#1 | Link |
Bleacher Creature
How long till Harmony can handle newly released equipment?
If a particular device, such as a DVD player, receiver or TV, is newly released to the market, how long will it be before the Harmony can handle it?
When I fire up the Harmony software and tell it to add a device, it asks me to select the type of device, the brand name (i.e. Toshiba), and then to enter the model number of the device. However, once I've done that, I don't get any feedback as to whether that device is in the database (and hence will be operable by the Harmony). I'm interested in the Toshiba HD-A2 HD-DVD player, but because it's so new I'm concerned that my Harmony 880 won't work with it (I'm not aware of any compatibility list for things that the Harmony will work with). How can I make sure it will? How long does it take before Logitech's database is updated for use with any given brand-new piece of equipment?
__________________
"THE YANKEES ARE BACK ON TOP! World champions for the 27th time!" - Joe Buck, 2009 World Series Game 6, November 4, 2009 |
#2 | Link |
HD user since 1984
AVS CLUB MEMBER
Have no idea on length of time, but it should not matter too much as if you have the original remote and you should because it's new. Just teach it the commands it is lacking or you desire. simple. A lot of times it will obtain data from previous models that may no may not function.
__________________
Tony! My AV equipment / AC-3RF audio gear LDDb.com collection / D-Theater collection pic |
#4 | Link | |
Bleacher Creature
__________________
#5 | Link | |
The device will work straight away.
If it isn't already in the database, it will ask you to teach it from the original remote, and will ask some other questions about power settings etc. This is the way all devices are added to the Harmony database...ie they are added by users, not Harmony directly. This is why Harmony's database is so extensive(and sometimes has errors). |
#6 | Link | |
Bleacher Creature
__________________
#7 | Link |
There should be a confirmation screen asking you if the device you are adding is entered correctly. More than likely, the device is already there unless you are one of the first people do buy it. I've never run into a device that wasn't already there in the three different setups I have.
But as everyone else mentioned, why worry about it? You can literally learn the codes from the new remote in less than 5 minutes. |
#8 | Link | |
Basically, so long as your device has a IR remote, the Harmony can operate it. |
#9 | Link | |
Rouser of rabbles
I sent them an e-mail on Dec. 18. They promised a response within 24 hours. I'm still waiting. Logitech CS sucks.
__________________
Mediacom Digital Cable HD (using a TiVo S3 & TiVo HD both w/CableCARDS) and OTA HD. |
#11 | Link |
The database is really just a convenience. If Harmony doesn't have your particular model, it will likely set up the remote with a set of generic commands for that manufacturer, which may or may not work.
But it doesn't really matter whether it is in the database or not. Learning all of the remote codes from your original remote only adds about half an hour to the setup time, and then you are good to go. |
#12 | Link |
You could just try using the A1 remote settings. Chances are they will work. The Harmony databases are really messed up. I have commands that just don't work. This makes the device list long and tedious to scroll through.
Don't misunderstand... I love my Harmony remotes and have 3 of them! |
#13 | Link |
Bleacher Creature
Doesn't it kind of defeat the purpose of having a Harmony in the first place if you have to have it learn all the commands manually?
__________________
#14 | Link | |
Any universal remote can/will require learning of some commands. The Harmony database is by far the most extensive, but you can't expect it to have every single device ever manufactured in it...especially if that device has only just been released. As others have said, it's quite possible that the A2 uses the same code set as the A1, so the learning might only be about 3 commands...all it needs to match the codeset to a codeset already on file. |
#15 | Link | |
Bleacher Creature
Apparently the Harmony database doesn't know about the Pioneer BDP-HD1 BluRay player either; I just tried to add that device (I don't have the player yet, but I wanted to make sure the Harmony could operate it), and it apparently doesn't know any of the commands.
__________________
#17 | Link | |
I have not seen a device yet that doesn't have some sort of generic codes that don't apply to it in their database. It's stupid. This is why there are never any discrete codes! God damnit. I'm pissed. This is why i'm switching to URC which can import Hex codes from pronto AND has a real database |
#18 | Link | |
#19 | Link | |
#20 | Link | |
| Bookmarks |
| Thread Tools | |
