#1 | Link |
Harmony remote questions?
1: Can the Harmony remotes be programed as a "learning remote" or is the only way to program them is via computer/Internet?
2: Are the on-screen labels user customizable? 3: How long is the battery life if not in the charger? 4: Which model is the best bang for the buck? Thanks for any help here. ![]() |
#4 | Link |
I agree with previous answers to your other questions.
The 550 is the one I chose for both best bang for the buck (The HK-TC30 is basically a slightly more expensive 550), and frankly, I think it is less obnoxious then the other high end remotes. Do you really need a colour LCD display and recharchablde battery in your remote? I'd rather get an Ipod for those prices. The programming was initally frustrating simply because I didn't like the wizard, but I later found a work around. And yes, EVERYTHING is customizable - I am happy with it and have it doing everything I hoped it would. The unit takes 4 AAA bateries, and you could get aftermarket rechargeables. I have read reviews that state it will last a week with the back light left on constantly - so that probably translates to 6 months of normal use... |
#6 | Link |
Thanks for all the help. How about the Harmony 520? I can get that at Target on-sale for $80. http://www.target.com/gp/detail.html...sin=B000BDG3HU
#7 | Link | |
Big Member
Clay |
#10 | Link | |
You can get the 550 from Amazon for $85.39 out-the door (free standard shippiing). Ships from Amazon and not third party reseller. |
#11 | Link |
I found many of the Harmony products functionally similar except for the keypad layout. You might want to look closely at the different keypads to see which is the most convenient for you. I wanted the guide and DVR transport functions in the center of the remote along with volume and channel up/dn. The numbers at the bottom and soft keys (LCD) at the top were less important to me. A "good deal" maybe ain't so great if your hand gets cramped trying to reach your most often used keys.
#12 | Link |
^ I completely agree. I got the 550 on a whim from Dell since it was on sale for $74, but I don't like how the transport buttons are laid out. I prefer the style of the 550, but I've decided the 670 layout is better since we always use our Tivo and I'm used to the Tivo remote and MX-500 (our previous universal). For me that's worth an extra few bucks.
__________________
I am a consumer whore! |
#13 | Link | |
Available in Hi-def!
__________________
- jrod /"don't mess with a man with a way-back machine, Dave." |
#14 | Link |
I'm not very familliar with Harmony remotes, and I have a pretty simple (but long winded) question:
The surround settings on my HK A525 reciever require you to toggle through 3 settings on DPLII (movie, music, emulate) by pressing the same buttom. Can I program a "Listen to music" button that will switch it directly to the "music" setting. Then, if I press the TV button, will it go back to the "movie" mode? Since the reciever requires one button to toggle, it seems like it would be difficult for the Harmony to go directly to the other setting. If I set up a macro that would "press" the button twice (in order to toggle twice) it would probably wouldn't know what mode I'm in and might put me in the wrong mode. So, if I was in "music" DPLII mode, and I hit the "listen to music music" button on my Harmony by accident, I wouldn't want it to toggle to "Movie" DPLII mode, I'd want it to reckognize that I was already in "music" mode and do nothing. Is this possible? Thanks, Travis |
#15 | Link | |
The Harmony remotes also have a delay feature. Most A/V equipment needs time between switching on or between commands before it will accept additional commands. You can add or change the delay time. Last edited by Digitude; 01-04-07 at 10:57 AM.. |
#16 | Link | |
For example, I have a Marantz SR7400 and want the receiver to be in DPLIIx: Game mode when playing the PS2. I basically have the remote programmed to send the "Auto" command first and then the DPLIIx command three times. This way, it always goes to the correct DPLIIx mode since "Auto" defaults the receiver to the original state. |
#17 | Link |
Wow, thanks for the fast replies and great info, guys. I forgot about my TV inputs. My example would have been more simpler if I just mentioned the TV inputs because I'm sure that the TV input situation is one that everybody has had to deal with.
Do you guys know where I could find out if my TV or reciever has the "Auto" command that you speak of? Would it be in the manuals or would logitec know? Also, does the current command sequence go out of order if the signal gets blocked by a chair or something and the reciever/TV was unable to recieve the signal? If so, how often does this happen (how good is the remote transmitter signal strength?)? Thanks |
#18 | Link | |
#19 | Link | |
And you always can put that button into activity's screen. In case you use the same device, e.g., DVD changer, to listen and to watch I would simply split audio cables to use different inputs on the receiver. |
#20 | Link | |
I should also note that if your device has discrete commands, pressing the Activity button will work better than the Help. If your device toggles and doesn't have a "base" to toggle from, Help would be better. |
#22 | Link | |
New Member
#23 | Link | |
#24 | Link | |
New Member
#25 | Link |
If your Harmony has the "Picture" and "Sound" buttons the answer may be there. I have my "Sound" button programmed such that I can choose the best DSP (that's what my Yamaha calls the Hall, Rock, TV/Sports. e.g.) for whatever I'm watching.
For example, if I'm watching ESPNHD and UVa is kicking the crap out of Gonzaga, I'll choose "TV/Sports". But when the score gets ridiculous, like 102 to 74, I might go to some concert on Rave and switch the DSP to "Rock" or "Hall". No new Activity to set up, no changing Devices, just press "Sound" and choose what suits you best.
__________________
Joel |
#26 | Link | |
| Bookmarks |
| Thread Tools | |
