#1 | Link |
New Member
Harmony 676 for X-Mas Should I keep it?
As the title says. I got a Harmony 676 for X-Mas and do not know what to do. I have found very little info about this remote. I was thinking of taking it back and getting the 880. I have done some looking around this forum and have seen many people say remote other then Harmony are better. What would you guys do?
Thanks BP |
#2 | Link | |
#3 | Link |
I love my 676. I've had it for 2 years now. I went with Harmony because it's easy to configure, easy to use, and I like the activity feature. If you have issues setting it up, customer service absolutely rocks. Unless you know of a remote you'd rather have, there's nothing wrong with the 676.
Harmony's web service has been 100% stable and usable for me. I have two Harmonies and have had no issues with either remote and Harmony's website. Actually, Harmony's website/software is the reason my next remote will be a Harmony as well. |
#4 | Link | |
Also, the tier one support guy told me he already had 4 complaints that morning of not being able to download from their server and that he advised his supervisor. I tried to configure both from the Harmony software loaded on my PC (ver 7.0.2) and also from the members web page with the same results (or lack of results as it happens). badbimr wanted to know if he should keep it. I'd have to vote "no". |
#6 | Link | |
#7 | Link |
New Member
I got one for Christmas also and could not be happier. Took 20 minutes to load the new software and I am a moron when it comes to the computer. Took another 20 minutes to set everything up and it all works perfectly.
I wonder if they weren't having server problems from the number of people trying to get in at once. |
#8 | Link | |
#10 | Link | |
#11 | Link |
As KidRed mentioned, the actual web interface is the way to go. I've found the software to be very difficult to use and not very useful in getting consistent downloads.
http://members.harmonyremote.com |
#12 | Link | |
#13 | Link | |
#14 | Link | |
#15 | Link | |
Success Against The Odds!
I finally got this 676 to work properly after round two with the Tier 2 support. To recap: my 676 would not take any updates. The update file would download and install but none of the changes would take effect. In one final test I was asked to remove the interchangeable face plate on the 676 and try the updates again. This time it worked! It seems the face plate was partially holding button(s) down which prevented the remote memory from accepting any changes even though the download completed successfully. The remote control came with the silver face plate installed. I tried the others but the red one wouldn't completely lock down on the right side and the blue one could not be applied at all without depressing several buttons. I put the silver one back on but one of the tape drive buttons stuck down and I had to manually pull it back up.
So I was right in one respect. This thing is a POS from the manufacturing standpoint. I haven't decided whether or not to send it back but my recommendation right now to anyone considering the purchase of a 676.....DON"T. You are in for a BIG hassle. |
#16 | Link |
New Member
I really like the 676!
I have owned two Harmony 676 remotes, and I'm going to buy a third one today. I haven't had any problems remotely like the ones mentioned in this thread. I have several separate A/V set ups in my house, thus the need for the multiple remotes. Also, having all the remotes being the same type make things easier on the mental workload.
The Harmony website will work fine with FireFox, they just show that stupid message. I can also put in my vote that the web site is a lot better than the software, which actually just looks like a version of the website in a separate little window. While there are definately flaws with the devices, and I admittedly don't have much experience with other types of remotes, I really like the Harmony 676. Todd
__________________
!todd erases a red dot! |
| Bookmarks |
| Thread Tools | |
