AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 12-31-06, 03:05 AM   #1   |  Link
Chief Ediri
Artest=NBA CHAMPS!
Question DISH Network Picture Quality
About 2 weeks ago, I got DISH Network installed into my TV. It is a SD set top box and is connected through S-Video and RCA audio cables. The picture quality has alot of static and pixelation on my TV, noticably worse than Time Warner Cable. I was wondering if that is normal or it could be a problem with the satillite alignment?
Chief Ediri is offline   Reply With Quote
Old 12-31-06, 12:04 PM   #2   |  Link
miniz
OFFICAL HOME OF HDTV
Sticky: Please redirect DBS chat to the new sister site DBSTalk.com
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!"
miniz is offline   Reply With Quote
Old 12-31-06, 05:33 PM   #3   |  Link
hometheaterguy
You either get satelllite 110 (East coast channels) and satellite 119 (West coast channels), or you do not. Having reception of these satellites verified from a check switch with a high signal has nothing to do with picture quality. Having a signal level from 85 to 124 has nothing to do with the picture. Having a stronger signal overcomes bad weather and recovers from it faster is all. If S-VIDEO is the best video cable you can use then the picture quality may be the cable from the dish (LNB), verify no splices save the ground block, have a hi-freq ground block, 3000MHz cable, less then 100', a hi- freq wall plate, and no RG-59 between the LNB and receiver. Use compression fittings everywhere as well. If in doubt have your installer replace everything, but the receiver. Last case would be a TV issue.
hometheaterguy is offline   Reply With Quote
Old 12-31-06, 06:40 PM   #4   |  Link
Chief Ediri
Artest=NBA CHAMPS!
Thanks for the help. I greatly apperciate it.
Old 01-02-07, 03:26 PM   #5   |  Link
Lex vs Kingpin
morning glory
2 weeks ago I also switched from direct tv to dish network *due to number of hd channels*. In addition, I also changed my tv set from 36" sony wega (crt) to 42" panny 8 series commercial plasma unit.
My first impression was exactly like yours, but couldnt decide whether it is due to satellite provider or the tv itself.
The installer guy used his component cables and I was too busy to change it to hdmi. After i start using hdmi output from stb that did the trick
The change, indeed, was dramatic in my case. Hope it helps...
Lex vs Kingpin is offline   Reply With Quote
Old 01-07-07, 01:13 PM   #6   |  Link
Chief Ediri
Artest=NBA CHAMPS!
OK, it might be the type of cables I am using.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11498809 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
