AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 12-30-06, 12:36 AM   #1   |  Link
JSein456
Question 880 and Olevia inputs...weird issue.
I got one of these for Christmas, and I love it, but I noticed a strange issue with how it changes inputs on my Olevia. Let me describe my setup...I use Component 1 for Watch TV, Component 2 for Play Game, and DVI for Watch DVD.
Here is the issue:
If I switch to the DVI input from Component 1 (from Watch TV to Watch DVD) and back to either Watch TV or Play Game, the TV will end up to the proper input. BUT, if I change to DVI from Component 2 (from Play Game to Watch DVD) and back to either Watch TV or Play Game, the TV will go to the wrong input for either one of these.
After that I have to use the help button to fix it up. Other than the above it switches inputs just fine.
I've been knocking my head against the wall trying to figure out why this happens and how to fix this. I even e-mailed tech support...Maybe the function wasn't coded properly or something.
JSein456 is offline   Reply With Quote
Old 12-30-06, 04:31 AM   #2   |  Link
czzer
Go to "Adjust Inputs" for the TV device and answer all the questions carefully. Make sure the list of inputs matches exactly what your TV actually has.
czzer is offline   Reply With Quote
Old 01-01-07, 08:37 PM   #3   |  Link
JSein456
Actually, I'm using the default setup for the TV from the database. It works well, except if you switch to DVI from Component 2. After that, if you try to go to an activity using the component inputs, you'll have them reversed, like 1 instead of 2 and 2 instead of 1.
The other way of switching inputs is a list/scroll/select option, but that takes longer.
It's a shame that Olevia has 1 button for both component inputs on the remote, 1 for VGA/DVI, and one for all 3 video inputs, instead of individual commands.
Has anyone had experience with the tech support? Do they help people fix these kinds of issues with the database commands for these TVs?
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09203291 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
