AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Home Theater Computers
Forum Jump
Old 12-22-06, 09:34 AM   #1   |  Link
Gary McCoy
PowerDVD Ultra (HD-DVD and Blu-Ray)
......is downloadable as of this morning:
http://www.cyberlink.com/multi/produ...n_112_ENU.html
Reportedly supports both HD-DVD and Blu-Ray playback in the PC.
Awaiting user reports.
Gary
Gary McCoy is offline   Reply With Quote
Old 12-22-06, 09:36 AM   #2   |  Link
Dwight2001
Gary
Praise the Baby Jesus!!
Dwight2001 is offline   Reply With Quote
Old 12-22-06, 10:38 AM   #3   |  Link
dtwilly57
New Member
Audio
"High-definition audio technologies - Pure high-definition audio with Dolby Digital Plus, TrueHD, DTS-HD"
Can a pc with a Blu Ray or HDVD drive decode the next gen audio formats and output them in multi channel linear pcm like the current crop of standalone HD DVD/Blu Ray players?
Which sound cards support this? X Meridian, X-Fi etc, Intel HD audio?
dtwilly57 is offline   Reply With Quote
Old 12-22-06, 11:10 AM   #4   |  Link
stanger89
Living the PVR Life
AVS CLUB MEMBER
I don't see why not.
It shouldn't matter.
__________________
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen
stanger89 is offline   Reply With Quote
Old 12-22-06, 11:26 AM   #5   |  Link
wayner9
New Member
Sorry if this is a dumb question but do you need an HDCP compliant video card to use this software at 720p, 1080i or 1080p?
wayner9 is offline   Reply With Quote
Old 12-22-06, 11:42 AM   #6   |  Link
Tinker
Money Challenged
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
Yes for commercial HD disks that have AACS copy protection (most HD-DVD and BR).
__________________
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline   Reply With Quote
Old 12-22-06, 11:43 AM   #7   |  Link
MidnightWatcher
Of The 7th Dimension
Classified Rating: 100% (4)
It doesn't indicate specifically that you need an HDCP compliant video card, but it does mention an HDCP compliant display. I would presume though that the video card would also require HDCP compliance.
__________________
"Without struggle there can be no progress."
MidnightWatcher is offline   Reply With Quote
Old 12-22-06, 11:51 AM   #8   |  Link
stanger89
Living the PVR Life
AVS CLUB MEMBER
If you're using DVI/HDMI you will. If you're using VGA or component, you shouldn't but it's been reported WinDVD requires and HDCP card even if you're not using DVI/HDMI.
__________________
Old 12-22-06, 11:51 AM   #9   |  Link
wayner9
New Member
Would an HDTV with an HDMI input be HDCP compliant?
Old 12-22-06, 11:53 AM   #10   |  Link
ShagMan
AVS CLUB MEMBER
Classified Rating: 100% (7)
Almost always, yes.
ShagMan is offline   Reply With Quote
Old 12-22-06, 11:59 AM   #11   |  Link
sotti
Unfortunetly there is no output for linear multichannel PCM on the PC. You can do analog output though.
sotti is online now   Reply With Quote
Old 12-22-06, 12:17 PM   #12   |  Link
umdivx
MN Maven
If you are hooking up to a digital display with a digital connection (IE HDMI or DVI) but if you can use VGA or component then no. But you do need a pretty powerfull video card, basically a 7600GT PCIexpress or higher.
- Josh
umdivx is offline   Reply With Quote
Old 12-22-06, 12:33 PM   #13   |  Link
karos
They say it requires 7800gtx 512 mb? What the 'regular' 256 mb card wont work?
karos is offline   Reply With Quote
Old 12-22-06, 01:11 PM   #14   |  Link
MidnightWatcher
I'm sure that would be fine considering that a 7600GT 256MB is sufficient.
__________________
Old 12-22-06, 01:22 PM   #15   |  Link
wayner9
New Member
If your card can play the WMV-HD stuff at 1080p then you hsould be fine, shouldn't you? (Barring any HDCP issues). I have a 7600GS and have no trouble playing any HD content.
Old 12-22-06, 01:36 PM   #16   |  Link
umdivx
MN Maven
From what i've gathered in terms of video cards and what will and won't work.
- First off you need (for Nvidia side mind you) a PCI Express based video card with atleast 256megs of ram.
- 7600GT is the lowest end you can go for the nvidia side.
- HDCP supported video card is NOT needed if you are using VGA or component dongle out from your video card.
- HDCP supported video card IS NEEDED if you are using DVI or HDMI into your tv. also a little side note is that if you are using DVI or HDMI your display device needs to support HDCP as well
thats pretty much it in terms of video card support, now when you get into hardware like mobo, anything dual channel memory, such as Socket 939 or AM2 on the AMD side ( socket 754 won't work) then of course any of the core duo's or core 2 duo's will work on the intel side. I personally have mannaged to get a socket 478 Intel Prescott P4 3.2ghz OC'd to 3.8ghz to playback HD DVD smoothly. 512megs of ram is the min. 1gig the preferred.
Other than that if you want more info on what Nvidia says about the matter (system recommendations) check it out here: http://www.nzone.com/object/nzone_pvhd_build.html
here is also an Nvidia HD DVD and Blu-ray DVD hardware check list: http://download.nvidia.com/downloads...ing_a_HDPC.pdf
enjoy,
- Josh
Old 12-22-06, 01:36 PM   #17   |  Link
stanger89
Living the PVR Life
AVS CLUB MEMBER
Not necessarilly, WMV-HD stuff was make quite a long time ago (in HD terms) using a different/older codec than is used on HD DVD. WMV-HDs are generally using "normal" WMV9, where as HD DVD/Blu-ray use VC-1 which is WMV9 Advanced Profile, and has only been available on the PC for a couple months.
Further, WMV-HD stuff was encode primarilly for lower bitrates and easier decoding, where as VC-1 and especially H.264 on HD DVD/Blu-ray are quality focused, decoding requirements and bitrate are secondary. WMV-HD stuff (as well as most of the H.264 Quicktime stuff on the web) is usually under 10Mbps for 1080p clips, contrast that with VC-1 and H.264 which are often in the 15-20Mbps range, using more advanced (read more demanding) features.
That's going to be the big one, WMV-HD doesn't require HDCP.
Hopefully that should be OK (being a 7 series). But just a word of warning. I've got a 6600GT and have no trouble playing any HD that can be found on broadcast or on the net. Yet it's not capable of playing HD DVD (VC-1) currently.
__________________
Old 12-22-06, 01:39 PM   #18   |  Link
dennlv
New Member
Cool!
Anyone have xbox 360 hddvd on their htpc and using this already? seems like u cant download to try it out first.
wat about Dolby Digital Plus, Dolby TrueHD and DTS-HD? toslink out to xr55 can get these stuffs out from the speakers?
Gary
dennlv is offline   Reply With Quote
Old 12-22-06, 01:44 PM   #19   |  Link
sotti
Originally Posted by dennlv
Cool!
No you cannot, currently the only way to get these advanced codecs off a PC is analog out.
Old 12-22-06, 01:45 PM   #20   |  Link
umdivx
MN Maven
Originally Posted by stanger89
......Yet it's not capable of playing HD DVD (VC-1) currently.
You do realize that WMV-HD is infact VC-1 right? its not the problem of the codec but the bit rate.
Its the bit rate that is what is holding the older cards back from playing back smoothly, they aren't powerful enough.
WMV-HD uses a lower bit rate so that they can fit a whole movie onto a dual lay DVD. But because HD DVD's and Blu-ray DVD's are larger they are now able to run higher bit rates drastically improving the video quality, hence the HD.
This bit rate is really what is holding back a 6600GT or AGP based cards from playing back the video smoothly.
- Josh
Old 12-22-06, 01:58 PM   #21   |  Link
capitano
Angry
I bought it.
In my HTPC I have 1 BD drive and the X-box add-on.
After installed Powerdvd Ultra the program shows itself as BD version 7.2.
Only Blu-ray....
They stated Ultra plays BOTH BD and HD-DVD...
capitano is offline   Reply With Quote
Old 12-22-06, 02:09 PM   #22   |  Link
stanger89
Living the PVR Life
AVS CLUB MEMBER
OK, let me rephrase that. Most WMV-HD (that released before WMP11 and the new "VC-1" WMV decoder) is WMV9 Simple Profile, or WMV9 Main Profile. These are what we've known as WMV9 since WMV9 first appeared. This is what most WMV-HD (maybe all) are.
What's new, what HD DVD and Blu-ray use, and what is generally meant when the term VC-1 is used, is WMV9 Advanced Profile.
Advanced Profile is much more computationally demanding and may not be (perhaps isn't) supported by all cards that support accellerating WMV SP/MP.
I'd say it's the profile that's doing it. VC-1 Main Profile supports up to 1080p30 @ 20Mbps, much higher than what's normally used for WMV-HD clips.
__________________
Old 12-22-06, 02:27 PM   #23   |  Link
BobSalita
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
Anyone have any luck on notebook computers? Which mobile graphics chips can playback HD-DVD (via USB XBox HD-DVD drive)?
__________________
My notebooks are disk crash free and super fast. Got SSD?
BobSalita is online now   Reply With Quote
Old 12-22-06, 02:38 PM   #24   |  Link
umdivx
MN Maven
you basically are arguing about the same thing I just said. go here: http://en.wikipedia.org/wiki/VC-1#Bi...26_resolutions
it shows the bit rates between VC-1 simple profile, main profile and advanced profile. The all are still based off of the same codec structure but advanced profile (which is what is being used with HD DVD and BD DVD) is using higher bit rates, which is what I said. and that higher bit rate is the reason AGP based cards and lower end PCI express cards like a 6600GT PCIe card can't perform the duties of the higher end newer cards, ie 7600GT and higher.
WMV-HD uses VC-1 Main Profile @ high level which is around 20Mbits/s
right now HD DVD/BD DVD uses VC-1 Advanced profile @ Level 3 which is around 45 Mbits/s
which is 2.25 times higher bit rate. you do the math on that.
Like I said before the real main difference is the Bit rates, granted there still is a compression difference between each profile but the main difference that I see is the bit rates.
Also the Main profile is what WMVHD uses, so not sure what you meant by the more demanding part. I've got several WMVHD movies that are 1080p/30 20Mbit/s so and I know my AGP 6600GT handles them just fine.
But on the other hand it can't handle the 1080p/24 at 45 MBits/s.
- Josh
Old 12-22-06, 02:48 PM   #25   |  Link
ShagMan
AVS CLUB MEMBER
Originally Posted by capitano
I bought it.
Only Blu-ray....
So you can't playback HD-DVD at all?
I'm expecing this software to play Blu-Ray, HD-DVD *AND* all my satellite backups PERFECTLY, for $100.
Old 12-22-06, 02:52 PM   #26   |  Link
Sherbona
I wonder if Cyberlink is going to offer an upgrade path/price for current PowerDVD7 Deluxe owners? So far I see upgrades to get to the Deluxe version, but no way to get to Ultra version short of purchasing at full price. Or maybe I'm missing something?
Sherbona is offline   Reply With Quote
Old 12-22-06, 03:05 PM   #27   |  Link
stanger89
Living the PVR Life
AVS CLUB MEMBER
To a degree, or strait from the horse's mouth:
http://www.microsoft.com/windows/win...les_and_Levels
The same could be said of MPEG-4, you could say the AVC is the same codec as ASP, but the bit rates are different.
However that wouldn't come close to telling the whole story. Same is true of VC-1 SP/MP vs AP.
AP is more than just support for higher bitrates, a lot more. Just look at the discussions about VC1 AP when MS finally publicly released the AP codec. You can get the same quality at significantly lower bitrates with VC-1 AP, than with SP or MP.
While the VC-1 spec may encompass all three levels, there's a lot more than bitrate that distinguishes them.
But most WMV-HD is <= 10Mbps.
And most HD DVDs are well under 20Mbps.
More like a 50% maximum (probably less) real difference in bitrate. Besides insiders have reported recent VC-1 titles have been in the 12Mbps range.
The real difference is not the bitrates, it's the profile. Just like MPEG-4 AVC is much different than MPEG-4 ASP, VC-1 AP is much different than VC-1 MP.
VC-1 AP is much more computationally intensive (and also more efficient and higher quality) than VC-1 MP.
And yet an PCIe 6600GT can't accellerate <20Mbps VC-1 AP.
Where are you getting 45Mbps VC-1 AP clips? HD DVD is nominally <20 if not <15Mbps. Just because the profile allows 45Mbps does not mean it's utilized.
__________________
Old 12-22-06, 03:10 PM   #28   |  Link
Smonkey
I bought it.
Only Blu-ray....
Did you uninstall any old version of powerdvd before installing the new one?
You might have to install it twice, once with the hddvd drive only hooked up and once with the BD drive.
Smonkey is offline   Reply With Quote
Old 12-22-06, 03:13 PM   #29   |  Link
stanger89
Living the PVR Life
AVS CLUB MEMBER
Can anybody confirm if PDVD Ultra will do vertical stretch of an HD DVD?
__________________
Old 12-22-06, 03:21 PM   #30   |  Link
umdivx
MN Maven
There are a couple test patter/ test videos out there that some folks have put together, my system (AMD 64 X2 4400+, 2gigs of ram, 7900GT PCIexpress) chugs on those.
- Josh
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.38450503 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
