#3601 | Link | |
New Member
Well, it appears the update will include support for h.264. THANK THE HEAVENS! The page listing the features says up to 15mbps...is this the average bitrate?
http://www.xbox.com/en-US/community/...07/0408-im.htm |
#3602 | Link |
New Member
VGA 'tearing' fix in spring update
Amir,
You may not be aware of this as its a PAL issue but I can tell you there are literally thousands of PAL 360 users that have had issues with 'tearing' over VGA ever since the fall update.. Horizontal break up of frames is the best way to discribe it when panning horizontally and made games unplayable (literally), particularly Dead Rising. This issue is something MS introduced as there was no problem with tearing over VGA before the fall update. This did not affect NTSC systems for some reason which is why it hasnt received as much publicity. The subsequent 1080p 'fix' reduced the issue to making games more barable but still having the problem. Can you confirm whether these issues have been addressed in the spring update as part of the larger VGA fixes? Thanks |
#3603 | Link | |
High Def Lacrosse
The above is including titles that Sony and Disney have announced to be released on BD50s. If 80% of all titles are on BD25, how could that not be considered the norm? And at what point will this be reveresed that 80% will actually be on BD50 discs?
__________________
Link: My HT Room |
#3605 | Link |
Amir
Does the added support for MPEG-4 and some AVI apply when streaming to the 360 from Windows Media 11? Won't there need to be a Windows Media patch to allow this? If not can we request this to happen soon, more codecs for streamin through WM 11 would be great. |
#3607 | Link | |
I included some more details on the new codec in this article: http://www.streamingmedia.com/articl...510&page=2&c=4 |
#3608 | Link | |
With a TrueHD HD DVD disc, the content author knows that the user can get all the bits of audio they can take. With a BD TrueHD + AC-3 disc, the contnent author will know that many customers with expensive players would just hear the AC-3. That's why we see AC-3 + PCM discs, right? |
#3609 | Link | |
Swollen Member
1) The track simply doesn't work on bare bones HD DVD machines (none of which exist at the moment). 2) Only two channels of the TrueHD track are decoded. 3) All TrueHD channels are decoded, but the sound is remixed to 2 channel audio. 4) The DVD Forum will be changing the spec to require TrueHD 5.1 support (which wouldn't affect existing players). Which of the above is true, if any? Options 3 (and 4) would be fine, but options 1 and 2 would be problems. (I believe there were some comments on this before, but I'm not sure exactly where.)
__________________
Everything Apple | Xbox 360 HD DVD audio lag | HD DVD movie size | Funai Blu-ray disc compatibility Last edited by BuGsArEtAsTy; 04-09-07 at 12:17 PM.. |
#3610 | Link | |
#3611 | Link | |
No one will be upset if you say the HD DVD update is coming AFTER the Spring Dashboard update, and it ends up coming early. BUT, people will be upset if you say it's coming before the Spring Dashboard update and it ends up coming after. So I can safely assume the HD DVD update should (key word is "should") arrive before the May 7 Spring Dashboard update. |
#3612 | Link | |
Blu-ray Insider
- Talk
__________________
Blu-ray Insider Speaking solely for myself, not the BDA |
#3614 | Link | ||
Blu-ray Insider
- Talk
__________________
#3617 | Link |
Swollen Member
Is BD-9 an official Blu-ray format? I'm getting mixed info on this. I know 3X HD DVD is an official HD DVD format.
(I think the above will be very important for consumers.)
__________________
Everything Apple | Xbox 360 HD DVD audio lag | HD DVD movie size | Funai Blu-ray disc compatibility |
#3618 | Link | |
Blu-ray Insider
__________________
#3619 | Link | |
#3620 | Link | |
"This update will support MPEG-4 Part 2 data in a .mp4 file, but not in a .avi."
That sucks as the vast majority of internet video is .avi format. Also an idea on streaming or disc support for plain old mpeg2 .mpg files? I have some TS HD streams from my cable box in .mpg format that I'd like to stream to the 360 and do not want to convert them to .wmv as in trying to do this has been a disaster. |
#3621 | Link | |
#3622 | Link | ||
Second - what about mixing those video codec's with other audio codecs that are already supported on a 360. eg. H.264 video + DD 5.1 / AC3 audio?
__________________
My basement renovation project |
#3623 | Link | |
Blu-ray Insider
My point is that what Blu-ray takes away by not mandating TrueHD (824MB to support a DD 5.1 track alongside a TrueHD track on a three-hour movie) it gives back many times over with an extra 20GB and 18Mb/s of bandwidth. And the further marketplace reality is that the majority of HD DVD owners don't have players capable of outputting the lossless track (the Xbox 360 add-on), while the majority of Blu-ray owners do (the PS3). On what point do you and I disagree?
__________________
#3624 | Link | ||
#3625 | Link |
Animephile
Transport streams do support H.264/AVC along with AC3 yes. It's fast becoming one of the major standards for DVB in Europe in particular. Do you know if there's any plans to support transport streams containing that - say for recorded content? 15Mbps max peak is also not going to cut it for those kind of streams, unless that quote above is average bitrate?
__________________
/frode |
#3626 | Link | |
Users could add them to the 360 on their own if needed through a USB thumbdrive by selecting it and pressing an "add codec" button or something in the dashboard (just a crazy thought). In that case, Microsoft wouldn't have to officially 'support' every codec. The user base would supply their own. A "Remove codec" button could be used to delete it. Kind of like Windows very own "Add/remove Programs" in the control panel. I hope Microsoft understands how close they are to ruling the entertainment room with the 360. If it could play all types of files like a PC the 360 would be the ultimate multimedia device.
__________________
-David |
#3627 | Link |
HD DVD Resume Feature
I know this has been brought up before, but it just does not make sense to me that HD DVD cannot do resume play:
1) The player knows the position that I was playing because I can go back into the menu and return to the same spot. 2) I can start at the beginning and drag the time slider (at least in PowerDVD) to the correct position. So a macro can be made to do it for me, right? From a user standpoint, this is a major omission. Is it not in the player’s capabilities to provide this feature even if the disk does not? - Rich |
#3628 | Link |
Yep,
Note to AMIR if you guys ever support streaming of divx or xvid HD in .avi format from the pc to your Xbox 360 natively with no other conversion you have won the home media hub race. The 360 would then become the ultimate media streaming appliance. You guys are so close .avi support for divx and xvid and .mpg are all you need for the win. |
#3629 | Link | |
Also - matroska supports pretty much any combination of video and audio you want to put into a single file. I do a lot of recording of MPEG2+AC3 transport streams over firewire from my DCT-6200. To save HD space I transcode the video to h.264 and usually just mux that + the original audio into a mkv file. The ASF/WMV container I believe should also technically be able to have h.264 + AC3 in it. I know I've muxed VC1 + AC3 into a WMV before. Its far from standard, but if the 360 will demux it and send the audio+video off to their proper codecs for display, then I'd be happy ![]()
__________________
| Bookmarks |
| Thread Tools | |
