#1 | Link |
New Member
Optical Splitter not working??
I just purchased a TOSLINK optical splitter
advertised as two way (split one device to two receivers or two devices to one receiver) I have a PS3 and a XB 360 I want to connect to my receiver with only one optical input. Right now I'm waiting on my 3rd optical cable to show, but I wanted to test the splitter now. I hooked one optical cable from the PS3 to the splitter and then another from the splitter to the receiver. No sound. Tested the wires and all good. I tried every combo on the splitter for the two wires and nothing. Does the splitter need all three holes in use to work correctly? Does the splitter just not work? |
#2 | Link |
Resident Enforcer
First see if the splitter has those little rubber caps on the inside of the hole to prevent dust from going into the device ,another thing is it might not work unless all 3 cables are hooked up.
But I like using an optical selector which is alot better than the splitter. http://www.monoprice.com/products/pr...seq=1&format=2
__________________
De-interlacing explained: http://www.hqv.com/technology/index1...TOKEN=92875981 Rainbow effect? : http://www.dietforum.net/balagee/projected/rainbow.html Lou |
#5 | Link | |
Super Duper Member
__________________
"All men are frauds. The only difference between them is that some admit it. I myself deny it." |
#8 | Link | |
New Member
| Bookmarks |
| Thread Tools | |
