AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 12-18-06, 03:43 AM   #1   |  Link
gts007
Comcast remote not seeing H/K receiver
Anyone else with Comcast and their 3-device remote having no results with the H/K codes 0110 and 0189 in auxillary mode?
gts007 is offline   Reply With Quote
Old 06-14-07, 03:18 PM   #2   |  Link
Marti
New Member
comcast and H/K
I am having the same problem and have not found a code that will work. I have contacted Comcast and Harman Kardon and neither one of them have been able to help me out. Does anyone have a solution to this issue?
Marti is offline   Reply With Quote
Old 06-14-07, 09:48 PM   #3   |  Link
Kupakai
What is the model number of your receiver? Also, what is the model number of your remote (it should be inside the battery compartment, starting with "URC-....". Generally, setup code AUX/0110 should give you basic functions like volume and input selection (they are the number keys). Do any of those functions work? Power on might work, but possibly not for power off, but there's a way to program that.
If you want functions beyond that, you would need to get a JP1.2 cable to add an upgrade for the HK receiver.
Kupakai is offline   Reply With Quote
Old 05-27-09, 10:58 AM   #4   |  Link
wilson4intx
New Member
Can you tell me how to program so the power goes off? It goes on okay, but not off. Thanks!
wilson4intx is offline   Reply With Quote
Old 05-28-09, 09:18 PM   #5   |  Link
Kupakai
Assuming you are using AUX/0110 or AUX/30110, depending on which remote you have, do the following to add power off to shift-POWER:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 994
4. Press and release SETUP
5. Type 00002
6. Press and release SETUP
7. Press and release POWER key
The remote should blink twice to confirm. Now, if you press and release SETUP and the press POWER, it should turn off the receiver. If you would rather program it in a non-shifted button, do the steps above except skip step 6 and press the key you want to program power off function to in step 7
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11840105 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
