#5 | Link | |
There is really no such thing as a "small" or "large" room size. The design and properties of the room can have far more effect on the sound quality than the specific number of cubic feet. A room with 8' ceilings with wood floors and plaster walls has very different properties than another room with carpeting, drywall, and an 18' vaulted ceiling.
That said, at least as far as subwoofers go, you're generally looking at larger subs, or multiple smaller subs, once you exceed 3000 cubic feet. However, again, that is a generalization -- for some rooms with 3500 cubic feet, a single 12" subwoofer may be adequate, while for others, two 10" or two 12" subs may be highly desirable. |
#7 | Link | |
__________________
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd. -Bertrand Russell |
#8 | Link | ||
The manual says on page 11 Quote:
#9 | Link | |
I would consult your Pioneer's manual further to see if it specifies distances for those settings. This is a Pioneer-specific thing, not an industry standard. |
#10 | Link | |
#11 | Link | |
Does your receiver have another setting for "large" and "small"? If not, the setting in question is probably that above. |
#13 | Link |
I have a Yamaha receiver that has a similar room size setting under the Basic settings, which is just used for a quick set-up. It automatically sets speaker sizes, distances, etc. Under the Advanced setup menu are the actual settings for speaker sizes, distances, etc. If you make changes in the Advanced settings it ignores anything set in the Basic setup. I'm guessing your receiver is similar and once you adjust any of the speaker settings the room size gets ignored.
#14 | Link | |
#15 | Link | |
Bass Addict
With subs I have always considered these for room size:
<2500 cubic ft = Small 2500-3500 cubic feet = Medium >3500 cubic feet = Large
__________________
-Chris B. DIY Quad 18" Sealed and IB Build DIY Home Theater Build DIY 7 Speaker Build |
#16 | Link |
I finally got around to reading the on line version of your owner's manual. Pioneer requires one to register first.
The reference to room size is the easy setup is a sort of categorical way of referring to the distance from the speakers to the listening position. The advanced setup should override that. I would suggest sticking with the advanced setup and a tape measure. Room volume is is important in selecting a subwoofer, and the ranges given by Mr. Cracky seem about right.
__________________
| Bookmarks |
| Thread Tools | |
