AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 12-27-06, 12:00 AM   #1   |  Link
guru76
Comcast Motorola DCT 6412 III - Panasonic Plasma Aspect Control
I have a Panasonic Plasma TH-42PX60U. I have the Motorola DCT 6412 III cable box. I was trying to program the motorola remote to work with the TV. I am not abe to get the Aspect functionality to work. Everything else (like Power/Volume/Inputs/Mute) works fine.
I have the cable box connected to the TV using HDMI. The cable box is set to output 1080I. 4:3 override is set to 480I. I am able to control aspect using the TV remote, but not using the motorola remote.
Anybody have any ideas how to program this functionality?
guru76 is offline   Reply With Quote
Old 12-27-06, 08:10 AM   #2   |  Link
Kupakai
Which remote do you have? Is it this one?
http://en.wikibooks.org/wiki/How_to_...ing_the_Remote
If it is, which device code are you using for the TV?
Kupakai is offline   Reply With Quote
Old 12-27-06, 01:06 PM   #3   |  Link
guru76
The code is 0250
Old 12-27-06, 01:52 PM   #4   |  Link
Kupakai
I'm not sure if this will work, since the protocol for device TV/0250 is not exactly the same as the one I got this number from, but try a keymove with the code: 60481
1. Press the "TV" button at the top of the remote.
2. Press and hold the "Setup" button until the "TV" button blinks twice.
3. Type in the code 994. The "TV" button will blink twice.
4. Press (do not hold) the "Setup" button.
5. Type in the code 60481.
6. Press whatever button you want to for the function (ex: "HD Zoom" seems like a good one for this function). The "TV" button will blink twice if successful.
BTW, if you are curious about where I got the number, you can read about JP1 cable for remotes made by UEI (like the Comcast remote) at this site:
http://www.hifi-remote.com/jp1/index.shtml
The URC-1067 remote is actually a JP1.2 remote, which requires a different cable, but the info there still applies.
Old 12-27-06, 02:52 PM   #5   |  Link
guru76
Thanks a lot. Will give it a try when I get home.
Old 12-29-06, 01:29 PM   #6   |  Link
guru76
That didn't work. I even tried the 0650 code instead of the 0250 code for the TV. Then I keyed in the 222 code for the aspect ratio, but it still did not work.
I guess I will have to live with 2 remotes. Or buy the Harmony universal remote.
Old 01-15-07, 01:43 AM   #7   |  Link
Kupakai
If you are still interested, I think I found what might work.
First just to test it:
1. set AUX to code 1490
2. press AUX
3. Press and hold the "Setup" button until the "AUX" button blinks twice.
4. Type in the code 994. The "AUX" button will blink twice.
5. Press (do not hold) the "Setup" button.
6. Type in the code 09761.
7. Press whatever button you want to for the function (ex: "HD Zoom"). The "AUX" button will blink twice if successful.
Try the new key. If that works, AUX/1490 should work for most of the buttons, but it's a code for AUX, not TV, so you need to change the TV button to accept device codes for AUX:
1. Press and hold the "Setup" button until the LED blinks twice.
2. Type 992. The LED will blink twice.
3. Press "AUX" once
4. Press "TV" once
Now you can set TV to code 1490:
1. Press "TV"
3. Type 1490. The "TV" button will blink twice.
Now you can assign a button to aspect.
1. press "TV"
5. Type in the code 09761.
6. Press whatever button you want to for the function (ex: "HD Zoom"). The "TV" button will blink twice if successful.
If this code works, you may also want to try:
15393 Component input 1
16417 Component input 2
26913 Aspect Zoom
43297 Aspect Full
Old 01-16-07, 11:36 PM   #8   |  Link
guru76
Thanks a lot!!
Worked like a charm. I also tried the discrete code for Zoom, but that did not work. Doesn't matter at all. Am really happy with this.
2. press AUX
3. Press "AUX" once
4. Press "TV" once
1. Press "TV"
1. press "TV"
26913 Aspect Zoom
43297 Aspect Full
Old 01-04-08, 03:27 PM   #9   |  Link
MIAaron
I know it's an old thread, but does anyone know the codes for hdmi1 and hdmi2?
Thx
MIAaron is offline   Reply With Quote
Old 01-04-08, 06:41 PM   #10   |  Link
Kupakai
Follow the steps in post #7 but try these codes:
HDMI 1 = 54561
HDMI 2 = 55585
If you are using a different setup code for the rest of the TV functions (ie TV/0250), after you program in the advanced codes, set the TV back to TV mode and that previous setup code and the advanced codes you programmed in should still be programmed.
Old 01-06-08, 05:23 PM   #11   |  Link
MIAaron
Thanks, that's just what I needed! After I set TV back to TV mode they don't work anymore, but it's not a big deal to hit the aux button to change hdmi inputs. Thanks for the help!
Old 02-21-09, 11:05 AM   #12   |  Link
BRADH
BRADH's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (1)
I have a Comcast 6416 and a Panasonic TH-50PZ80U. I tried the above code for the aspect control and it didnt work. Were can I find a code that might work.
Thanks in advance
Brad
BRADH is online now   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.17020392 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
