-13-06, 03:28 PM   #3   |  Link
dcp
True - inexpensive but appear to be a little large and clunky. Hoping for more discreet wall mount sensor and I do not have a lot of room in cabinet for transmitter.
Not to mention how damn annoying the x10.com website is with all the flashing, moving, scrolling, fake pop up junk on it - almost reason enough to avoid their product IMHO.
Old 12-13-06, 03:32 PM   #4   |  Link
boykster
Its possible to put together a kit yourself, but here's one for about $100
http://www.smarthome.com/8225p.html
boykster is offline   Reply With Quote
Old 12-13-06, 03:35 PM   #5   |  Link
Targus
Can you solder?
Targus is offline   Reply With Quote
Old 12-13-06, 03:43 PM   #6   |  Link
dcp
That kit looks good.
Also believe I've found suitable solution on aforementioned website.
Sensor
http://www.partsexpress.com/pe/showd...number=182-314
Hub
http://www.partsexpress.com/pe/showd...number=182-315
Flasher
http://www.partsexpress.com/pe/showd...number=182-305
Old 12-13-06, 03:55 PM   #7   |  Link
boykster
That will do it,and the price point is pretty much in line with the kit I posted.
don't forget a powersupply too
http://www.partsexpress.com/pe/showd...number=182-317
Old 12-13-06, 04:02 PM   #8   |  Link
dcp
Can you solder?
Yes. What solution did you have in mind?
Old 12-13-06, 04:59 PM   #9   |  Link
Targus
I've posted a tutorial on building your own system before, I'll try to find it.
However, everytime I suggest DIY...I get scolded for it...it seems to anger those who can't DIY.
Old 12-14-06, 01:57 PM   #10   |  Link
DaveHolland
Buffalo Electronics. Here's the cheapest place I've found.
http://www.automatedoutlet.com/home.php?cat=140
DaveHolland is offline   Reply With Quote
Old 12-14-06, 05:04 PM   #11   |  Link
js5752
Personally, I'd love to see what you've got on the DIY front. I'm not the most skilled DIYer, but I do consider myself fairly skilled with a soldering iron.
Hey if it can be more reliable that my RadioShack IR repeaters, then it can't be all bad. I have to power cycle the receiver module daily, or else it stops working. It's a real pain.
-Jeff
js5752 is offline   Reply With Quote
Old 12-19-06, 03:06 PM   #12   |  Link
Nightlites13
Thumbs up
Hey Targus, I would be very interested to see what type of DIY solution you have as well. No one should complain because there are plenty of store bought solutions out there and plenty of suggestions from others for that so if you have time and can find it, thanks.
__________________
"If you choose not to decide, you still have made a choice"
Nightlites13 is offline   Reply With Quote
Old 12-19-06, 03:33 PM   #13   |  Link
tlniec
Add me to the list of folks interested in the DIY.
tlniec is offline   Reply With Quote
Old 12-19-06, 04:53 PM   #14   |  Link
trpltongue
I actually just installed the following from parts express:
8 of these receivers ($15 each): http://www.partsexpress.com/pe/pshow...number=182-834
1 of these connecting blocks and power supply ($39): http://www.partsexpress.com/pe/showd...number=182-315
4 of these dual emitters ($7.85 each): http://www.partsexpress.com/pe/showd...number=183-204
Total for 1 receiver, 1 connecting block, 1 power supply, and 1 dual emiiter is $63.
The receivers only use 3 single wires from the cat5 cable and they work outstanding! My runs are relatively long at ~50' and I have had no problems whatsoever. I was a bit skeptical about the receivers because of their price, but they've worked flawlessly so far.
Russell
trpltongue is offline   Reply With Quote
Old 01-01-07, 09:54 AM   #15   |  Link
DEZI979
New Member
Russell,
I'm curious as to why you purchased 8 receivers...are you controlling equipment from multiple rooms? (newbe question probably...!)
DEZI979 is offline   Reply With Quote
Old 01-04-07, 10:51 PM   #16   |  Link
trpltongue
Yeah,
We've got the equipment centrally located and are controlling it from 8 different rooms throughout the house.
They've worked pretty well so far. I'm having a bit of difficulty with 1 of the satellite boxes working intermitently but I haven't taken the time to troubleshoot it yet. The only downside to the buffalo distribution block is the lack of adjustment on the IR output. There is no gain control so if the IR is overpowering the equipment you have to use some filters to drop the intensity.
Russell
Old 01-16-07, 09:34 PM   #17   |  Link
DEZI979
New Member
Originally Posted by trpltongue
Yeah,
Russell
Gotcha,
I install the Buffalo Electronics receiver, block and 4 emitters last weekend and it works flawlessly. Now on to find a quality universal remote for around $100. Looking at MX-500 and URC-200 along with logitech products.
Any thoughts?
Old 01-16-07, 09:42 PM   #18   |  Link
Speedskater
Originally Posted by DEZI979
Gotcha,
Any thoughts?
How sensitive is the receiver? With my old pyramid, you have to point the remote right at the sensor.
Speedskater is offline   Reply With Quote
Old 01-21-07, 07:59 AM   #19   |  Link
lastplace
Gotcha,
Any thoughts?
Sams has the Logitech 676 on sales in your price range
__________________
I love this HD stuff!
lastplace is offline   Reply With Quote
Old 01-21-07, 09:13 AM   #20   |  Link
aviman33
I got the Hot Link Pro and I'm very pleased with it. One big plus is the size of the receiver. Most of the systems in this price range have a huge receiver, or a very expensive compact add-on. The Hot Link is very sensitive and works well withl my plasma.
http://www.hot-link.com/products.html
Jon
aviman33 is offline   Reply With Quote
Old 01-21-07, 10:24 AM   #21   |  Link
RTBrandy
Jon
I'm about to pull the trigger on this, too.....lookslike it will cover all my needs...
RTBrandy is offline   Reply With Quote
Old 01-21-07, 11:34 AM   #22   |  Link
aviman33
The receiver is super sinsitive and easy to hide. I have mine mounter behind the TV (out of line of site) and it picks up the remotes reflections perfectly. It even has a blue LED for signal feedback . You really can't go wrong with this one.
Jon
Old 01-21-07, 04:13 PM   #23   |  Link
UpSide
I just jumped on this PRO setup for $99. Look like exactly what I have been searching for, thanks for the advice.
-J
UpSide is offline   Reply With Quote
Old 02-06-07, 02:07 PM   #24   |  Link
RTBrandy
I got this, and am using it..
Very happy with it, and easy as pie to set up....my only issue is that I'm having a lot of trouble extending the reader eye. The instructions say use Coaxial cable with RCA connectors...so i bought rg59 RCA subwoofer cable (6 feet) from monoprice....no luck...the blue flasher eye picks up a lot of interference ....
but it workjs great without the extension...
Old 04-17-07, 02:43 AM   #25   |  Link
Marcus111
Hello Randy:
Did you get your RG59 extension cable to work with the Hot Link Pro?
If noisy, check to make certain all connectors and adapters are metal and fully shielded.
At your service,
Marcus, Microsmith Inc.
800-999-8846
Marcus111 is offline   Reply With Quote
Old 04-17-07, 09:06 AM   #26   |  Link
RTBrandy
Originally Posted by Marcus111
Hello Randy:
At your service,
800-999-8846
I actually wound up ordering the actual extension cable, and it works great.....Very pleased with this solution...
thanks Marcus !!
Old 04-18-07, 12:57 PM   #27   |  Link
jspielmann
Human Sponge
Has anyone spliced the emitter cables to lengthen them? I have a long run to a projector and was wondering if anyone has spliced and soldered a longer wire. My run is almost 20 feet.
jspielmann is offline   Reply With Quote
Old 04-18-07, 01:17 PM   #28   |  Link
Marcus111
No Worries:
We have people splice emitter cable and add twin lead all of the time.
Just mind polarity before the cut and do one at a time and check.
All emitters are in series and thus need to be in correct polarity with eachother.
Warranty is not affected either...
Best regards,
Old 04-18-07, 01:18 PM   #29   |  Link
Marcus111
Oh, usee the emitter closest to the outside corner for best noise injection prevention.
You may add up to 100 feet...
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.28642797 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
