#1 | Link |
Maximum cable length to projector?
Hi all. I am probably going to purchase a Mitsu HD1000 and mount it to my ceiling in my living room. I will be able to run the wires through the ceiling, but it may require a lot of distance (possibly 50 to 75ft) to my xbox360. I was going to use VGA as the cabling for best image quality. Will the cable length cause any picture degradation and should I be concerned? Thanks in advance!
#4 | Link |
Go with HDMI for the best picture. Run fiber optic and you can go VERY far!
http://www2.dvigear.com/hdfiopca.html |
#11 | Link |
Do you think there's any chance of noticeable degrading with 35 feet of 22 awg HDMI cable from monoprice?
I'll redo the measurements, but I think 25 feet would be cutting it close. Is my best bet to go into a local retailer and have them cut a 30 foot cable? I'd rather not have to spend a fortune in cables if I can avoid it- the $50 35 foot 22 awg from monoprice is definitely my choice if it works. if not, I'll see if I can make it with 25 feet. |
#12 | Link |
Front Projection
Let me see if I can help here
I have looked into this as I own an Xbox 360 and looking to purchase the HD1000U as well...
It is my understanding that the original poster was asking about running a VGA cable 50 feet for an Xbox 360. I can understand why you would want to run VGA as it will allow you to up convert SD DVDs to match the 720P of the Mits. But VGA degrades pretty fast over a cable that length and as others had said ghosting from interference is a real good possibility to a probability. I believe bluejeanscable has VGA break out cables which allow for the signal to be split between different cables for the majority of the run. This help prevent image degradation from interference. As for me, I am running VGA, Component, and HDMI to my projector this allows me tons of connection options. Also if your are planning on pulling wires might as well run everything you need(or might need). Of course you can fix this whole mess by purchasing an up-converting to HDMI receiver for xxxx amount of dollars and run just the HDMI! ![]() Last edited by bd_showtime; 12-24-06 at 06:06 AM.. Reason: grammar |
#13 | Link | |
Luftmensch
AVS CLUB MEMBER
BTW, with digital signals, it will either work or it won't. There isn't much in between although one might see "sparkles" if it is marginal! Here are Monoprice's specs for the length versus wire gauge: Maximum Data Length Based on Gauge of Wire:0 to 50 Meters Over HDMI-Cable, 24 AWG STP
__________________
“The greatest obstacle to discovery is not ignorance — it is the illusion of knowledge.” - Daniel Boorstin “Our lives begin to end the day we become silent about things that matter.” - MLK |
#14 | Link |
Once again, I appreciate everyone's help. Tiger Direct offers CablesToGo products and had a section devoted to explaining the differences between the cables. Here is a quote on their description of Component:
Component Video The Component Video interface is the most common extended definition video interface in use on contemporary consumer products. Component connections send one luminance (brightness) and two phase-opposite chrominance (color) signals on three 75-Ohm coaxial cables with a color code of Red, Green, and Blue (RGB). This analog interface is compatible with 1080i and 720p HDTV signals. Component Video is not subject to the same length limitations as digital HDMI and DVI are and can be extended easily to 150ft. What is important is that it states that component does not have the same length limitations as DVI or HDMI. I think there is some confusion surrounding the vga, component, and DVI/HDMI outputs with regards to the length of cables to be run. I also found a link to a sight that seems to feel that vga is indeed superior to component, but the site will not allow me to type a site until I have at least 5 posts. (As soon as I get my 5th, I will post the site that reviews all of the cable types). What I do know is that I can not seem to find any definitive answer with regard to the length limitations for vga. Perhaps I will buy both cables and do a write up. |
#15 | Link | |
HDMI Cable discussion
Somebody else posted the link to this article a few weeks ago on the topic of HDMI cables. I haven't personally tested any of these cables yet. But the article was certainly educational.
When I finally decide on a projector, my cable length will be 40'. I was originally planning to get the ProjectorPeople cable which incorporates component and HDMI in a single jacket. But it is only available in 35' and 50' lengths. So I'll probably go for separate cables instead. Anyway, here's the article... http://www.hometheaterhifi.com/other...benchmark.html -- Peter |
#16 | Link | |
#17 | Link |
Woohoo, 5th post. Here is that link: Cable article
#18 | Link |
Although it is technically not recommended, I have run 100' lengths of VGA cable with no issues. But it has to be a GOOD QUALITY cable.
On the other hand, I recently got a new LCD monitor for my office, and it came with really crappy 6' VGA cables, and I am having issues with it. (I hope it's just the cable, and not the monitor.) -- Peter |
#19 | Link | |
#20 | Link | |
#22 | Link | |
GOT TORQUE!?!?!?!
I have a 50ft HDMI cable running from a closet through the attic to a plasma with no problems of picture quality..
__________________
NO REPLACEMENT FOR DISPLACEMENT 2006 GTO LS2GTO.COM I usually P.W.I. = Post While Intoxicated and Play While Intoxicated |
#25 | Link |
I ran the following Monoprice cables in the ceiling of my house before they drywall.
- HDMI Tin-Plated Copper CL2 Rated (for In-Wall Installation) Cable (24AWG) - 35ft (Gold Plated) - 50 Ft 3-RCA Component Video Cable (RG-59/u) - 50 Ft S-Video & 50FT RCA Audio Cable - MOLDED - 50 Ft SVGA Super VGA M/M Monitor Cable w/ ferrites I will use one of the RCA's on the S-Video molded run to connect composite. I know the quality of S-Video and Composite are quite low, but I wanted to run EVERYTHING I would ever connect to the PJ now while the ceiling was open. I will be sure to post my results of everything once the house is done and we move in. |
| Bookmarks |
| Thread Tools | |
