AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 12-23-06, 06:13 PM   #1   |  Link
keldarironfist
a good component cable selector
i have multiple consoles,and likely will have an added dvd player and i have an hdtv that has only two component inputs. i dont wanna spend too much al monster etc...but i don want some RCA peice of junk either. thanks
keldarironfist is offline   Reply With Quote
Old 12-23-06, 06:48 PM   #2   |  Link
bakpakva
bakpakva's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (1)
RAM Electronics or Monoprice. Both have some nice ones at very resonable prices. They are both AVS sponsors as well. I bought a 3x1 component switcher from RAM and it worked great. (Although I don't use it anymore). http://www.ramelectronics.net/html/40-814.html
bakpakva is offline   Reply With Quote
Old 12-31-06, 11:12 AM   #3   |  Link
dtschoerner
New Member
I purchased a "4:2 Atlona Component Video Switch Selector" a few months ago and have been very pleased with it. Connected to the inputs are an Xbox, PS2, 400 DVD Changer and soon to be Wii. One output goes to my AV Receiver and the other to a DVD Recorder. I choose this for the IR control capabilities which works perfectly with my HouseBot automation setup. Got it for around a hundred bucks on ebay.
dtschoerner is offline   Reply With Quote
Old 12-31-06, 11:34 PM   #4   |  Link
sdspga
Judge Smails' Twin
Blue Jeans Cables
__________________
"There's a lot of badness in the world, Danny"
sdspga is offline   Reply With Quote
Old 01-06-07, 06:49 PM   #5   |  Link
VanMark
HT Enthusiast
I have also been looking for a component video switch and found several recommendtations for the Impact Acoustics 3-Play High Performance Component Video/Digital Audio Selector. It seemed to be exactly what I'm looking for and can be found on the web for about 50 - 60 bucks. Keep in mind though, it doesn't do digital coax for audio, you have to use Toslink or L/R RCA. I haven't used optical for my audio before, so we'll see how that turns out...
Mark
__________________
My Theatre
VanMark is offline   Reply With Quote
Old 01-07-07, 06:00 PM   #6   |  Link
goobenet
if all your runs are short (less than 6ft) a plain old AV switchblock works fine. $10 at ratshack. That's what i use, can't tell a difference. I've got a 5 item block that i use purely for component video items.
goobenet is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12634397 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
