#1 | Link |
Will the HSU MBM work with any sub?
I just took the plunge on the SVS PB-12 NSD and am thrilled. I know it produces some very low bass. I am also concerned with the upper bass frequencies as well and see that HSU has a product that is supposed to cover that area. I was wondering how well it would work together with the SVS. Or is it specifically designed to work with HSU subs? That brings me to my next question. Would I be able to buy a PB-10 NSD and have that crossed over higher to get some more punch in the upper bass region?
__________________
I'm your Huckleberry |
#3 | Link | ||
The PB12 drops off substantially after around 90Hz, so you should see a significant improvement with the addition of a MBM-12. Quote:
#6 | Link | |
listen for yourself
__________________
-curtis Volunteer Mod at the A s c e n d A c o u s t i c s Forum Somewhere between what someone posts and what I think, is the truth. |
#7 | Link |
Also, talking with HSU, they recommended that I place it next to the couch. That is not an option for me. The only place I can put it is on top of my current SVS PB12 NSD. Will it defeat the purpose or will it be okay sitting on top of my other sub?
__________________
#8 | Link | |
From what I've read that wouldn't be a problem. The only downfall is that you loose the punch that you would get from having it near field. HSU recommends that the MBM be placed near field and the true Sub to be far field. These are not set in stone. Dr. Hsu has stated that you can place the MBM between the mains or next to the True Sub. If you have smaller sat's that don't go down below 80hz, then you have a dilemma or rather a choice of placing the MBM near field and risk localization (which depends on your taste, hearing a slight directionality from it doesn't bother me at all). Purists won't want to be able to localize the bass at all. ( reason being you would set the crossover higher than 80hz, most likely 100hz or 120hz to pair well with small sats.) I'm running the MBM with a PC-Ultra and an Orb 5 speaker setup. I'm crossing the MBM at 120hz (the orbs can be crossed at 80hz, but I'm going to give it a try at 120hz for a few days, 100hz and then 80hz. The PC-Ultra in all cases will be handling 50hz on down, set in 16hz tune. The beauty of the MBM is that it frees up some power on the Ultra since it will only be receiving the very Low LFE. Seems like it has even more punch now even though it had plenty of to spare even before introducing the MBM-12. I have placed the MBM 12 behind the back left side ( if your back is facing the couch). It's a few feet from a corner in the room, my couch is a half circle shape. The MBM port is facing away from the couch and towards the corner wall. So far, I'm very impressed with the MBM and PC-Ultra combo. I haven't truly calibrated it yet with an SPL meter but I will in a week or so. Just had to play with the gain on the MBM a bit, it's very sensitive and it does play the Mid-range loud if turned up to far. I only have it set just under 10 O'clock and it sounds great with a nice little rumble through the couch. Crossed at 120hz, it is slightly locatable to my ears, but not enough to really bother me at all. I will play with it some more and try lower crossovers and report back my opinions. |
#9 | Link |
listen for yourself
You should try and cross the Orbs even higher....they begin to roll off before 150hz. If you cross at 80hz, you will be missing a lot of information...localized or not.
__________________
#11 | Link | |
When I first got the MBM-12 in my system with the 3HO Turbo, the mid-bass (MBM-12) was very localizable and sounded like crap. My first thought was, "this thing is going back to HSU"! It took me a couple hours of tweaking on the gain of each sub, processor and sub crossovers, and using the Velo SMS-1, to get the MBM-12 to blend with my 3HO sub/mains and listening room. My mains start rolling off around 60hz (the NHT M6s), but I've found crossing them over to the MBM-12 at around 85-110hz works best for my system. The MBM-12 has completely disappeared and I have it located right next to my main listening position. Once you get the MBM-12 dialed in, the rewards are huge! Mid-bass detail and slam have never sounded this good in my system! dc
__________________
Live Long & Prosper |
#13 | Link | |
A SPL meter and a bit of tweaking should give similar results. dc
__________________
#14 | Link | |||
American Gladiator
I contend that the better option is to get a second sub. |
#15 | Link | |
#16 | Link |
American Gladiator
But then I ask again, just as I did before, what is the point of greater dynamics and decreased distortion in a small bass range? Were you to buy a second identical subwoofer, you'd gain better dynamics and decreased distortion over the whole sub range - you'd also have a much easier time integrating it than you would a superwoofer. A logical goal would be to have a system that roughly maintains a given level of capability over all frequencies, not just bits and pieces.
#17 | Link | |
listen for yourself
Like you said, all speculation until experienced in practice.
__________________
#18 | Link |
My take is that it's like adding shakers. You put it near field (if possible) and the mid-bass gives you that kick while letting the main sub do the deeper stuff. Some of the larger subs already are for this purpose, and there are already people who let their big, big subs handle say below 30~40Hz down to 10~25Hz or so, with other subs handling the more audible bass.
#19 | Link | |
American Gladiator
#22 | Link | |
#24 | Link |
Human
In Colin Miller and Brian Florians' excellent article Miscellaneous Ramblings on Subwoofer Crossover Frequencies:
http://www.hometheaterhifi.com/volum...rs-9-2002.html They mention 120Hz brickwalled as the top end of frequencies mixed to the LFE out. Does anyone know the actual upper limit of LFE channel mix in commercial recordings? Last edited by ggunnell; 12-18-06 at 08:10 PM.. |
#26 | Link |
I wonder how two of these set under my bookshelf mains as bass bins would sound?
__________________
Rockem's Home Theater |
#27 | Link | |
Well, I decided to bust out the SPL meter to see just how far down the orbs go. They don't really drop off until about 90hz, at least significantly. But the problem is I have a MOD 2 center and that has a higher drop around 120hz and then goes back to normal and begins to drop off at around 90hz. Weird, i expected it to peform better in the lower mid bass region, but it could be room acoustics. Remember that the room is having an effect on the roll off of these orbs. I don't think I will cross the MBM any lower than 120hz because of the inconsistency of my Center Orb. I still have it place nearfield behind the couch. I think steve has a point to a degree, This MBM is great for someone in my position with orbs. I might try it in the front of the room under my Plasma TV. The orbs are above the TV. So it would be center under the center channel. And about 6 feet to the right of the PC-Ultra. I will see how this sounds. Although I do enjoy the Punch I get from behind the couch. But like I said before, I have to keep the gain low, around 9am or it's too localizable. I do like to run a nice house curve with my low end boosted. I usually listen at around -20 on my HK, this is about 66dbs. So I often run the Ultra hot, at around 76-80 dbs. |
#28 | Link |
The argument that the MBM only serves a purpose with bookshelf speakers is a fallacy in my opinion. The reality is that there are few loudspeakers that have the mid-bass headroom to match the MBM-12, let alone anything near $400. And even then, these loudspeakers don't get the benefit of being placed nearfield for reduced interaction with room.
The term "good enough" can mean almost anything. Some people may find it good enough to have about 105db at the listening position without output compression in the 50-100Hz region. The MBM-12 will give >120db at the listening position with virtually no output compression in this same range of frequencies. That is a huge difference no matter which way you look at it. Even a difference of 6-10db would be huge. Is that a limited range of frequencies? I don't think so. Looking at various waterfall charts that are floating around the internet, it seems that almost every movie has lots of activity and some very large dynamic peaks in the 50-80Hz mid-bass region. Also, obviously music is rich with information in this range of frequencies, while much less rich in content below about 25Hz. A setup with dual VTF-3 HO + turbochargers would stand to seriously gain from a single MBM-12, which sells for a fraction of the cost of a single one of these subwoofers. A system with single VTF-3 HO + MBM-12 can do things that no quantity of VTF-3 HO's or other true subwoofers placed farfield in a corner handling the low/mid/upper bass can do, namely having a very high ratio of direct-to-reflected sound energy in the mid bass region for reduced room effects, in addition to having vanishing levels of intermodulation distortion between low and mid bass since the mid bass frequencies can no longer be modulated by the lower bass frequencies. There's no doubt that adding a second true subwoofer will generally make a very large and noticeable improvement in performance, but it is certainly no substitute for the MBM. Last edited by Peter Marcks; 12-18-06 at 10:56 PM.. |
#29 | Link | |
Would you say that the MBM-12 has [directly or indirectly] improved the sound quality of your system at all bass frequencies? Thanks again |
#30 | Link | |
May I ask what other subwoofers you have tried in your home? I am definitely humbled by the glowing remarks. Sincerely, |
| Bookmarks |
| Thread Tools | |
