#1 | Link |
Creating a movie intro
I just received my disk of slides from HDReady102 and am working on putting together a few intros. I am also trying to put a few movie trailers into it that I have downloaded from Apple. I am using Ulead VideoStudio 10. Once I insert the trailers into the intro I am creating and play it back, it plays back almost like it is skipping. Can anybody recommend a good program that I can use for creating the intros? Thanks for any input you can give.
Mike |
#5 | Link | |
Hi mig1868,
I used Ulead software about a year and a half ago and it seems to me that I had this same problem with the video. I seem to recall that it was a frames per second issue. Might be a good place to start looking. This was of course before HD trailers were out so, I am not sure how that complicates the problem. |
#6 | Link |
HDReady102,
I am not really sure what the frame rate should be set at. Here is what it is set at right now..... NTSC drop frame (29.97 fps) MPEG files 24 bits, 720 x 480, 29.97 fps Lower Field First (DVD-NTSC), 16:9 Video data rate: Variable (Max. 8000 kbps) LPCM Audio, 48000 Hz, Stereo Is this ok or do you think it should be changed to something different? Thanks, Mike |
#7 | Link |
New Member
I had the same problem back when I started making videos, it's been a while, but the problem with the jerky playback may be that you need to switch from lower field first to upper field first. I learned from trial and error till I got it right. I also used some DVD RWs so I could try something then redo it instead of using up good nonrewritable DVD's. Hope this helps. Morgan
#8 | Link |
Just to let you know, I went out and got Roxio Media Creator 9 to do my intro's with. It works great and haven't had any problem with it at all with the above mentioned issue. Its a lot of fun putting something together with the pre-show slides and a few trailers. My wife and kids really thought they were so cool.
| Bookmarks |
| Thread Tools | |
